Windows Command line DFU over BLE with PCA10059 problem
To the kind attention of Nordic support team,
I'm trying to do things like in https://devzone.nordicsemi.com/f/nordic-q-a/39630/windows-command-line-dfu-over-ble-with-pca10059 thread.
Even when not putting the -f option I'm having this report:
2020-02-26 17:42:44,231 Using connectivity board at serial port: COM6
2020-02-26 17:42:44,239 Sending Application image.
2020-02-26 17:42:47,676 Successfully opened COM6. Baud rate: 1000000. Flow control: none. Parity: none.
2020-02-26 17:42:47,677 evt> severity(20) message(Successfully opened COM6. Baud rate: 1000000. Flow control: none. Parity: none.)
2020-02-26 17:42:47,678 RpcAppStatus.resetPerformed: Target Reset performed
2020-02-26 17:42:47,678 evt> status code(RpcAppStatus.resetPerformed) message(Target Reset performed)
2020-02-26 17:42:48,884 RpcAppStatus.connectionActive: Connection active
2020-02-26 17:42:48,884 evt> status code(RpcAppStatus.connectionActive) message(Connection active)
File "C:\Users\astella\AppData\Local\Programs\Python\Python38\Scripts\nrfutil-script.py", line 11, in <module>
2020-02-26 17:42:50,388 Failed to receive response for command
load_entry_point('nrfutil==6.0.1', 'console_scripts', 'nrfutil')()
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 764, in __call__
2020-02-26 17:42:50,391 evt> severity(30) message(Failed to receive response for command)
return self.main(*args, **kwargs)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 717, in main
2020-02-26 17:42:50,392 RpcAppStatus.pktSendError: Error sending packet to target. Code: 0x8016
2020-02-26 17:42:50,393 evt> status code(RpcAppStatus.pktSendError) message(Error sending packet to target. Code: 0x8016)
rv = self.invoke(ctx)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 1137, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 555, in invoke
return callback(*args, **kwargs)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\__main__.py", line 1144, in ble
dfu.dfu_send_images()
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
self._dfu_send_image(self.manifest.application)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu.py", line 88, in _dfu_send_image
self.dfu_transport.open()
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu_transport_ble.py", line 473, in open
self.dfu_adapter.open()
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu_transport_ble.py", line 119, in open
self.adapter.driver.ble_cfg_set(
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\wrapt\wrappers.py", line 606, in __call__
return self._self_wrapper(self.__wrapped__, self._self_instance,
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 103, in wrapper
raise NordicSemiException(
pc_ble_driver_py.exceptions.NordicSemiException: Failed to ble_cfg_set. Error code: NRF_ERROR_SD_RPC_SEND
When I'm putting the -f option:
nrfutil -vvvv dfu ble -ic NRF52 -pkg app26022020.zip -p COM6 -n "DfuTarg" -f
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 2732, in __init__
snr = [d.serial_number for d in serial_ports if d.port == serial_port][0]
IndexError: list index out of range
During handling of the above exception, another exception occurred:
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\__main__.py", line 1120, in ble
flasher = Flasher(serial_port=port, snr = jlink_snr)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 2734, in __init__
raise NordicSemiException("Board not found: {}".format(serial_port or snr))
pc_ble_driver_py.exceptions.NordicSemiException: Board not found: COM6
In device manager I see nRF Connect USB CDC ACM (COM6), even switching off nRFConnect,plugging in and out PCA10059
I'm using nrfutil 6.0.1 version. and sdk15.2.
Thank you for your help
