I'm trying to edit the C library code which communicates with the nrf52 dongle. I'm using custom gatt & the descriptor CCCD is 0x2902. Since its not able to find the correct descriptor, read & write operations fail. Please help.
Serial port used: COM18 Baud rate used: 1000000 Info: Successfully opened COM18. Baud rate: 1000000. Flow control: none. Parity: none. Status: 6, message: Target Reset performed RESET_PERFORMED: Target Reset performed Status: 7, message: Connection active CONNECTION_ACTIVE: Connection active nRF BLE Driver successfully opened BLE stack enabled Scan started Received advertisement report with device address: 0xCEA7F96FB0FD Connection Request Succeeded Received advertisement report with device address: 0x74F61C14801C Connection established Discovering primary services Successfully added the custom gatt service. Initiate or continue a GATT Primary Service Discovery procedure Received service discovery response Discovered custom gatt service. UUID: 0x1400, start handle: 0x000E, end handle: 0xFFFF Discovering characteristics Received characteristic discovery response, characteristics count: 1 Characteristic handle: 0x000F, UUID: 0x1401 Custom gatt characteristic found. Discovering characteristic's descriptors 0x000F Received descriptor discovery response, descriptor count: 1 Handle: 0x000F, UUID: 0x2803 Descriptor handle: 0x000F, UUID: 0x2803 1 Setting custom gatt CCCD Error. No CCCD handle has been found Setting custom gatt CCCD Error. No CCCD handle has been found
