Hello, I am using a nRF51822 chip to communicate with a sensor. The sensor continuously outputs its reading via UART every couple of seconds. This is what I am currently doing which works perfectly...... unless the sensor is bad, or not installed. Either of these functions will prevent the firmware from continuing to run, and essentially locks everything up.
I am using this to initialize the UART:
void UART_init( uint8_t pin_rx, uint8_t pin_tx ) { uint32_t err_code; const app_uart_comm_params_t comm_params = { pin_tx, //nRF51 RX pin_rx, //nRF51 TX 2, //not used 3, //not used APP_UART_FLOW_CONTROL_DISABLED, false, UART_BAUDRATE_BAUDRATE_Baud9600 }; APP_UART_FIFO_INIT(&comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_error_handle, APP_IRQ_PRIORITY_LOW, err_code); APP_ERROR_CHECK(err_code); }
And I use this to read the UART data:
void Read_string( char *resultPointer ) { uint8_t charResponse; char cToStr[2]; cToStr[1] = '\0'; for(int i = 0; i < RX_BUF_SIZE; i++) { while(app_uart_get(&charResponse) != NRF_SUCCESS); cToStr[0] = charResponse; strcat(resultPointer,cToStr); if(charResponse == '\n'){ break; } } return; }
Do you know of a good way, such as if I don't get a reading after X amount of time, then to just exit and try later? Or is there a better way of handling this? There are other firmware functions that I would like to continue running even if the sensor goes bad.
Thanks and any help or advice is greatly appreciated!
