MBR PARAMETER not installed when i flash SD+BOOT+APP
For my project, firstly i erase all the user program, and then I install succesively the softdevice (s132 v6.1.0), the bootloader and my application software with nrfjprog.
This work well, but with one of my device, neither the bootloader or the application has started.
After investigation, i observe with nrf connect that the MBR parameter is not set with the device impacted.
                                         Device OK        Device not OK
So my question is why the MBR Parameter is not set automatically ?
    The bootloader configures the MBR param and bootloader settings pages on the first boot. So the fact that both pages are empty indicates that the bootloader has not been run for some reason. Were you able to get this particular device to work if you reflash it? If not, try to run "nrfjprog --readregs" and see if it is stuck at a certain address (see PC register value). Also, please include the --verify argument when programming to make sure the image is loaded correctly.
    eg.,
    nrfjprog --program <>.hex --chiperase --verify -r
    The device doesn't work even if if i reflash it. The verify argument is always used when i program the device.
    Si I run "nrfjprog --readregs" and i have the following result with the impacted device :
    R0:   0x0000C277
    R1:   0x00000000
    R2:   0x0007A0B0
    R3:   0x20009BD4
    R4:   0x00000021
    R5:   0x0007A0A1
    R6:   0x0007A0A0
    R7:   0x0000FA00
    R8:   0x00000000
    R9:   0x00000000
    R10:  0x00000000
    R11:  0x00000000
    R12:  0x40000614
    SP:   0x20009BE8
    LR:   0x00075C15
    PC:   0x0007A0A0
    xPSR: 0x21000000
    MSP:  0x20009BE8
    PSP:  0x00000000
    To compare i send the same commande with an other device, and we have this result :
    R0:   0x01000001
    R1:   0x40020518
    R2:   0x00000001
    R3:   0x00000000
    R4:   0x200000C0
    R5:   0x00000000
    R6:   0xE000E000
    R7:   0x0000006F
    R8:   0xA5A5A5A5
    R9:   0xA5A5A5A5
    R10:  0xA5A5A5A5
    R11:  0xA5A5A5A5
    R12:  0xA5A5A5A5
    SP:   0x2000B5C8
    LR:   0x00015C7D
    PC:   0x00015C7E
    xPSR: 0x61000000
    MSP:  0x2000DAF8
    PSP:  0x2000B5C8
    I don't find the documentation to understand clearly the different field.
  • The program counter (PC) value is what's the most interesting here. The first one shows that the CPU is executing code at address 0x7A0A0 so it appears to get stuck in the bootloader code. Have you tried to debug the bootloader/application on this board? And are you able to look up what code/function you have at this address?
  • I debug my bootloader on this board. And it's my function nrf_twi_mngr_perform() who return me NRF_ERROR_INTERNAL who block the bootloader. I don't know why, it's the first time i see this nrf error
  • Ok, so it's using TWI. Do you have test points, etc to verify voltage levels and see if data is being transferred on the bus lines?
