build connectivity firmware softdevice dfu packet for secured usb bootloader
To the kind attention of Nordic support team,
using these commands, like in https://devzone.nordicsemi.com/f/nordic-q-a/58365/doing-dfu-ble-as-a-pca10059-dongle,
I flashed PCA10056 DK with usb open bootloader coming from sdk15.2
Then I used  C:\Users\astella\AppData\Local\Programs\Python\Python38\Lib\site-packages\pc_ble_driver_py\hex\sd_api_v5
connectivity_4.1.1_usb_with_s132_5.1.0_dfu_pkg.zip
Using this dfu file, I was able to program PCA10056:
nrfutil dfu usb-serial -pkg connectivity_4.1.1_usb_with_s132_5.1.0_dfu_pkg.zip -p COM13
After that, connectivity firmware was running properly and I was able to do ota updating in a second board
using this command:
nrfutil dfu ble -ic NRF52 -pkg app26022020.zip -p COM12 -n "DfuTarg"
[####################################] 100%
Device programmed.
So, I managed to have a first idea of what it is needed to get what I need.
I noticed that after a reset, the default openbootloader from sdk15.2 seems to activate itself and connectivity firmware doesn't run anymore.
But, I'd like to signature my dfu package. Is there a way to get a dfu package that is working with secured usb bootloader?
I tried to do something like this:
nrfutil pkg generate --sd-req 0x0 --sd-id 0x0 --hw-version 52 --key-file private.key --application-version 1 --application connectivity_4.1.1_usb_for_s132_5.1.0.hex --softdevice s132_nrf52_5.1.0_softdevice.hex dfu.zip
Zip created at dfu.zip
But after programming PCA10056, connectivity firmware wasn't running.
To me it is important to understand if it is possible to find a way to work with default connectivity files (as it seems to be the case in the open bootloader case) as they are provided in
C:\Users\astella\AppData\Local\Programs\Python\Python38\Lib\site-packages\pc_ble_driver_py\hex\sd_api_v5 or I need to deeply work with src files to rebuild them.
Thank you for your valuable work and attention
Best regards
