Reading external sensor using I2C on nrf9160dk
I want to read external accelerometer on nrf9160dk using I2C. But when I connect SDA and SCL pins of sensor to nrf91, there is no output.
The Code is:
#include <nrf9160.h>
#include <zephyr.h>
#include <misc/printk.h>
#include <i2c.h>
#include <string.h>
#include <stdlib.h>
#include <math.h>
#define I2C_ACCEL_READ_ADDR   60
struct device * i2c_accel;
u8_t I2C_BUFFER[35];
void init_accelerometer(){
    i2c_accel = device_get_binding("I2C_2");
    if (!i2c_accel) {
		printk("error\r\n");
    i2c_configure(i2c_accel, I2C_SPEED_SET(I2C_SPEED_FAST));
void main(void)
        printk("Start I2C comminication\r\n");
        init_accelerometer();
	while (1) {
                i2c_read(i2c_accel, I2C_BUFFER, 29, I2C_ACCEL_READ_ADDR);
                printk("I2C_BUFFER = %s\n", I2C_BUFFER);
When I don't connect sensor to nrf91, then continuously it prints "I2C_BUFFER ="
When I connect the sensor, everything stops and when I again remove the pins it prints "I2C_BUFFER ="
What I am doing wrong? How to read these sensors value?
Thank you
    Here is some code that you can test to see if you get a response from the sensor. If there is an ACK for the address, it prints the address it found.
    main.c
    #include <zephyr.h>
    #include <i2c.h>
    #include <string.h>
    #include <stdlib.h>
    #include <math.h>
    #include <gpio.h>
    #define I2C_ACCEL_WRITE_ADDR 0x32
    #define I2C_ACCEL_READ_ADDR 0x75
    uint8_t WhoAmI = 0u;
    static struct device  *led_port;
    #ifdef CONFIG_SOC_NRF9160
    #define I2C_DEV "I2C_3"
    #else
    #define I2C_DEV "I2C_1"
    void main(void)
    	struct device *i2c_dev;
    	k_sleep(500);
    	printk("Starting i2c scanner...\n");
    	i2c_dev = device_get_binding(I2C_DEV);
    	if (!i2c_dev) {
    		printk("I2C: Device driver not found.\n");
    		return;
    	uint8_t error = 0u;
    	i2c_configure(i2c_dev, I2C_SPEED_SET(I2C_SPEED_STANDARD));
    	printk("Value of NRF_TWIM3_NS->PSEL.SCL: %ld \n",NRF_TWIM3_NS->PSEL.SCL);
    	printk("Value of NRF_TWIM3_NS->PSEL.SDA: %ld \n",NRF_TWIM3_NS->PSEL.SDA);
    	printk("Value of NRF_TWIM3_NS->FREQUENCY: %ld \n",NRF_TWIM3_NS->FREQUENCY);
    	printk("26738688 -> 100k\n");
    	for (u8_t i = 4; i <= 0x77; i++) {
    		struct i2c_msg msgs[1];
    		u8_t dst = 1;
    		/* Send the address to read from */
    		msgs[0].buf = &dst;
    		msgs[0].len = 1U;
    		msgs[0].flags = I2C_MSG_WRITE | I2C_MSG_STOP;
    		error = i2c_transfer(i2c_dev, &msgs[0], 1, i);
    		if (error == 0) {
    			printk("0x%2x FOUND\n", i);
    		else {
    			//printk("error %d \n", error);
    nrf9160_pca10090ns.overlay
    &i2c3 {
    	status = "ok";
    	sda-pin = < 12 >;
    	scl-pin = < 11 >;
        clock-frequency = <I2C_BITRATE_STANDARD>;
    prj.conf
    #CONFIG_SERIAL=y
    #CONFIG_UART_INTERRUPT_DRIVEN=y
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_3=y
    CONFIG_I2C_3_NRF_TWIM=y
    CONFIG_NEWLIB_LIBC=y
    #CONFIG_LOG=y
    #CONFIG_I2C_LOG_LEVEL_DBG=y
    #CONFIG_LOG_BACKEND_UART=y
    #CONFIG_I2C_INIT_PRIORITY=60
    I  compile and debug the above code. Also, I edited the "prj.conf" file, but the I couldn't find the ".overlay" file to edit. Then I Debug the program. But it stopped at,
                                                               line 38:  printk("I2C: Device driver not found.\n");
    Here, I have not connected any I2C compatible sensor  with nRf9160 dk board.
    Does this code print the address if only I2C sensor connected ?
    Can you help me solve this issue.
    Thank You.
