The sdk_config.h file is not being parsed by the compiler
I cannot get the scope of the sdk_config.h file to encompass all modules. Process
  • Start with example project using the file system as per the install.
  • After compiling and running on the DK, copy the example files over to a new folder for inclusion into revision control.
  • Edit the project file to make sure the relative paths have been properly modified to reflect the new project folder
  • Make sure the project still compiles and runs.
  • Make an edit that includes a new module, in this case the TWIM
  • dutifully edit the sdk_config.h file to enable the TWIM module
  • Compiler error in main at this line: static const nrfx_twim_t twi0 = NRFX_TWIM_INSTANCE(TWI_INSTANCE_ID);
  • When expanding the macro the compiler cannot find a definition for "NRFX_TWIM0_INST_IDX" because it is not enumerated in nrfx_twim.h because NRFX_TWIM0_ENABLED is not defined
  • Go back and check the nrf_config.h file and it is indeed enabled.
  • Find out that disabling other modules in the nrf_config.h file doesn't have an effect, ergo the nrf_config.h file is not being used.
  • To make sure the pathways are not pointing to another version, disable (rename) all other nrf_config.h files in the file system - no effect.
  • Explicitly define NRFX_TWIM0_ENABLED in nrfx_twim.h and everything compiles fine.
  • make a test header file with just that line and include it in main - no effect.
  • include that same test header file in nrfx_twim.h file, everything compiles fine
  • remove the test include and include the sdk_config.h file in the nrfx_twim.h file, compile fails again
What on earth is going on? I've searched up and down the project settings thinking that the config file is disabled somehow, but nothing.
