Sensor is not communicating with nrf52840 via SCL p0.6 and SDA p0.08 lines.
Hi all,
Greeting of the day....
Here I am getting an issue with TWI interface. That I am using to communicate with sensor module with NRF52840.
The SCL------> p0.6
       SDA -----> p0.8
In the firmware part it is struck at the  nrf_drv_tx() call and return with time out error.
Please suggest me.
Basha
  • Which board are you using ? On the DK, it might be used for UART.  Make sure that those pins are not connected to something else.
  • If you are using a custom board, make sure you do not have NRF_LOG module enabled with UART backend, or that you do not enable any UART modules in your application.
    // <e> NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
    #ifndef NRF_LOG_BACKEND_UART_ENABLED
    #define NRF_LOG_BACKEND_UART_ENABLED 0 // Disable UART backend for logging
    // <o> NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin
    #ifndef NRF_LOG_BACKEND_UART_TX_PIN
    #define NRF_LOG_BACKEND_UART_TX_PIN 3 // Or change this pin to something else than the pin you want to use for TWI (P0.06 is default)
