Timeslots and SOFTDEVICE: ASSERTION FAILED, PCxxx: 0x2552e
Hello
in our concurrent radio application using timeslot API there are failed assertions from time to time (10min - 10h).
Message is as above.
Stacktrace and system state shows clearly that the failed assertion happens during sd_radio_request().  Parameters are:
Details:{request_type = 1 '\001', params = {earliest = {hfclk = 1 '\001', priority = 0 '\0', length_us = 69977, timeout_us = 55000}, normal = {hfclk = 1 '\001', priority = 0 '\0', distance_us = 69977, length_us = 55000}}}
So my question is: what does this address means?  Is there any list of failed assertion addresses with their meanings?
Ah, yes: it happens with SD 6.1.0.  With 6.1.1 one gets the same(?) assertion with a slightly different address.
And no: assigned timeslots were not exceeded.
Thanks & regards
Hardy
  • As far as I know your timeslot code runs at highest priority (0) and you are not allowed to call any SVC functions from inside. sd_radio_request would translate to an SVC call which has lower priority than the context you call it in and on ARM Cortex M4 that would cause a hardfault. If you want to reschedule another timeslot that is not the way to do it.
  • Sorry, I did not write, that the sd_radio_request() happens during the callback.
    The above readout is done post-mortem with the debugger.
    sd_radio_request()s are done in NRF_EQU0 context which has an assigned prio of 7.
  • can you please provide us with the proper call stack to understand context properly.
    I do not see any instruction address for the fault in your question. If this is an assert, which address caused this?
    Combined with call stack info and assert instruction address, we should be able understand the nature of the fault.
  • The assertion happens inside the softdevice (0x2552e, see subject).  That's why I'm asking you what the actual cause of this (failed) assertion could be.
    From internal states and the call stack, I can assure you that the assertion happens during sd_radio_request().
    Call stack, if this is of any help (S140 6.1.0):
    0xb0af2
    0x2003a5d0
    0x53f39: __assert_func at errorhandler.c:175:0
    0xa4f4f
    0x20009772
    0x20008f2c
    0x20000acc
    0x0
    0x0
    0x0
    0x20000acc
    0x0
    0x2552e
    0x1
    0x200001cc
    0x20005258
    0x254e7
    0x24add
    0x0
    0x1ee9c4
    0x1eec9f
    0x1e0300fd
    0x47a69
    0x1524d
    0x25530
    0x6100000b
    0x2003a620
    0x1000001
    0x20005258
    0x24211
    0x2000b3f8
    0x2003ec08
    0x2003de0c
    0x2003a668
    0x2003addc
    0xfffffff1
    0x20005258
    0x20005210
    0x1f1bff
    0x2
    0x47a69
    0x46e89: _SlotRequest at TimeslotControl.c:603:26                -> line 603 does sd_radio_request()
    0x9d506
    0x1000024
    0x0
    0x1f1bfe
    0x20005264
    0x2000ba07
    0x1f
    0x4268
    0x0
    0x0
    0x2000b3f8
    0x2003de0c
    0x2003a7d8
    0x475e3: TimeSlotControl_Request at TimeslotControl.c:721:8     -> line 721 does _SlotRequest()
  • sorry, I missed to see the address.
    i checked S140 v6.1.0 at 0x2552E and it does not look like there is code there. It looks like that is reserved space for data. If you see that this is your assert address in the fault handler, then it could be because of the stack corruption which does not show correct faulting address
