I am using the TWI scanner example from the sdk15. Board is NRF52840. I have a differential pressure sensor connected to the TWI input pins on the nordic board and am trying to read the pressure. However, for that I need to be able to observe that there is a device.
I have gotten this sensor working via an arduino with the same pin connections as I am using for the Nordic board. 2 4.7Kohm resistors one for each line upto VDD(3.3).
I am using the P27 and P26 ports as defined in the example they are not used for anything else. But when I run my terminal I just get a loop stating no devices are connected.
I can see using a logic analyser that the clock and data are running but no response. My sensor has the address of 0X40.
Here is my code:
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup tw_scanner main.c
* @ingroup nrf_twi_example
* @brief TWI Sensor Example main file.
* This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID 0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID 1
/* Number of possible TWI addresses. */
#define TWI_ADDRESSES 127
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
* @brief TWI initialization.
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl = ARDUINO_SCL_PIN,//27 (green)
.sda = ARDUINO_SDA_PIN,//26 (yellow)
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
nrf_drv_twi_enable(&m_twi);
uint8_t address;
uint8_t sample_data;
bool detected_device = false;
NRF_LOG_INFO("TWI scanner started.");
NRF_LOG_FLUSH();
twi_init();
for (address = 1; address <= TWI_ADDRESSES; address++)
err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
if (err_code == NRF_SUCCESS)
detected_device = true;
NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
NRF_LOG_FLUSH();
if (!detected_device)
NRF_LOG_INFO("No device was found.");
NRF_LOG_FLUSH();
while (true)
NRF_LOG_FLUSH();
NRF_LOG_FLUSH();
nrf_delay_ms(500);
Here is my scope:
Note the top line is the clock and bottom is the data (SCL and SDA respectively)
After fixing the issue of not seeing the device on the Nordic board I then will need to emulate my arduino code on the board to read this sensor.
Please could someone look into this issue
Thanks
