I want to change vdd to 3.3v , but when I use the code showed in picture, it remain error
Is the chip fully erased before this code is run? Also, what is the problem you are experiencing? Is it that it fails to build or update the register setting?
It fails to build , so I need to erase all the chip first?
Thanks for confirming. Unfortunately, it won't help to erase the chip as this is a build error. What is the error you get?
NRF_NVMC->CONFIG should already be accessed in your startup file (system_nRFxx.c) to enable PINRESET. Are those routines being compiled without errors?
