UART Streaming from central to peripheral
I need to stream data from NUS UART Central Device to one peripheral, but the device always disconnects while trying to send second set of data. So I changed the write_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_CMD to BLE_GATT_OP_WRITE_REQ, and used "BLE_GATTC_EVT_WRITE_RSP" inside ble_nus_c_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context). After getting write response, the central sends next set of data.
But this also didn't work well, the nus_c_send_string() returns NRF_ERROR_INVALID_LENGTH.
I am using nRF52DK and nRF5_SDK_16.0.0_98a08e2\examples\ble_peripheral\ble_app_uart, and central device example, and sending 200 bytes of data at a time.
How can I continuously stream data from central to peripheral? (peripheral to central seems OK, where I used  BLE_NUS_EVT_TX_RDY to check peripheral ready to send next data set.
I changed back to BLE_GATT_OP_WRITE_CMD, this time the segger log shows (May not be resulted from nus_c_send_string call, because on this error the APP_ERROR_CHECK is not called)
nrf_ble_gq: SD GATT procedure (1) failed on connection handle 0 with error: 0x00000013.
In short the question is how I can safely send the next set of data or payload.
