want to save data in flash
hi... i want to store data in flash , i will get the data periodically . i have merged the ble_app_uart +fstorage example . Even i am writing data to flash using write command ,when i am trying to print the data which is stored in flash , it getting printed but seems like it is not printing the data from flash ,,, in my case , my data will change periodically  so i need to save everything
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "nrf_fstorage.h"
#include "nrf_fstorage_sd.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
#define SAMPLES_IN_BUFFER 1
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(3);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
uint8_t distance,V;
static char     m_hello_world[80];
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
         str[i]  = p_evt->params.rx_data.p_data[i];
do
               // err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    nrf_pwr_mgmt_run();
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
           V =  ((( p_event->data.done.p_buffer[i]* 3.6) / (1023)) * 3);
           distance = 30/V;
      m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
    /* Set a handler for fstorage events. */
    .evt_handler = fstorage_evt_handler,
    /* These below are the boundaries of the flash space assigned to this instance of fstorage.
     * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
     * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
     * last page of flash available to write data. */
    .start_addr = 0x3e000,
    .end_addr   = 0x3ffff,
/**@brief   Helper function to obtain the last address on the last page of the on-chip flash that
 *          can be used to write user data.
static uint32_t nrf5_flash_end_addr_get()
    uint32_t const bootloader_addr = NRF_UICR->NRFFW[0];
    uint32_t const page_sz         = NRF_FICR->CODEPAGESIZE;
    uint32_t const code_sz         = NRF_FICR->CODESIZE;
    return (bootloader_addr != 0xFFFFFFFF ?
            bootloader_addr : (code_sz * page_sz));
    if (p_evt->result != NRF_SUCCESS)
        NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
        return;
    switch (p_evt->id)
        case NRF_FSTORAGE_EVT_WRITE_RESULT:
            NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
                         p_evt->len, p_evt->addr);
        } break;
        case NRF_FSTORAGE_EVT_READ_RESULT:
         NRF_LOG_INFO("--> Event received: read %d bytes at address 0x%x.",
        case NRF_FSTORAGE_EVT_ERASE_RESULT:
            NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
        } break;
void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
    /* While fstorage is busy, sleep and wait for an event. */
    while (nrf_fstorage_is_busy(p_fstorage))
        //power_manage();
/**@brief Application main function.
    bool erase_bonds;
    uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
 saadc_sampling_event_init();
    saadc_init();
    NRF_LOG_INFO("SAADC HAL simple example started.");
    while(1)
     char con[100];
    static uint8_t len;
    len = sprintf(con,"%d",distance);
    ble_nus_data_send(&m_nus,con,sizeof(len),m_conn_handle);
    nrf_delay_ms(1000);
    ret_code_t rc;
#ifndef SOFTDEVICE_PRESENT
    clock_init();
    NRF_LOG_INFO("fstorage example started.");
nrf_delay_ms(10000);
    nrf_fstorage_api_t * p_fs_api;
#ifdef SOFTDEVICE_PRESENT
    NRF_LOG_INFO("SoftDevice is present.");
    NRF_LOG_INFO("Initializing nrf_fstorage_sd implementation...");
    /* Initialize an fstorage instance using the nrf_fstorage_sd backend.
     * nrf_fstorage_sd uses the SoftDevice to write to flash. This implementation can safely be
     * used whenever there is a SoftDevice, regardless of its status (enabled/disabled). */
    p_fs_api = &nrf_fstorage_sd;
#else
    NRF_LOG_INFO("SoftDevice not present.");
    NRF_LOG_INFO("Initializing nrf_fstorage_nvmc implementation...");
    /* Initialize an fstorage instance using the nrf_fstorage_nvmc backend.
     * nrf_fstorage_nvmc uses the NVMC peripheral. This implementation can be used when the
     * SoftDevice is disabled or not present.
     * Using this implementation when the SoftDevice is enabled results in a hardfault. */
    p_fs_api = &nrf_fstorage_nvmc;
    rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
    APP_ERROR_CHECK(rc);
   // print_flash_info(&fstorage);
    /* It is possible to set the start and end addresses of an fstorage instance at runtime.
     * They can be set multiple times, should it be needed. The helper function below can
     * be used to determine the last address on the last page of flash memory available to
     * store data. */
    (void) nrf5_flash_end_addr_get();
    wait_for_flash_ready(&fstorage);
    NRF_LOG_INFO("Done.");
/*#ifdef SOFTDEVICE_PRESENT
    NRF_LOG_INFO("Enabling the SoftDevice.");
    rc = nrf_fstorage_write(&fstorage, 0x3f000, str,sizeof(str), NULL);
    rc = nrf_fstorage_read(&fstorage, 0x3f000, str,sizeof(str));
NRF_LOG_INFO("Writing \"%s\" to flash.", m_hello_world);
     printf("Write\"%s\" to flash.", m_hello_world);
    // Enter main loop.
    for (;;)
        idle_state_handle();
see the code below ,
  • I see the code you posted, but this does not include the full file. There is no information about how you call the functions. Do you wait for the successful FDS_EVT_WRITE event after writing before reading? FDS is also asynchronous, if you do not wait, the read function will not find any records.
  • Here i am dropping my main code
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "fds.h"
    #define RELAY_PIN 29
    static volatile uint8_t write_flag_fds_test = 0;
    #define FILE_ID_FDS_TEST     0x1111
    #define REC_KEY_FDS_TEST     0x2222
        uint32_t                err_code;
            uint32_t err_code;
     do
        uint32_t           err_code;
        // Initialize NUS.
        uint32_t err_code;
        uint32_t err_code;
                sleep_mode_enter();
        uint32_t err_code;
            } break;
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
        uint32_t       err_code;
                index++;
                    if (index > 1)
                        do
                    index = 0;
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
        nrf_pwr_mgmt_run();
    static void my_fds_evt_handler(fds_evt_t const * const p_fds_evt)
        switch (p_fds_evt->id)
            case FDS_EVT_INIT:
                if (p_fds_evt->result != FDS_SUCCESS)
                    // Initialization failed.
    				case FDS_EVT_WRITE:
    						if (p_fds_evt->result == FDS_SUCCESS)
    							write_flag_fds_test=1;
                                                            printf("hello");
                                                             NRF_LOG_INFO("writting");
                                                            //  printf("Writing Record ID = %d \r\n",record_desc.record_id);
    static ret_code_t fds_test_write(void)
    		//static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
    		static uint8_t const m_deadbeef[4] = {0x1,0x2,0x3,0x4};
    		fds_record_t        record;
    		fds_record_desc_t   record_desc;
    		// Set up data.
    		// Set up record.
    		record.file_id              = FILE_ID_FDS_TEST;
    		record.key              		= REC_KEY_FDS_TEST;
    		record.data.p_data       = &m_deadbeef;
    		//record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint32_t);
    		record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint8_t);
    		ret_code_t ret = fds_record_write(&record_desc, &record);
    		if (ret != FDS_SUCCESS)
    				return ret;
    		 NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
    		return NRF_SUCCESS;
    static ret_code_t fds_read(void)
    		fds_flash_record_t  flash_record;
    		fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
    		//uint32_t *data;
    		uint8_t *data;
    		uint32_t err_code;
    		NRF_LOG_INFO("Start searching... \r\n");
    		// Loop until all records with the given key and file ID have been found.
    		while (fds_record_find(FILE_ID_FDS_TEST, REC_KEY_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
    				err_code = fds_record_open(&record_desc, &flash_record);
    				if ( err_code != FDS_SUCCESS)
                                             NRF_LOG_INFO("Data ");
    					return err_code;
    				NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
    				NRF_LOG_INFO("Data = ");
    				data = (uint8_t *) flash_record.p_data;
    				for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
    					NRF_LOG_INFO("0x%8x ",data[i]);
                                            printf("0x%8x",data[i]);
    				NRF_LOG_INFO("\r\n");
    				// Access the record through the flash_record structure.
    				// Close the record when done.
    				err_code = fds_record_close(&record_desc);
    				if (err_code != FDS_SUCCESS)
    					return err_code;
    		return NRF_SUCCESS;
    static ret_code_t fds_test_find_and_delete (void)
    		fds_find_token_t    ftok;
    		ftok.page=0;
    		ftok.p_addr=NULL;
    		// Loop and find records with same ID and rec key and mark them as deleted.
    			fds_record_delete(&record_desc);
    			NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
    		// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
    		ret_code_t ret = fds_gc();
    				return ret;
    		return NRF_SUCCESS;
    static ret_code_t fds_test_init (void)
    		ret_code_t ret = fds_register(my_fds_evt_handler);
    					return ret;
    		ret = fds_init();
    				return ret;
    		return NRF_SUCCESS;
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
    fds_test_init();
    fds_test_find_and_delete();
    fds_test_write();
    while (write_flag_fds_test==0);
    fds_read();
    	 // Test FDS:
        // Start execution.
        // Enter main loop.
        for (;;)
  • I tested your application. As I suspected, your call to fds_record_find() inside fds_read() does not return FDS_SUCCESS and the record will never be opened. This is caused by the application not waiting for a successful FDS_EVT_INIT event before performing the write. You can check in the FDS example in the SDK, how to fix this using a flag.
  • yes i am done ,but while printing the read data , i am getting the garbage values , please help me with this
     * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #else
    #include "nrf_drv_clock.h"
    #include "fds.h"
    #include "app_error.h"
    #include "nrf_cli.h"
    #include "fds_example.h"
    #define NRF_LOG_MODULE_NAME app
    /* A tag identifying the SoftDevice BLE configuration. */
    /* Array to map FDS return values to strings. */
    char const * fds_err_str[] =
        "FDS_SUCCESS",
        "FDS_ERR_OPERATION_TIMEOUT",
        "FDS_ERR_NOT_INITIALIZED",
        "FDS_ERR_UNALIGNED_ADDR",
        "FDS_ERR_INVALID_ARG",
        "FDS_ERR_NULL_ARG",
        "FDS_ERR_NO_OPEN_RECORDS",
        "FDS_ERR_NO_SPACE_IN_FLASH",
        "FDS_ERR_NO_SPACE_IN_QUEUES",
        "FDS_ERR_RECORD_TOO_LARGE",
        "FDS_ERR_NOT_FOUND",
        "FDS_ERR_NO_PAGES",
        "FDS_ERR_USER_LIMIT_REACHED",
        "FDS_ERR_CRC_CHECK_FAILED",
        "FDS_ERR_BUSY",
        "FDS_ERR_INTERNAL",
    /* Array to map FDS events to strings. */
    static char const * fds_evt_str[] =
        "FDS_EVT_INIT",
        "FDS_EVT_WRITE",
        "FDS_EVT_UPDATE",
        "FDS_EVT_DEL_RECORD",
        "FDS_EVT_DEL_FILE",
        "FDS_EVT_GC",
    /* Dummy configuration data. */
    static configuration_t m_dummy_cfg =
        .device_name = "999555",
    /* A record containing dummy configuration data. */
    static fds_record_t const m_dummy_record =
        .file_id           = CONFIG_FILE,
        .key               = CONFIG_REC_KEY,
        .data.p_data       = &m_dummy_cfg,
        /* The length of a record is always expressed in 4-byte units (words). */
        .data.length_words = (sizeof(m_dummy_cfg) + 3) / sizeof(uint32_t),
    /* Keep track of the progress of a delete_all operation. */
    static struct
        bool delete_next;   //!< Delete next record.
        bool pending;       //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete the next record.
    } m_delete_all;
    /* Flag to check fds initialization. */
    static bool volatile m_fds_initialized;
    static void fds_evt_handler(fds_evt_t const * p_evt)
        NRF_LOG_GREEN("Event: %s received (%s)",
                      fds_evt_str[p_evt->id],
                      fds_err_str[p_evt->result]);
        switch (p_evt->id)
            case FDS_EVT_INIT:
                if (p_evt->result == FDS_SUCCESS)
                    m_fds_initialized = true;
            case FDS_EVT_WRITE:
                    NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id);
                    NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
                    NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
            } break;
            case FDS_EVT_DEL_RECORD:
                    NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
                    NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
                    NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
                m_delete_all.pending = false;
            } break;
    /**@brief   Begin deleting all records, one by one. */
    void delete_all_begin(void)
        m_delete_all.delete_next = true;
    /**@brief   Process a delete all command.
     * Delete records, one by one, until no records are left.
    void delete_all_process(void)
        if (   m_delete_all.delete_next
            & !m_delete_all.pending)
            NRF_LOG_INFO("Deleting next record.");
            m_delete_all.delete_next = record_delete_next();
            if (!m_delete_all.delete_next)
                NRF_LOG_CYAN("No records left to delete.");
    /**@brief   Function for initializing the SoftDevice and enabling the BLE stack. */
        ret_code_t rc;
        uint32_t   ram_start;
        /* Enable the SoftDevice. */
        rc = nrf_sdh_enable_request();
        rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
        rc = nrf_sdh_ble_enable(&ram_start);
    #else
    static void clock_init(void)
        /* Initialize the clock. */
        ret_code_t rc = nrf_drv_clock_init();
        /* Wait for the clock to be ready. */
        while (!nrf_clock_lf_is_running()) {;}
    /**@brief   Initialize the timer. */
    static void timer_init(void)
    /**@brief   Initialize logging. */
        ret_code_t rc = NRF_LOG_INIT(NULL);
    /**@brief   Sleep until an event is received. */
    static void power_manage(void)
        (void) sd_app_evt_wait();
    #else
        __WFE();
    /**@brief   Wait for fds to initialize. */
    static void wait_for_fds_ready(void)
        while (!m_fds_initialized)
            power_manage();
        ret_code_t rc;
        ble_stack_init();
    #else
        clock_init();
        timer_init();
        log_init();
       cli_init();
        NRF_LOG_INFO("FDS example started.")
        /* Register first to receive an event when initialization is complete. */
        (void) fds_register(fds_evt_handler);
        NRF_LOG_INFO("Initializing fds...");
        rc = fds_init();
        /* Wait for fds to initialize. */
        wait_for_fds_ready();
        NRF_LOG_INFO("Available commands:");
        NRF_LOG_INFO("- print all\t\tprint records");
        NRF_LOG_INFO("- print config\tprint configuration");
        NRF_LOG_INFO("- update\t\tupdate configuration");
        NRF_LOG_INFO("- stat\t\tshow statistics");
        NRF_LOG_INFO("- write\t\twrite a new record");
        NRF_LOG_INFO("- delete\t\tdelete a record");
        NRF_LOG_INFO("- delete_all\tdelete all records");
        NRF_LOG_INFO("- gc\t\trun garbage collection");
        NRF_LOG_INFO("Reading flash usage statistics...");
        fds_stat_t stat = {0};
        rc = fds_stat(&stat);
        NRF_LOG_INFO("Found %d valid records.", stat.valid_records);
        NRF_LOG_INFO("Found %d dirty records (ready to be garbage collected).", stat.dirty_records);
        fds_record_desc_t desc = {0};
        fds_find_token_t  tok  = {0};
    uint8_t *data;
        rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);
        if (rc == FDS_SUCCESS)
            /* A config file is in flash. Let's update it. */
            fds_flash_record_t config = {0};   //!< Location of the record data in flash.
            /* Open the record and read its contents. */
            rc = fds_record_open(&desc, &config); //last known locaton of the data in flash
            if ( rc != FDS_SUCCESS)
                                             printf("Data ");
    					return rc;
    				printf("Found Record ID = %d\r\n",desc.record_id);
                                    data = (uint8_t ) config.p_data;
                                     printf("%d",data);
                                    for (uint8_t i=3;i<config.p_header->length_words;i++)
                                        printf("data ");
                                           // printf("%d\n  data:",data[i]);
            /* Copy the configuration from flash into m_dummy_cfg. */
           // memcpy(&m_dummy_cfg, config.p_data, sizeof(configuration_t));
           // NRF_LOG_INFO("Config file found, updating boot count to %d.", m_dummy_cfg.boot_count);
            /* Update boot count. */
           // m_dummy_cfg.boot_count++;
            /* Close the record when done reading. */
            rc = fds_record_close(&desc);
            /* Write the updated record to flash. */
            rc = fds_record_update(&desc, &m_dummy_record);
            /* System config not found; write a new one. */
            NRF_LOG_INFO("Writing config file...");
            rc = fds_record_write(&desc, &m_dummy_record);
        cli_start();
        /* Enter main loop. */
        for (;;)
            if (!NRF_LOG_PROCESS())
                power_manage();
            cli_process();
            delete_all_process();
  • I'm not sure I understand what you mean. Is this the read/print you are referring to?
    printf("%d",data);
    It looks like you are printing a pointer, which does not make sense if you wanted to print the data.
