Radio is flashing green, on and off, but I can't seem to connect to it. Looking at the graph of usage, I can see that it is talking to something since the available amount of data left is decreasing.
Hi sirob,
If you connect the device through USB and open up a serial terminal you should be able to get out information from the application, and that can help you debug what is going on.
Have you followed the Getting Started guide?
Which network are you connecting to, and what technology (LTE-M or NB-IoT)?
Have you registered the iBASIS SIM or are you using another SIM card?
In general, our connectivity can be found at:
https://ibasis.com/solutions/iot-connectivity/network-coverage/
Still not connecting. Yes I followed the "Getting Started" guide.I'll check the USB port and see if I can get anything out of that.
