Power Management Clarification
I want to test the power managment on the nRF52840. I plan to make a  simple test application that enter in sleep/systemoff mode every, let's say, 1 minute. After wake up it'll performs some simple tasks and then enter again in sleep/systemoff mode, and so on.
I can use the "pwr_mgmt" example in the SDK as a start, but I'll need to add a timer.
I read the power section in the datasheet, and the power management library documentation but I have some doubts:
1.- On system off, all the device will shutdown, including the timer, so , I can't enter in this mode because the timer won't be able to wake up the device. Am I right?.
2.- If the question above is right, how can I go to sleep mode (or an equivalent mode)? Using the "nrf_pwr_mgmt_run" function will do the job?
3.- Is there another  mode to save power in this type of application, that needs a timer to wake up the system?
Best regards
José Forno
