Few Questions on nRF9160: Thingy:91 and Dev Board
I have few question on nRF9160 Thingy:91 and Dev Board.
1.    From the schematic, I see that have used SP8T Switch from Antenna Feed pin (GPS and LTE) to the SIngle Antenna (Fractus).
When we initially turn on GPS and read the GPS Fix data(TTFF:30 seconds as per the data sheet) and Then switch off GPS section and Turn ON LTE and send the data.
If we turn on GPS again immediate after sending the GPS Fix data(meaning Turn off LTE and Turn ON GPS) Will it take again 30 seconds to get the GPS Fix data Or it'll be quicker?
2.   Is the LNA for GPS  required?
If we're using Separate external antenna for GPS and LTE CAT-M1/NB1 what's the use of Switch(U33 and U34) we can directly connect to the Antenna Feed point to the Module's GPS Feed point(with / Without LNA) right?
https://www.nordicsemi.com/-/media/Software-and-other-downloads/Dev-Kits/nRF9160-DK/pca10090_schematic_and_pcb_rev085.pdf
3. Could you please give me example of COEX2 (pin 91)?
4. Are there any limitation on Max duration of sleep mode on nRF9160?
5. May I know the Layer stack up details of Thingy:91?(Signal,GND,GND Signal OR Signal,GND,PWR,Signal?)
Thanks.
