#define configTICK_SOURCE FREERTOS_USE_RTC #define configCPU_CLOCK_HZ ( SystemCoreClock ) #define configTICK_RATE_HZ 1024
Hi ,
in the RTOS example, you set
configTICK_SOURCE as FREERTOS_USE_RTC and configCPU_CLOCK_HZ as( SystemCoreClock ) .Since SystemCoreClock is 64mhz, why did you not set configCPU_CLOCK_HZ as 32768? As I can see in port files everything designed for LF clock, so is configCPU_CLOCK_HZ just useless?
