Zigbee reporting not work while using multiple endpoints
I just started to understand Zigbee and I had some problem. I created 3 endpoints. In one of them (endpoint counter_ep) I need a attribute reporting. A reporting works well only if this endpoint is the last in the list of macro parameters ZBOSS_DECLARE_DEVICE_CTX_3_EP or the only one in the macro ZBOSS_DECLARE_DEVICE_CTX_1_EP, otherwise reports will be unstable (for example, only 1 out of 10 reports will be received). Please tell me what could be the problem. I already found a similar problem on your forum, but the question has been deleted.
Thanks in advance.
I am using nrf52840 chip, SDK 4.0.0, router.
Coordinator: nrf52840, SDK 4.0.0, CLI example.
Examples:
counter_ep - endpoint with report.
Works:
ZBOSS_DECLARE_DEVICE_CTX_3_EP (counter_ctx, duty_ep, leds_ep, counter_ep);
or
ZBOSS_DECLARE_DEVICE_CTX_1_EP (counter_ctx, counter_ep);
Does not work:
ZBOSS_DECLARE_DEVICE_CTX_3_EP (counter_ctx, counter_ep, duty_ep, leds_ep);
or
ZBOSS_DECLARE_DEVICE_CTX_3_EP (counter_ctx, duty_ep counter_ep, leds_ep);
or
ZBOSS_DECLARE_DEVICE_CTX_2_EP (counter_ctx, counter_ep, leds_ep);
or
ZBOSS_DECLARE_DEVICE_CTX_2_EP (counter_ctx, counter_ep, duty_ep);
  • Hi
    This case should explain how you can detect and expose multiple Zigbee endpoints in your application.
    Simon
  • Thanks for the answer, but I think you do not understand me.
    I had no problems finding the endpoints on the device. When I worked through zigbee2mqtt(shepherd) all the endpoints were detected (see screenshot).
    My problem is that the reports do not work when on the router (not the coordinator) I declare CTX and change the order of the arguments in the parameters of the macro ZBOSS_DECLARE_DEVICE_CTX_3_EP (see the example in the first post).
  • Hi
    I'm sorry about the misunderstanding! When declaring the reporting context with ZBOSS_DECLARE_DEVICE the first argument should be the reporting context variable "reporting_info## device_ctx_name". This should be implemented correctly in the Multisensor example in the SDK.
    Simon
    Thanks for the answer. All my code is based on the example of a Multisensor. Yes, I know about ZBOSS_DECLARE_DEVICE (more precisely ZBOSS_DEVICE_DECLARE_REPORTING_CTX) and its parameters. I declared a new ZBOSS_DEVICE_DECLARE_REPORTING_CTX at each endpoint, following the example of the endpoint in the Multisensor, but gave each one a different name (otherwise it gives an error)(reporting_info## ep_name). It seemed to me logical. Example before:
    #include "zb_zcl_analog_input.h"
    #include "zb_zcl_multistate_value.h"
    #include "zb_zcl_binary_value.h"
    #include "zb_zcl_multistate_input.h"
    #define ZB_DEVICE_VER                        1
    /* COUNTER EndPoint */
    #define ZB_COUNTER_EP                        10                  /**< Device endpoint. */
    #define ZB_COUNTER_EP_REPORT_ATTR_COUNT      4                   /**< Number of attributes mandatory for reporting in cluster. */
    #define ZB_COUNTER_EP_IN_CLUSTER_NUM         4                   /**< Number of the input (server) clusters in the multisensor device. */
    #define ZB_COUNTER_EP_OUT_CLUSTER_NUM        0                   /**< Number of the output (client) clusters in the multisensor device. */
    /* DUTY EndPoint */
    #define ZB_DUTY_EP                           11                  /**< Device endpoint. */
    #define ZB_DUTY_EP_REPORT_ATTR_COUNT         2                   /**< Number of attributes mandatory for reporting in cluster. */
    #define ZB_DUTY_EP_IN_CLUSTER_NUM            3                   /**< Number of the input (server) clusters in the multisensor device. */
    #define ZB_DUTY_EP_OUT_CLUSTER_NUM           0                   /**< Number of the output (client) clusters in the multisensor device. */
    /* LEDS EndPoint */
    #define ZB_LEDS_EP                           12                  /**< Device endpoint. */
    #define ZB_LEDS_EP_REPORT_ATTR_COUNT         4                   /**< Number of attributes mandatory for reporting in cluster. */
    #define ZB_LEDS_EP_IN_CLUSTER_NUM            5                   /**< Number of the input (server) clusters in the multisensor device. */
    #define ZB_LEDS_EP_OUT_CLUSTER_NUM           0                   /**< Number of the output (client) clusters in the multisensor device. */
    #define ZB_LEDS_EP_LIGHT_CVC_ATTR_COUNT      1
    /* -------------------------------------------- COUNTER ENDPOINT DECLARE ---------------------------------------------------------- */
    /** @brief Declares endpoint for the COUNTER EndPoint.
     *  @param ep_name          Endpoint variable name.
     *  @param ep_id            Endpoint ID.
     *  @param cluster_list     Endpoint cluster list.
    #define ZB_DECLARE_COUNTER_EP(ep_name, ep_id, cluster_list)                           \
      ZB_DECLARE_COUNTER_DESC(ep_name,                                                    \
                              ep_id,                                                      \
                              ZB_COUNTER_EP_IN_CLUSTER_NUM,                               \
                              ZB_COUNTER_EP_OUT_CLUSTER_NUM);                             \
      ZBOSS_DEVICE_DECLARE_REPORTING_CTX(reporting_info## ep_name,                        \
                                         ZB_COUNTER_EP_REPORT_ATTR_COUNT);                \
      ZB_AF_DECLARE_ENDPOINT_DESC(ep_name,                                                \
                                  ep_id,                                                  \
                                  ZB_AF_HA_PROFILE_ID,                                    \
                                  0,                                                      \
                                  NULL,                                                   \
                                  ZB_ZCL_ARRAY_SIZE(cluster_list, zb_zcl_cluster_desc_t), \
                                  cluster_list,                                           \
                                  (zb_af_simple_desc_1_1_t*)&simple_desc_##ep_name,       \
                                  ZB_COUNTER_EP_REPORT_ATTR_COUNT,                        \
                                  0,                                                      \
                                  NULL)
    /* -------------------------------------------- DUTY ENDPOINT DECLARE ---------------------------------------------------------- */
    /** @brief Declares endpoint for the DUTY EndPoint.
    #define ZB_DECLARE_DUTY_EP(ep_name, ep_id, cluster_list)                              \
      ZB_DECLARE_DUTY_DESC(ep_name,                                                       \
                           ep_id,                                                         \
                           ZB_DUTY_EP_IN_CLUSTER_NUM,                                     \
                           ZB_DUTY_EP_OUT_CLUSTER_NUM);                                   \
                                         ZB_DUTY_EP_REPORT_ATTR_COUNT);                   \
                                  ep_id,                                                  \
                                  0,                                                      \
                                  NULL,                                                   \
                                  cluster_list,                                           \
                                  ZB_DUTY_EP_REPORT_ATTR_COUNT,                           \
                                  0,                                                      \
                                  NULL)                                                   \
    /* -------------------------------------------- LEDS ENDPOINT DECLARE ---------------------------------------------------------- */
      @brief Declare endpoint for Dimmable Light device
      @param ep_name - endpoint variable name
      @param ep_id - endpoint ID
      @param cluster_list - endpoint cluster list
    #define ZB_DECLARE_LEDS_EP(ep_name, ep_id, cluster_list)                              \
      ZB_DECLARE_LEDS_SIMPLE_DESC(ep_name, ep_id,                                         \
                                  ZB_LEDS_EP_IN_CLUSTER_NUM,                              \
                                  ZB_LEDS_EP_OUT_CLUSTER_NUM);                            \
                                         ZB_LEDS_EP_REPORT_ATTR_COUNT);                   \
      ZBOSS_DEVICE_DECLARE_LEVEL_CONTROL_CTX(cvc_alarm_info## device_ctx_name,            \
                                             ZB_LEDS_EP_LIGHT_CVC_ATTR_COUNT);            \
                                  ep_id,                                                  \
                                  0,                                                      \
                                  NULL,                                                   \
                                  cluster_list,                                           \
                                  ZB_LEDS_EP_REPORT_ATTR_COUNT,                           \
                                  ZB_LEDS_EP_LIGHT_CVC_ATTR_COUNT,                        \
                                  cvc_alarm_info## device_ctx_name)
    But now I got the idea that I need to call the macro ZBOSS_DEVICE_DECLARE_REPORTING_CTX (rep_ctx, rep_count) only at ONE endpoint (and specify the sum of all reporting attributes from all endpoints in rep_count), and in other declarations endpoints specify only the context name report (rep_ctx) in ZB_AF_DECLARE_ENDPOINT_DESC.
    In other words, the context (global variable zb_zcl_reporting_info_t rep_ctx[rep_count]) should be common to all endpoints? This is true?
    Examle now:
    /* DUTY EndPoint */
    /* LEDS EndPoint */
    /* ---------------------------------------------- DECLARE REPORTING CTX --------------------------------------- */
                              ep_id,                                                      \
      ZBOSS_DEVICE_DECLARE_REPORTING_CTX(reporting_info## device_ctx_name,                \
                                         ZB_COUNTER_EP_REPORT_ATTR_COUNT + ZB_DUTY_EP_REPORT_ATTR_COUNT + ZB_LEDS_EP_REPORT_ATTR_COUNT);  \
                                  ep_id,                                                  \
                                  0,                                                      \
                                  NULL,                                                   \
                                  cluster_list,                                           \
                                  ZB_COUNTER_EP_REPORT_ATTR_COUNT + ZB_DUTY_EP_REPORT_ATTR_COUNT + ZB_LEDS_EP_REPORT_ATTR_COUNT,        \
                                  0,                                                      \
                                  NULL)
    /* -------------------------------- NOT ZBOSS_DEVICE_DECLARE_REPORTING_CTX -------------------------------- */
                           ep_id,                                                         \
                                  ep_id,                                                  \
                                  0,                                                      \
                                  NULL,                                                   \
                                  cluster_list,                                           \
                                  0,                                                      \
                                  NULL)                                                   \
                                  ep_id,                                                  \
                                  0,                                                      \
                                  NULL,                                                   \
                                  cluster_list,                                           \
  • Hi
    I'm sorry that I haven't been able to give you a concise answer to your questions, but our Zigbee experts are out of office this week. In order to provide a satisfactory reply, I will have to wait for their return (Monday) to make sure we get it right.
    Sorry about the delay, and thank you for your patience!
    Simon
