I have some code which is based on the ble_app_gatts_c example sdk 15. I am using a Nordic NRF52840-dk pca10056 s140. Coding in Segger.
I want to each second change the live data advertisement that is being transmitted from the Nordic board. I have this code working without a Gatt connection but, want to merge the two projects together.
I have live data coming in each second via a UART connection containing sensor data which I then need to advertise.
However, when I create a loop in the main containing the advertisement mod (custom function) I makes a infinite loop for advertisement being stopped and, no advert appears.
My understanding to update and advert is as follows:
- Encode new data my case manufacturer data with sensor values in it
- Stop advertising
- Configure the data to the advert
- Restart the advert
This is how it works in my code that is not connectable.
My code runs a advertising_init then starts the advert then goes into the main loop where, the advert is to be updated but, crashes upon attempt to restart.
Below is my code with the problem.
void advertising_init() { ret_code_t err_code; ble_advertising_init_t init; ble_advdata_manuf_data_t manuf_specific_data; memset(&init, 0, sizeof(init)); //Manufacturer data ble_advdata_manuf_data_t manuf_data; //Variable to hold manufacturer specific data manuf_data.company_identifier = 0x0487; //Centricas company ID manuf_data.data.p_data = m_beacon_info; manuf_data.data.size = 15;//Was 11 init.advdata.p_manuf_specific_data = &manuf_data; init.advdata.name_type = BLE_ADVDATA_FULL_NAME; init.advdata.include_appearance = true; init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; init.config.ble_adv_fast_enabled = true; init.config.ble_adv_fast_interval = ADV_INTERVAL; init.config.ble_adv_fast_timeout = APP_ADV_DURATION; init.evt_handler = on_adv_evt; err_code = ble_advertising_init(&m_advertising, &init); APP_ERROR_CHECK(err_code); ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG); err_code = ble_advertising_restart_without_whitelist(&m_advertising); APP_ERROR_CHECK(err_code); } //Mod code static void advertising_mod(int count, int T1_value,int T2_value, int T3_value,int T4_value, float Pdiff_value) { ret_code_t err_code; ble_advdata_t advdata; ble_advdata_manuf_data_t manuf_data; ble_advertising_init_t init; int pdiff_value_1 = 0; int pdiff_value_2 = 0; int pdiff_value_3 = 0; float pressure_to_convert = 0; int value_of_pressure_data = 0; int t1_value_1 = (T1_value >>8) & 0XFF;//MSB shifting int t1_value_2 = T1_value & 0XFF;//LSB int t2_value_1 = (T2_value >> 8) & 0XFF;//MSB int t2_value_2 = T2_value & 0XFF;//LSB int t3_value_1 = (T3_value >> 8) & 0XFF;//MSB int t3_value_2 = T3_value & 0XFF;//LSB int t4_value_1 = (T4_value >> 8) & 0XFF;//MSB int t4_value_2 = T4_value & 0XFF;//LSB //Handling the pressure value if(Pdiff_value < 0)//Result is less than 0 { pdiff_value_1 = 0;//For a negative number aka negative pressure pressure_to_convert = -Pdiff_value;//Make a positive value pressure_to_convert = pressure_to_convert*100; } else { pdiff_value_1 = 1;//For a positive pressure pressure_to_convert = Pdiff_value;//Keep a positive value pressure_to_convert = pressure_to_convert*100; } value_of_pressure_data = (int)pressure_to_convert;//Convert to an int pdiff_value_2 = (value_of_pressure_data >> 8) & 0XFF; pdiff_value_3 = (value_of_pressure_data & 0xFF);//LSB ble_advdata_manuf_data_t manuf_specific_data; m_beacon_info[0]= (unsigned char) count; m_beacon_info[1]= (unsigned char) t1_value_1; m_beacon_info[2]= (unsigned char) t1_value_2; m_beacon_info[3]= (unsigned char) t2_value_1; m_beacon_info[4]= (unsigned char) t2_value_2; m_beacon_info[5]= (unsigned char) t3_value_1; m_beacon_info[6]= (unsigned char) t3_value_2; m_beacon_info[7]= (unsigned char) t4_value_1; m_beacon_info[8]= (unsigned char) t4_value_2; m_beacon_info[9]= (unsigned char) pdiff_value_1;//Was sign bit m_beacon_info[10]=(unsigned char) pdiff_value_2; m_beacon_info[11]=(unsigned char) pdiff_value_3; m_beacon_info[12]=(unsigned char) SD_CARD_PRESENT; // Build and set advertising data memset(&advdata, 0, sizeof(advdata)); //Manufacturer data manuf_data.company_identifier = 0x0487; //Centricas company ID manuf_data.data.p_data = m_beacon_info; manuf_data.data.size = 15;//Was 11 advdata.p_manuf_specific_data = &manuf_data; advdata.name_type = BLE_ADVDATA_FULL_NAME; advdata.include_appearance = true; advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; memset(&init, 0, sizeof(init)); //Manufacturer data manuf_data.company_identifier = 0x0487; //Centricas company ID manuf_data.data.p_data = m_beacon_info; manuf_data.data.size = 15;//Was 11 init.advdata.p_manuf_specific_data = &manuf_data; init.advdata.name_type = BLE_ADVDATA_FULL_NAME; init.advdata.include_appearance = true; init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; init.config.ble_adv_fast_enabled = true; init.config.ble_adv_fast_interval = ADV_INTERVAL; init.config.ble_adv_fast_timeout = APP_ADV_DURATION; init.evt_handler = on_adv_evt; ble_advertising_encode(&m_advertising, &init);//Encode the data ble_advertising_stop(&m_advertising);//Custom stop function ble_advertising_configure(&m_advertising, &init);//Configure the data err_code =ble_advertising_start_mod(&m_advertising);//Custom start function APP_ERROR_CHECK(err_code); }
This code is the modify code for my other application which works however the init and mod are slightly different.
Please could you explain where I am going wrong thanks
static void advertising_init(void) { ret_code_t err_code; ble_advdata_t advdata; ble_advdata_manuf_data_t manuf_data; uint8_t flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE; APP_ERROR_CHECK_BOOL(sizeof(flags) == ADV_FLAGS_LEN); // Assert that these two values of the same. // Build and set advertising data memset(&advdata, 0, sizeof(advdata)); manuf_data.company_identifier = COMPANY_IDENTIFIER; manuf_data.data.size = APP_BEACON_INFO_LENGTH; manuf_data.data.p_data = (uint8_t *) m_beacon_info; advdata.flags = flags; advdata.p_manuf_specific_data = &manuf_data; err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len); APP_ERROR_CHECK(err_code); if(m_is_non_connectable_mode) { err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, NULL, &m_adv_params); APP_ERROR_CHECK(err_code); } else { err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params); APP_ERROR_CHECK(err_code); } } static void advertising_mod(int count, int T1_value,int T2_value, int T3_value,int T4_value, float Pdiff_value) { uint32_t err_code; ble_advdata_t advdata; uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED; int pdiff_value_1 = 0; int pdiff_value_2 = 0; int pdiff_value_3 = 0; float pressure_to_convert = 0; int value_of_pressure_data = 0; int t1_value_1 = (T1_value >>8) & 0XFF;//MSB shifting int t1_value_2 = T1_value & 0XFF;//LSB int t2_value_1 = (T2_value >> 8) & 0XFF;//MSB int t2_value_2 = T2_value & 0XFF;//LSB int t3_value_1 = (T3_value >> 8) & 0XFF;//MSB int t3_value_2 = T3_value & 0XFF;//LSB int t4_value_1 = (T4_value >> 8) & 0XFF;//MSB int t4_value_2 = T4_value & 0XFF;//LSB //Handling the pressure value if(Pdiff_value < 0)//Result is less than 0 { pdiff_value_1 = 0;//For a negative number aka negative pressure pressure_to_convert = -Pdiff_value;//Make a positive value pressure_to_convert = pressure_to_convert*100; } else { pdiff_value_1 = 1;//For a positive pressure pressure_to_convert = Pdiff_value;//Keep a positive value pressure_to_convert = pressure_to_convert*100; } value_of_pressure_data = (int)pressure_to_convert;//Convert to an int pdiff_value_2 = (value_of_pressure_data >> 8) & 0XFF; pdiff_value_3 = (value_of_pressure_data & 0xFF);//LSB int Time_stamp_id_value_1 = (Time_stamp_id >> 24) & 0XFF;//MSB int Time_stamp_id_value_2 = (Time_stamp_id >> 16) & 0XFF;//MSB int Time_stamp_id_value_3 = (Time_stamp_id >> 8) & 0XFF;//MSB int Time_stamp_id_value_4 = (Time_stamp_id) & 0XFF;//MSB ble_advdata_manuf_data_t manuf_specific_data; m_beacon_info[0]= (unsigned char) count; m_beacon_info[1]= (unsigned char) t1_value_1; m_beacon_info[2]= (unsigned char) t1_value_2; m_beacon_info[3]= (unsigned char) t2_value_1; m_beacon_info[4]= (unsigned char) t2_value_2; m_beacon_info[5]= (unsigned char) t3_value_1; m_beacon_info[6]= (unsigned char) t3_value_2; m_beacon_info[7]= (unsigned char) t4_value_1; m_beacon_info[8]= (unsigned char) t4_value_2; m_beacon_info[9]= (unsigned char) pdiff_value_1;//Was sign bit m_beacon_info[10]=(unsigned char) pdiff_value_2; m_beacon_info[11]=(unsigned char) pdiff_value_3; m_beacon_info[12]=(unsigned char) SD_CARD_PRESENT; m_beacon_info[13]=(unsigned char) Time_stamp_id_value_1; m_beacon_info[14]=(unsigned char) Time_stamp_id_value_2; m_beacon_info[15]=(unsigned char) Time_stamp_id_value_3; m_beacon_info[16]=(unsigned char) Time_stamp_id_value_4; //SD_CARD_PRESENT manuf_specific_data.company_identifier = COMPANY_IDENTIFIER; manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info; manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH; // Build and set advertising data. memset(&advdata, 0, sizeof(advdata)); advdata.name_type = BLE_ADVDATA_NO_NAME; advdata.flags = flags; advdata.p_manuf_specific_data = &manuf_specific_data; // Initialize advertising parameters (used when starting advertising). memset(&m_adv_params, 0, sizeof(m_adv_params)); m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED; m_adv_params.p_peer_addr = NULL; // Undirected advertisement. m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY; m_adv_params.interval = CONNECTABLE_ADV_INTERVAL; m_adv_params.duration = APP_ADV_DURATION; // 30 Second adverts m_adv_params.primary_phy = BLE_GAP_PHY_1MBPS; err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len); APP_ERROR_CHECK(err_code); err_code = sd_ble_gap_adv_stop(m_adv_handle); APP_ERROR_CHECK(err_code); err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params); APP_ERROR_CHECK(err_code); err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG); APP_ERROR_CHECK(err_code); }
