In our application, we need the TCP/UDP socket keeps alive even when its receiving is timeout. so we changed the process code in do_tcp_receive() and do_udp_recvfrom() to below:
if (ret < 0) {
LOG_WRN("recv() error: %d", -errno);
//do_socket_close(-errno);
ret = -errno;
} else if (ret == 0) {
* When a stream socket peer has performed an orderly shutdown,
* the return value will be 0 (the traditional "end-of-file")
* The value 0 may also be returned if the requested number of
* bytes to receive from a stream socket was 0
* In both cases, treat as normal shutdown by remote
LOG_WRN("recv() return 0");
//do_socket_close(0);
} else {
After receive timeout(Log output: recv() error: -60), we found the next receive or send will be not available.
In this situation, how to continue to receive and send without closing and recreating the socket?
