mesh_config_entry_get()/mesh_config_entry_set() are not working as expected
Hi all,
I am developing on nRF Mesh SDK 4.0.0 with nRF52833 DK (PCA10100).
To save/restore persistent model state to flash, I added the code using mesh_config_entry_get()/mesh_config_set() functions as below.
1. I added mesh_config_entry_get() in model initialization function.
   It will fail if there is no entry in flash, but after saved once, it can read it afterwards.
2. I also added mesh_config_entry_set() function in model set callback.
    When I send a set message, log shows that this function call is successful, i.e. returns NRF_SUCCESS.
But, when I power cycled the board, it still cannot get the entry and mesh_config_get() always failed.
What is wrong/missing in my code? Can somebody advice about?
TIA.
  • Hi Choe,
    Could you let me know how you define your config ID , have you followed what we did, for example in mesh_opt_provisioner.h in the light switch provisioner example ?
    You need to define config file using MESH_CONFIG_FILE().
    Please note that you can store your data using the flash library directly by creating your own flash area outside of the mesh config area. You can call this: mesh_stack_persistence_flash_usage() to know the mesh stack flash usage and allocate your own flash area outside of the mesh stack.
  • I followed the emocean example.
    Below is my code for declaring & getting entries.
    #define LOCATION_FILE_ID                (0x0010)
    #define GLOBAL_LOCATION_RECORD          (0x0001)
    #define LOCAL_LOCATION_RECORD           (0x0002)
    #define GLOBAL_LOCATION_ENTRY_ID        MESH_CONFIG_ENTRY_ID(LOCATION_FILE_ID, GLOBAL_LOCATION_RECORD)
    #define LOCAL_LOCATION_ENTRY_ID         MESH_CONFIG_ENTRY_ID(LOCATION_FILE_ID, LOCAL_LOCATION_RECORD)
    MESH_CONFIG_FILE(m_location_file, LOCATION_FILE_ID, MESH_CONFIG_STRATEGY_CONTINUOUS);
    static uint32_t global_location_setter(mesh_config_entry_id_t id, const void * p_entry);
    static void global_location_getter(mesh_config_entry_id_t id, void * p_entry);
    static void global_location_deleter(mesh_config_entry_id_t id);
    static uint32_t local_location_setter(mesh_config_entry_id_t id, const void * p_entry);
    static void local_location_getter(mesh_config_entry_id_t id, void * p_entry);
    static void local_location_deleter(mesh_config_entry_id_t id);
    MESH_CONFIG_ENTRY(global_location,
                      GLOBAL_LOCATION_ENTRY_ID,
                      1,
                      sizeof(generic_location_global_status_params_t),
                      global_location_setter,
                      global_location_getter,
                      global_location_deleter,
                      false);
    MESH_CONFIG_ENTRY(local_location,
                      LOCAL_LOCATION_ENTRY_ID,
                      1,
                      sizeof(generic_location_local_status_params_t),
                      local_location_setter,
                      local_location_getter,
                      local_location_deleter,
                      false);
    static generic_location_global_status_params_t m_location_global =
        .global_latitude = 0x80000000,
        .global_longitude = 0x80000000,
        .global_altitude = 0x7FFF,
    static generic_location_local_status_params_t m_location_local =
        .local_north = 0x8000,
        .local_east = 0x8000,
        .local_altitude = 0x7FFF,
        .floor_number = 0xFF,
        .uncertainty = 0x0000,
        return NRF_SUCCESS;
        m_location_global.global_latitude = 0x80000000;
        m_location_global.global_longitude = 0x80000000;
        m_location_global.global_altitude = 0x7FFF;
        return NRF_SUCCESS;
        m_location_local.local_north = 0x8000;
        m_location_local.local_east = 0x8000;
        m_location_local.local_altitude = 0x7FFF;
        m_location_local.floor_number = 0xFF;
        m_location_local.uncertainty = 0x0000;
    static void model_config_load(void)
        mesh_config_entry_id_t idx = GLOBAL_LOCATION_ENTRY_ID;
        uint32_t status = mesh_config_entry_get(idx, &m_location_global);
        if (status == NRF_SUCCESS)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Load global location: 0x%08X,0x%08X,0x%04X\n",
                  m_location_global.global_latitude, m_location_global.global_longitude, m_location_global.global_altitude);
        idx = LOCAL_LOCATION_ENTRY_ID;
        status = mesh_config_entry_get(idx, &m_location_local);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Load local location: 0x%04X,0x%04X,0x%04X,0x%02X,0x%04X\n",
                  m_location_local.local_north, m_location_local.local_east, m_location_local.local_altitude,
                  m_location_local.floor_number, m_location_local.uncertainty);
    And used the following code to set entries.
        // Save to configuration entry
            mesh_config_entry_id_t entry_id = GLOBAL_LOCATION_ENTRY_ID;
            uint32_t status = mesh_config_entry_set(entry_id, &m_location_global);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Save global location: 0x%08X,0x%08X,0x%04X\n",
            mesh_config_entry_id_t entry_id = LOCAL_LOCATION_ENTRY_ID;
            uint32_t status = mesh_config_entry_set(entry_id, &m_location_local);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Save local location: 0x%04X,0x%04X,0x%04X,0x%02X,0x%04X\n",
    I am a little bit suspicious of using getter/setter code.
    Because I just already have static module variable and try to share it between functions, no code is used inside getter/setter function.
    Can it be problem?
  • I found what is the problem.
    my model_config_load() call is too early in model_init_cb(), so it failed.
    And also I figured out that mesh_config_load() automatically includes loading each of my custom entries.
    So, because mesh_config_load(0 will call getter/setter for my entries, I added memcpy() inside getter/setter, even it seems to be redundant.
    After then, it works fine.
