combining central and peripheral
my application is normally a BLE scanner, listening for beacons. This runs OK.
Now, I tried to add a tested piece of connectable gap/gatt firmware, that runs fine in another application. The idea is to have the processor check a pushbutton at power-up. Normally the processor will call "sd_ble_gap_scan_start" to begin scanning, but if the button is pressed it calls the standard gap/gatt initialisation to start advertising:
  flash_timer_init();
  observer_init();
  gap_params_init();
  gatt_init();
  services_init();
  advertising_init();
  conn_params_init();
  peer_manager_init();
As I mentioned, this gap/gatt software works fine in another application, but here it crashes at the first call to "sd_ble_uuid_vs_add" with error_code 203995, which does not tell me how to fix it.
Is there possibly a conflict between central and peripheral, or a config setting that needs changing?
thx,
Henk
    203995 does not seem like an expected error code from sd_ble_uuid_vs_add, are you sure this is the correct error code?
    Have you changed the sdk_config.h file (NRF_SDH_BLE_VS_UUID_COUNT) and project memory config to allow space for the vendor-specific UUID?
    Which SDK version are you using? Can you upload your project for us to reproduce and debug the error?
    Jørgen
  • Hi Jorgen,
    thanks for your support.
    The actual error code seems to change with software modifications, but is always high. Here is a recent one:
    <error> app: ERROR 203971 [Unknown error code] at C:\Nordic\nRF5_SDK_16.0.0_98a08e2\531904\src-eml-ble\rev000\EBTgap.c:278
    PC at: 0x00031B11
    <error> app: End of error report
    The code from line 275 onwards is:
      char_uuid.uuid = cstm_uuid;
      ces_handles.ces_short_uuid[char_no] = cstm_uuid; // for quick look-up of handle
      sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
    I copied the config settings from the app with the original gap/gatt firmware:
    #define NRF_SDH_BLE_ENABLED 1
    #define NRF_SDH_BLE_GAP_DATA_LENGTH 27
    #define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 1
    #define NRF_SDH_BLE_CENTRAL_LINK_COUNT 1
    #define NRF_SDH_BLE_TOTAL_LINK_COUNT 1
    #define NRF_SDH_BLE_GAP_EVENT_LENGTH 800
    #define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 583
    #define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 5128
    #define NRF_SDH_BLE_VS_UUID_COUNT 1
    #define NRF_SDH_BLE_SERVICE_CHANGED 0
    The project is fairly large, with a uart interface to wirepas where proprietory data is transferred. I cannot share that part, but if needed, I can make a reduced version with just the scanner and the gap/gatt parts for you to examine. For now, the complete config file is uploaded to  sdk_config.h
    thx, Henk
  • From the code you posted, it looks like you are not assigning the error code to the err_code variable. What you are seeing is most likely garbage from RAM. Please change your code to this:
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
  • Hi Jorgen,
    I can't believe I missed that, shame on me ;-)
    Thanks for your support,
    Henk
