To the kind attention of Nordic support team,
I have got a project with this memory configuration
and this
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
<MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
<ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
<ProgramSection alignment="4" load="Yes" name=".init" />
<ProgramSection alignment="4" load="Yes" name=".text" />
<ProgramSection alignment="4" load="Yes" name=".dtors" />
<ProgramSection alignment="4" load="Yes" name=".ctors" />
<ProgramSection alignment="4" load="Yes" name=".rodata" />
<ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
<ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
<ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
<ProgramSection alignment="4" load="No" name=".GZP_PARAMS" start="0x09000" size="4096" />
</MemorySegment>
<MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
<ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
<ProgramSection alignment="4" load="No" name=".bss" />
<ProgramSection alignment="4" load="No" name=".fast_run" />
<ProgramSection alignment="4" load="No" name=".data_run" />
<ProgramSection alignment="4" load="No" name=".tdata_run" />
<ProgramSection alignment="4" load="No" name=".tbss" />
<ProgramSection alignment="4" load="No" name=".non_init" />
<ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
<ProgramSection alignment="4" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" address_symbol="__StackLimit" end_symbol="__StackTop"/>
<ProgramSection alignment="4" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
</MemorySegment>
</Root>
flash_placement.xml files. What it happens is that if I put a little array in stack memory the program seems to go ok, both encrypted and non encrypted communications works very well.
If I put the very same array in .bss memory, the encrypted communication keeps working, but nrf_gzll_add_packet_to_tx_fifo fails after one or two good communications. If I add another
array in stack and I give this address to nrf_gzll_add_packet_to_tx_fifo, then it works ok again. It seems that the routine needs a stack address. It is really strange behaviour, I don't know what to think.
What could theoretically be? Basically I'm evaluating the standard gzp program device host program in Segger environemnt and the little array I'm moving around is the 32 byte gazell payload one. Obviously, I'm not 100% sure of device configuration, it being excluded from SDK in its segger incarnation.
Hope you could give me a theoretically hint about memory configuration. Thank you for your kindness
