Create accurate microsecond timer without interrupts
Hey guys,
I want to create an accurate timer without interrupts. My timer has to be very accurate because I have to send HIGH and LOW signals for 1us. I have read this post to know that I need high-frequency clock source (HFCLK, 16 MHz), which means better resolution (62.5 ns) and higher power consumption (typ. 5 or 70 uA depending on HFCLK source). But I don't know how to program my code so I followed this post and this post. But I have still some problems with it. I post my code below.
My timer should only replace the unaccurate nrf_delay_us.
#include <stdint.h>
#include "nrf_delay.h"
#include "app_error.h"
#include "nrf_gpio.h"
#include "nrf_drv_timer.h"
#define OUTPUT_PIN  18
/** @brief Function for Timer 1 initialization.
void TIMEOUT_TIMER1_Init(void)
    NRF_TIMER1->TASKS_STOP = 1;           /**< Stop Timer 1 */
    NRF_TIMER1->TASKS_CLEAR = 1;          /**< Clear Timer 1 */
    NRF_TIMER1->MODE      = 0;            /**< Mode 0: Timer */
    NRF_TIMER1->BITMODE   = 3;            /**< Bitmode 3: 32 bit (for what?, What happens if I choose 16 bit?) */
    NRF_TIMER1->PRESCALER = 4;            /**< Prescaler 4: 1us Timer -> f(TIMER) = 16MHz / (2^PRESCALER) = 1MHz -> t(TIMER) = 1us */
    NRF_TIMER1->INTENCLR = TIMER_INTENCLR_COMPARE0_Disabled
                            | TIMER_INTENCLR_COMPARE1_Disabled
                            | TIMER_INTENCLR_COMPARE2_Disabled
                            | TIMER_INTENCLR_COMPARE3_Disabled
                            | TIMER_INTENCLR_COMPARE4_Disabled
                            | TIMER_INTENCLR_COMPARE5_Disabled; /**< Disable all interrupts */
void TIMEROUT_TIMER1_Start(uint32_t timeout_us)
    // this line: set TIMER1 to 0 (start value)
    // this line: hand over the time "timeout_us" to TIMER1 (end time)
    // this line: stop TIMER1 if end time ("timeout_us") is reached
    NRF_TIMER1->TASKS_START = 1;
void Write_Byte(uint8_t byte)
    int walk;
    for (walk = 0; walk < 8; ++walk)
        nrf_gpio_pin_clear(OUTPUT_PIN);
        if (byte & 0x01)
            TIMEROUT_TIMER1_Start(1);       //instead of nrf_delay_us()
            nrf_gpio_pin_set(OUTPUT_PIN);
            TIMEROUT_TIMER1_Start(60);      //instead of nrf_delay_us()
        byte >>= 1;
 * @brief Function for application main entry.
    uint32_t err_code;
    TIMEOUT_TIMER1_Init;
    uint8_t AA = 0xAA;
    nrf_gpio_cfg_output(OUTPUT_PIN);
    while (true)
        Write_Byte(AA);
        nrf_delay_us(20);
In line 19: (Init) Why should I use 32 bits and not 16 bits? where is the difference?
In lines 35 - 37: (time function) I hope you can help me here. I don't know how I can hand over my timeout value to my function and to my timer, so that the timer can work with it...
I hope, you can help me.
Thanks in advance,
Christoph
  • Ok Håkon,
    Did you run the example as-is to see if you are able replicate my measurements?
    that is a good objection. I run your example and reduced the amount of __NOP() a little bit.
    #include <stdbool.h>
    #include <stdint.h>
    #include "boards.h"
    #define CC_USED 0
    void timer_setup(void)
        NRF_TIMER1->BITMODE = TIMER_BITMODE_BITMODE_32Bit;
        NRF_TIMER1->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos| TIMER_SHORTS_COMPARE0_STOP_Enabled << TIMER_SHORTS_COMPARE0_STOP_Pos;
        NRF_TIMER1->PRESCALER = 0;
    #pragma push
    #pragma O3
    void timer_sleep(uint32_t timeout_us)
        if (timeout_us == 0)
            return;
        if (timeout_us == 1)
            /* Adjust the amount of NOPs here */
            __NOP(); __NOP(); __NOP(); __NOP();
            /*__nop(); __nop(); __nop(); __nop();
            __nop(); __nop();*/
            return;
        NRF_TIMER1->CC[CC_USED] = (timeout_us << 4) - 18;
        while(NRF_TIMER1->EVENTS_COMPARE[CC_USED] == 0)
          /* Call __WFE() if loop is long */
        NRF_TIMER1->EVENTS_COMPARE[CC_USED] = 0;
    #pragma pop
        /* Configure board. */
        //bsp_board_init(BSP_INIT_LEDS);
        bsp_board_leds_init();
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
        NRF_NVMC->ICACHECNF = NVMC_ICACHECNF_CACHEEN_Msk;
        timer_setup();
        /* Toggle LEDs. */
        while (true)
            timer_sleep(2);
            NRF_P0->OUT ^= (1 << OUTPUT_PIN);
    Now I'm getting nearly the 1us! :)
    But why is there a delay when I'm using:
    nrf_gpio_pin_set() / clear() ?
    Can you please check if my adoptions are true:
    To set the output I'm using: NRF_P0->OUT |= (1 << OUTPUT_PIN);
    To clear the output: NRF_P0->OUT &= ~(1 << OUTPUT_PIN);
    To read from input: NRF_P0->IN = (1 << INPUT_PIN);
    I'm using SES and SDK 14.2.0
    Christoph
  • Hi Christoph,
    That is good news!
    Try this: uint32_t pin =  (NRF_P0->IN & (1 << INPUT_PIN));
    Others look OK.
    Because they are function calls, although static inlined, which use stacked memory to access the register. If you look at the assembly output, you'll likely see more instructions than just directly accessing the register. The output depends on the compiler used as well.
    For GCC, you need to force the optimization like this:
    #pragma GCC push_options
    #pragma GCC optimize ("O3")
            return;
            __nop(); __nop();
            return;
    #pragma GCC pop_options
    Your overall settings for optimization will be overridden for this specific function only.
    *edit*
    Tested with "O3" optimization on SES v4.22, and got:
    1 us input = 1.05 to 1.1 us
    2 us input = 1.9 us
    10 us input = 9.9 us
    Please check with these pragma's for GCC optimization and see if you also see similar behavior.
    Håkon
  • Hey Håkon,
    it's the last day before weekend. Slight smile
    As note: when I'm trying this I had to set the INPUT_PIN as input as follows:
    nrf_gpio_cfg_input(INPUT_PIN, NRF_GPIO_PIN_NOPULL);
    Thanks for your explanation.
    What is doing the ICACHE?
    Does the pragma set the priority for this function at the highest level or which settings for optimization will be overritten by pragma?
    I've check the input with the new GCC optimization and your amount of __NOP() (50 i think) and I'm getting the same values as you.
    1 us input = 1.08 us
    2 us input = 1.88 us
    60 us input = 60 us
    But first I have to thank you for your patience and devotiation. Without your help I would be very helpless. Thanks Håkon, you are a very nice and smart one! I really enjoyed working with you.
    Christoph
  • Hi Christoph,
    Ah, yes, that is a pre-requisite. Same goes for GPIO outputs, which needs to be configured (nrf_gpio_cfg_output(my_pin_number); for instance), but those you set/clear via NRF_GPIO->OUTSET, OUTCLR, or OUT (or any other "helper" functions, like nrf_gpio_pin_toggle()).
     This is the instruction cache. This cache reads instructions from flash, assuming that the program execution is incremental, thus speeding up your program. Its sped up as flash is actually a bit slower than the frequency the CPU run on. The implementation is explained more in detail here: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/nvmc.html?cp=4_2_0_10_5#concept_dh3_cyy_vr
    But, for generic cache explanations, wiki would help you out as well.
     The pragma sets the optimization level to the compiler. Let's say you want to optimize your firmware for size (-Os flag to the compiler), but you have certain functions that you want to run as fast as possible, you can wrap that option around those functions. You can even optimize a full .c file individually if you'd like.
    This is good news! You can ofcourse add or remove amount of NOPs to see if you're able to fine-tune it even further.
     Thank you for the kind words! I am very glad to hear that I was of good use! If you run into issues or questions in the future, you know where to ask Slight smile
    Hope you have a nice weekend, Christoph!
    Håkon
  • Hey Håkon,
    that's interesting because for toggling the output like NRF_P0->OUT ^= (1 << OUTPUT_PIN); I don't need to configure the output pin as output (in my project)...
    But thanks again for your detailed explanations. It helps me a lot. Slight smile
    If I have some problems again, I hope we can work together again. Slight smile
    Have a nice weekend too, Håkon!
    Best wishes and kind regards,
    Christoph
