nRF connect SDK fails to build with "attempt to assign the value 'y' to the undefined symbol"
Just reporting an issue I am having with the nRF9160 SDK in the hope that it will help someone else. OS is Ubuntu 18.04.
I was getting errors which look like this:
/home/jeremy/nrfconnect/ncs/nrf/samples/nrf9160/https_client/prj.conf:2: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
/home/jeremy/nrfconnect/ncs/nrf/samples/nrf9160/https_client/prj.conf:3: warning: attempt to assign the value 'n' to the undefined symbol BSD_LIBRARY_SYS_INIT
/home/jeremy/nrfconnect/ncs/nrf/samples/nrf9160/https_client/prj.conf:12: warning: attempt to assign the value 'y' to the undefined symbol MODEM_KEY_MGMT
/home/jeremy/nrfconnect/ncs/nrf/samples/nrf9160/https_client/prj.conf:13: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
and these were preventing the build from completing. The issue here is that the nRF connect setup asks you to install the pip libraries using the --user flag, which will put everything in ~/.local/bin. However, this path is not part of the default PATH environment variable. Adding this to the path in Segger Embedded Studio (or CLion in my case) is what fixed the problem.
