Merging HEX file with Softdevice
I can't get the hex file to come out correctly in segger studio. What happens is, I build the solution and create the hex file but when I go to program my device with it.... well the device doesn't work correctly. I added an output file in the linker to create a hex file, I added the softdevice s140 in the loader, and I even used the command line tools to try and merge the created hex file with the softdevice.... but the device does not function when programmed in this way. I can get the device to work perfectly when using "Build and run" on SES but when I try to manually download a created HEX file nothing works.
Nick
