I'm working on a simple ADC application where I sample using analog channel 1 and then read the value through the debugger. However my results are nonsense. I have connected a potmeter with VDD on the right pin, ground on the left and the analog input as the center pin. No matter which analog pin I connect the center potmeter pin to, i get a value around 0x50. I feel I have forgotten to set-up the analog input pin. It's like there's missing a connection between the input-pin and the ADC.
\#include <stdbool.h>
\#include "nrf.h"
\#include "nrf_delay.h"
\#include "nrf_gpio.h"
uint32_t result = 0;
/** Configures port 1 as output */
static void gpio_config(void)
nrf_gpio_range_cfg_output(8, 15);
nrf_gpio_port_write(NRF_GPIO_PORT_SELECT_PORT1, 0);
nrf_gpio_cfg_input(20, NRF_GPIO_PIN_PULLUP); //BUTTON 4
nrf_gpio_cfg_output(23); //LED 3
nrf_gpio_cfg_output(24); //LED 4
//Interupt on button 4
NVIC_EnableIRQ(GPIOTE_IRQn);
NRF_GPIOTE->CONFIG[0] = (GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos)
| (20 << GPIOTE_CONFIG_PSEL_Pos) //BUTTON 4
| (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos);
NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_IN0_Set << GPIOTE_INTENSET_IN0_Pos;
void GPIOTE_IRQHandler(void)
// Event causing the interrupt must be cleared.
if ((NRF_GPIOTE->EVENTS_IN[0] == 1) &&
(NRF_GPIOTE->INTENSET & GPIOTE_INTENSET_IN0_Msk))
NRF_GPIOTE->EVENTS_IN[0] = 0;
nrf_gpio_pin_toggle(23);
NRF_ADC->TASKS_START = 1;
/** Configures and enables the ADC */
void ADC_init(void)
/* Enable interrupt on ADC sample ready event*/
NRF_ADC->INTENSET = ADC_INTENSET_END_Msk;
NVIC_EnableIRQ(ADC_IRQn);
NRF_ADC->CONFIG = (ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos) /* Bits 17..16 : No external reference. */
| (ADC_CONFIG_PSEL_AnalogInput1 << ADC_CONFIG_PSEL_Pos) /*!< Use analog input 1 as analog input. */
| (ADC_CONFIG_REFSEL_SupplyOneThirdPrescaling << ADC_CONFIG_REFSEL_Pos) /*!< Use VDD/3 */
| (ADC_CONFIG_INPSEL_AnalogInputOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos) /*!< Analog input specified by PSEL with 1/3 prescaling used as input for the conversion. */
| (ADC_CONFIG_RES_8bit << ADC_CONFIG_RES_Pos); /*!< 8 bit */
/* Enable ADC*/
NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
/* Interrupt handler for ADC data ready event */
void ADC_IRQHandler(void)
/* Clear dataready event */
NRF_ADC->EVENTS_END = 0;
/* Write ADC result to port 1 */
//nrf_gpio_port_write(NRF_GPIO_PORT_SELECT_PORT1, NRF_ADC->RESULT);
nrf_gpio_pin_toggle(24);
//Use the STOP task to save current. Workaround for PAN_028 rev1.2 anomaly 1.
NRF_ADC->TASKS_STOP = 1;
//Write result
result = NRF_ADC->RESULT;
