additional questions to nRF52832 Errata 220 clearification
refering
(1) https://devzone.nordicsemi.com/f/nordic-q-a/55197/nrf52832-errata-220-clearification
(2) https://devzone.nordicsemi.com/f/nordic-q-a/58488/nrf52832-errata-220-clearification-need-more-information
(3) https://devzone.nordicsemi.com/f/nordic-q-a/4498/difference-between-wfe-and-sd_app_evt_wait/15954#15954
there is coming up an additional question.
Sorry for closing the last thread to early.
@Susheel in (2) you answer me that
(a) The SD never calls sd_app_evt_wait by itself. It will also not call __WFE by itself.
(b) Yes, that is correct. You just need to call __WFE in the way that is given as the workaround for this errata.
But reading (1) again I found:
(C) The softdevice will trigger this errata inside sd_app_evt_wait() which will be called by the app. Because this is where the CPU starts to execute after the wakeup.
This contradicts your answer in (a) and reading (3):
(d) The sd_app_evt_wait is basically the safe version of WFE when using the SoftDevice. Since the SoftDevice is running in a different context than your application you cannot know if it is safe to use WFE. Therefore, use the SD function.
makes me even more unsure what to do.
My app and the SDK (15.2.0) calling sd_app_evt_wait().
So now I'm in a dilemma.I should use the function sd_app_evt_wait() to be safe with the SD but on the other hand the implementation of sd_app_evt_wait() in the SD did't contains the workaround till now.
So it is again unclear for me if I should use sd_app_evt_wait() to be safe with the SD or using the workaround to get not into trouble with errata 220.
Till now we didn't observe any strange behavior in our device. So maybe it is more safe still using sd_app_evt_wait() but than I have to fully understand the conditions of errata 220 which I didn't do till now.
Thank you in advance!
Dirk
