NRF52840 RESET Pin stuck at LOW
I have a custom nRF52840 board. I mistakenly tried flashing the custom nRF52840 board with STM32 firmware. From that moment on, I can't flash board. When connected to J-Link, LED on J-Link is solid RED. I noticed that the RESET pin is in LOW level.
Here's what I tried after going through questions in forum:
  1. Pulled up the RESET pin to 3.3V.
  2. Erased the chip from SES
  3. Recovered the board using nRFGoStudio and it was successful.
  4. Followed one post which suggested to use J-Link commander to reset and write values after resetting. Everything went successful.
  5. In system_nRF52840.c, I commented this section, as recommended by one of the other posts.
    #if defined (CONFIG_GPIO_AS_PINRESET)
            if (((NRF_UICR->PSELRESET[0] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos)) ||
                ((NRF_UICR->PSELRESET[1] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos))){
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
                while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
                NRF_UICR->PSELRESET[0] = 18;
                NRF_UICR->PSELRESET[1] = 18;
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
                NVIC_SystemReset();
However, the RESET pin still needs to be pulled-up to HIGH for the board to responsd to J-Link.
Can you please help me un-brick this board?
