SDK nRF5_SDK_15.0.0_a53641a
例程 nRF5_SDK_15.0.0_a53641a\examples\peripheral\twi_sensor
没有修改任何内容,编译烧录到nordic开发板后,
执行到 main函数中 LM75B_set_mode()函数,出现阻塞,没有正常往下执行。阻塞的表达式为 while (m_xfer_done == false);
pics:
是因为SDK的原因吗?
pics:
是因为SDK的原因吗?
Please write your question in English.
SDK : nRF5_SDK_15.0.0_a53641a
examples: nRF5_SDK_15.0.0_a53641a\examples\peripheral\twi_sensor
I didn't change anything. After build and download to the Nordic development board,
The LM75B_set_mode() function in the main function is blocked and not executed normally. The blocking expression is while (m_xfer_done == false);
After I used the SDK: nRF5_SDK_15.2.0_9412b96 , also appeared the above situation
Please help to answer it, thank you
I am not sure I understand you correctly. You would like to add a TWI slave to the ble_app_uart example, is this correct?
If so, what do you mean when you say "I transplanted the nrf_drv_twi_tx function"?
Have you also initialized the TWI instance, and included the necessary nrf_drv_twi, nrfx_twi and nrfx_twim in your project?
I think it would be beneficial to my understanding of your issue if you could share the code you are running here.
lisi said:Then, I used the oscilloscope to collect SCL clock line wareform, found there is no high and low level conversion.
Does this mean that you were unable to see anything on the SCL pin, after having built and flashed your device with your modified ble_app_uart example?
Karl
the following is the main.c
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
do
if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
(err_code != NRF_ERROR_NOT_FOUND) )
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
nrf_pwr_mgmt_run();
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* Common addresses definition for temperature sensor. */
#define BMP280_ADDR (0xeeU >> 1)
#define BMP280_REG_ID 0xd0U
#define BMP280_REG_CONF 0xf4U
/* Mode for BMP280. */
#define COLLECT_MODE 0xb3U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
* @brief Function for setting active mode on MMA7660 accelerometer.
void BMP280_set_mode(void)
/* Writing to BMP280_REG_CONF "b3" set temperature sensor in NORMAL mode. */
uint8_t reg[2] = {BMP280_REG_CONF, COLLECT_MODE}; //{0xf4, 0xb3} enable temperature collect
err_code = nrf_drv_twi_tx(&m_twi, BMP280_ADDR, reg, sizeof(reg), false);
* @brief Function for handling data from temperature sensor.
* @param[in] temp Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(m_sample);
m_xfer_done = true;
* @brief UART initialization.
void twi_init (void)
const nrf_drv_twi_config_t twi_BMP280_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_BMP280_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
* @brief Function for reading data from temperature sensor.
static void read_sensor_data()
/* Writing to pointer byte. */
uint8_t reg[1];
reg[0] = BMP280_REG_ID;
err_code = nrf_drv_twi_tx(&m_twi, BMP280_ADDR, reg, 1, false);
nrf_delay_ms(500);
/* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
err_code = nrf_drv_twi_rx(&m_twi, BMP280_ADDR, &m_sample, sizeof(m_sample));
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
NRF_LOG_FLUSH();
twi_init(); //twi Initialize
BMP280_set_mode(); //BMP280 sensor Initialize //stop in this function
// Start execution.
advertising_start();
// Enter main loop.
for (;;)
nrf_delay_ms(500);
do
__WFE();
}while (m_xfer_done == false);
read_sensor_data();
NRF_LOG_FLUSH();
idle_state_handle();
the following is the twi configuration from the sdk_config.h
Searching for 'TWI'... E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3844) : // <e> NRFX_TWIM_ENABLED - nrfx_twim - TWIM peripheral driver E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3846) : #ifndef NRFX_TWIM_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3847) : #define NRFX_TWIM_ENABLED 1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3849) : // <q> NRFX_TWIM0_ENABLED - Enable TWIM0 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3852) : #ifndef NRFX_TWIM0_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3853) : #define NRFX_TWIM0_ENABLED 1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3856) : // <q> NRFX_TWIM1_ENABLED - Enable TWIM1 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3859) : #ifndef NRFX_TWIM1_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3860) : #define NRFX_TWIM1_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3863) : // <o> NRFX_TWIM_DEFAULT_CONFIG_FREQUENCY - Frequency E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3869) : #ifndef NRFX_TWIM_DEFAULT_CONFIG_FREQUENCY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3870) : #define NRFX_TWIM_DEFAULT_CONFIG_FREQUENCY 26738688 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3873) : // <q> NRFX_TWIM_DEFAULT_CONFIG_HOLD_BUS_UNINIT - Enables bus holding after uninit E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3876) : #ifndef NRFX_TWIM_DEFAULT_CONFIG_HOLD_BUS_UNINIT E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3877) : #define NRFX_TWIM_DEFAULT_CONFIG_HOLD_BUS_UNINIT 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3880) : // <o> NRFX_TWIM_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3891) : #ifndef NRFX_TWIM_DEFAULT_CONFIG_IRQ_PRIORITY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3892) : #define NRFX_TWIM_DEFAULT_CONFIG_IRQ_PRIORITY 7 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3895) : // <e> NRFX_TWIM_CONFIG_LOG_ENABLED - Enables logging in the module. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3897) : #ifndef NRFX_TWIM_CONFIG_LOG_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3898) : #define NRFX_TWIM_CONFIG_LOG_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3900) : // <o> NRFX_TWIM_CONFIG_LOG_LEVEL - Default Severity level E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3908) : #ifndef NRFX_TWIM_CONFIG_LOG_LEVEL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3909) : #define NRFX_TWIM_CONFIG_LOG_LEVEL 3 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3912) : // <o> NRFX_TWIM_CONFIG_INFO_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3924) : #ifndef NRFX_TWIM_CONFIG_INFO_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3925) : #define NRFX_TWIM_CONFIG_INFO_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3928) : // <o> NRFX_TWIM_CONFIG_DEBUG_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3940) : #ifndef NRFX_TWIM_CONFIG_DEBUG_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3941) : #define NRFX_TWIM_CONFIG_DEBUG_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3946) : // <q> NRFX_TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED - Enables nRF52 anomaly 109 workaround for TWIM. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3955) : #ifndef NRFX_TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3956) : #define NRFX_TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3961) : // <e> NRFX_TWIS_ENABLED - nrfx_twis - TWIS peripheral driver E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3963) : #ifndef NRFX_TWIS_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3964) : #define NRFX_TWIS_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3966) : // <q> NRFX_TWIS0_ENABLED - Enable TWIS0 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3969) : #ifndef NRFX_TWIS0_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3970) : #define NRFX_TWIS0_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3973) : // <q> NRFX_TWIS1_ENABLED - Enable TWIS1 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3976) : #ifndef NRFX_TWIS1_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3977) : #define NRFX_TWIS1_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3980) : // <q> NRFX_TWIS_ASSUME_INIT_AFTER_RESET_ONLY - Assume that any instance would be initialized only once E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3983) : // <i> Optimization flag. Registers used by TWIS are shared by other peripherals. Normally, during initialization driver tries to clear all registers to known state before doing the initialization itself. This gives initialization safe procedure, no matter when it would be called. If you activate TWIS only once and do never uninitialize it - set this flag to 1 what gives more optimal code. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3985) : #ifndef NRFX_TWIS_ASSUME_INIT_AFTER_RESET_ONLY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3986) : #define NRFX_TWIS_ASSUME_INIT_AFTER_RESET_ONLY 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3989) : // <q> NRFX_TWIS_NO_SYNC_MODE - Remove support for synchronous mode E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3994) : #ifndef NRFX_TWIS_NO_SYNC_MODE E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3995) : #define NRFX_TWIS_NO_SYNC_MODE 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3998) : // <o> NRFX_TWIS_DEFAULT_CONFIG_ADDR0 - Address0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(3999) : #ifndef NRFX_TWIS_DEFAULT_CONFIG_ADDR0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4000) : #define NRFX_TWIS_DEFAULT_CONFIG_ADDR0 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4003) : // <o> NRFX_TWIS_DEFAULT_CONFIG_ADDR1 - Address1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4004) : #ifndef NRFX_TWIS_DEFAULT_CONFIG_ADDR1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4005) : #define NRFX_TWIS_DEFAULT_CONFIG_ADDR1 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4008) : // <o> NRFX_TWIS_DEFAULT_CONFIG_SCL_PULL - SCL pin pull configuration E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4014) : #ifndef NRFX_TWIS_DEFAULT_CONFIG_SCL_PULL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4015) : #define NRFX_TWIS_DEFAULT_CONFIG_SCL_PULL 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4018) : // <o> NRFX_TWIS_DEFAULT_CONFIG_SDA_PULL - SDA pin pull configuration E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4024) : #ifndef NRFX_TWIS_DEFAULT_CONFIG_SDA_PULL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4025) : #define NRFX_TWIS_DEFAULT_CONFIG_SDA_PULL 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4028) : // <o> NRFX_TWIS_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4039) : #ifndef NRFX_TWIS_DEFAULT_CONFIG_IRQ_PRIORITY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4040) : #define NRFX_TWIS_DEFAULT_CONFIG_IRQ_PRIORITY 7 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4043) : // <e> NRFX_TWIS_CONFIG_LOG_ENABLED - Enables logging in the module. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4045) : #ifndef NRFX_TWIS_CONFIG_LOG_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4046) : #define NRFX_TWIS_CONFIG_LOG_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4048) : // <o> NRFX_TWIS_CONFIG_LOG_LEVEL - Default Severity level E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4056) : #ifndef NRFX_TWIS_CONFIG_LOG_LEVEL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4057) : #define NRFX_TWIS_CONFIG_LOG_LEVEL 3 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4060) : // <o> NRFX_TWIS_CONFIG_INFO_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4072) : #ifndef NRFX_TWIS_CONFIG_INFO_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4073) : #define NRFX_TWIS_CONFIG_INFO_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4076) : // <o> NRFX_TWIS_CONFIG_DEBUG_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4088) : #ifndef NRFX_TWIS_CONFIG_DEBUG_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4089) : #define NRFX_TWIS_CONFIG_DEBUG_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4096) : // <e> NRFX_TWI_ENABLED - nrfx_twi - TWI peripheral driver E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4098) : #ifndef NRFX_TWI_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4099) : #define NRFX_TWI_ENABLED 1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4101) : // <q> NRFX_TWI0_ENABLED - Enable TWI0 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4104) : #ifndef NRFX_TWI0_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4105) : #define NRFX_TWI0_ENABLED 1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4108) : // <q> NRFX_TWI1_ENABLED - Enable TWI1 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4111) : #ifndef NRFX_TWI1_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4112) : #define NRFX_TWI1_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4115) : // <o> NRFX_TWI_DEFAULT_CONFIG_FREQUENCY - Frequency E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4121) : #ifndef NRFX_TWI_DEFAULT_CONFIG_FREQUENCY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4122) : #define NRFX_TWI_DEFAULT_CONFIG_FREQUENCY 26738688 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4125) : // <q> NRFX_TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT - Enables bus holding after uninit E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4128) : #ifndef NRFX_TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4129) : #define NRFX_TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4132) : // <o> NRFX_TWI_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4143) : #ifndef NRFX_TWI_DEFAULT_CONFIG_IRQ_PRIORITY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4144) : #define NRFX_TWI_DEFAULT_CONFIG_IRQ_PRIORITY 7 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4147) : // <e> NRFX_TWI_CONFIG_LOG_ENABLED - Enables logging in the module. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4149) : #ifndef NRFX_TWI_CONFIG_LOG_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4150) : #define NRFX_TWI_CONFIG_LOG_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4152) : // <o> NRFX_TWI_CONFIG_LOG_LEVEL - Default Severity level E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4160) : #ifndef NRFX_TWI_CONFIG_LOG_LEVEL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4161) : #define NRFX_TWI_CONFIG_LOG_LEVEL 3 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4164) : // <o> NRFX_TWI_CONFIG_INFO_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4176) : #ifndef NRFX_TWI_CONFIG_INFO_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4177) : #define NRFX_TWI_CONFIG_INFO_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4180) : // <o> NRFX_TWI_CONFIG_DEBUG_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4192) : #ifndef NRFX_TWI_CONFIG_DEBUG_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(4193) : #define NRFX_TWI_CONFIG_DEBUG_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5454) : // <e> TWIS_ENABLED - nrf_drv_twis - TWIS peripheral driver - legacy layer E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5456) : #ifndef TWIS_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5457) : #define TWIS_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5459) : // <q> TWIS0_ENABLED - Enable TWIS0 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5462) : #ifndef TWIS0_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5463) : #define TWIS0_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5466) : // <q> TWIS1_ENABLED - Enable TWIS1 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5469) : #ifndef TWIS1_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5470) : #define TWIS1_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5473) : // <q> TWIS_ASSUME_INIT_AFTER_RESET_ONLY - Assume that any instance would be initialized only once E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5476) : // <i> Optimization flag. Registers used by TWIS are shared by other peripherals. Normally, during initialization driver tries to clear all registers to known state before doing the initialization itself. This gives initialization safe procedure, no matter when it would be called. If you activate TWIS only once and do never uninitialize it - set this flag to 1 what gives more optimal code. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5478) : #ifndef TWIS_ASSUME_INIT_AFTER_RESET_ONLY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5479) : #define TWIS_ASSUME_INIT_AFTER_RESET_ONLY 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5482) : // <q> TWIS_NO_SYNC_MODE - Remove support for synchronous mode E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5487) : #ifndef TWIS_NO_SYNC_MODE E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5488) : #define TWIS_NO_SYNC_MODE 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5491) : // <o> TWIS_DEFAULT_CONFIG_ADDR0 - Address0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5492) : #ifndef TWIS_DEFAULT_CONFIG_ADDR0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5493) : #define TWIS_DEFAULT_CONFIG_ADDR0 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5496) : // <o> TWIS_DEFAULT_CONFIG_ADDR1 - Address1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5497) : #ifndef TWIS_DEFAULT_CONFIG_ADDR1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5498) : #define TWIS_DEFAULT_CONFIG_ADDR1 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5501) : // <o> TWIS_DEFAULT_CONFIG_SCL_PULL - SCL pin pull configuration E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5507) : #ifndef TWIS_DEFAULT_CONFIG_SCL_PULL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5508) : #define TWIS_DEFAULT_CONFIG_SCL_PULL 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5511) : // <o> TWIS_DEFAULT_CONFIG_SDA_PULL - SDA pin pull configuration E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5517) : #ifndef TWIS_DEFAULT_CONFIG_SDA_PULL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5518) : #define TWIS_DEFAULT_CONFIG_SDA_PULL 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5521) : // <o> TWIS_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5534) : #ifndef TWIS_DEFAULT_CONFIG_IRQ_PRIORITY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5535) : #define TWIS_DEFAULT_CONFIG_IRQ_PRIORITY 7 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5540) : // <e> TWI_ENABLED - nrf_drv_twi - TWI/TWIM peripheral driver - legacy layer E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5542) : #ifndef TWI_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5543) : #define TWI_ENABLED 1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5545) : // <o> TWI_DEFAULT_CONFIG_FREQUENCY - Frequency E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5551) : #ifndef TWI_DEFAULT_CONFIG_FREQUENCY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5552) : #define TWI_DEFAULT_CONFIG_FREQUENCY 26738688 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5555) : // <q> TWI_DEFAULT_CONFIG_CLR_BUS_INIT - Enables bus clearing procedure during init E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5558) : #ifndef TWI_DEFAULT_CONFIG_CLR_BUS_INIT E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5559) : #define TWI_DEFAULT_CONFIG_CLR_BUS_INIT 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5562) : // <q> TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT - Enables bus holding after uninit E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5565) : #ifndef TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5566) : #define TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5569) : // <o> TWI_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5582) : #ifndef TWI_DEFAULT_CONFIG_IRQ_PRIORITY E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5583) : #define TWI_DEFAULT_CONFIG_IRQ_PRIORITY 7 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5586) : // <e> TWI0_ENABLED - Enable TWI0 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5588) : #ifndef TWI0_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5589) : #define TWI0_ENABLED 1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5591) : // <q> TWI0_USE_EASY_DMA - Use EasyDMA (if present) E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5594) : #ifndef TWI0_USE_EASY_DMA E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5595) : #define TWI0_USE_EASY_DMA 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5600) : // <e> TWI1_ENABLED - Enable TWI1 instance E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5602) : #ifndef TWI1_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5603) : #define TWI1_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5605) : // <q> TWI1_USE_EASY_DMA - Use EasyDMA (if present) E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5608) : #ifndef TWI1_USE_EASY_DMA E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5609) : #define TWI1_USE_EASY_DMA 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5614) : // <q> TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED - Enables nRF52 anomaly 109 workaround for TWIM. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5623) : #ifndef TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5624) : #define TWIM_NRF52_ANOMALY_109_WORKAROUND_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5809) : // <q> NRF_TWI_SENSOR_ENABLED - nrf_twi_sensor - nRF TWI Sensor module E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5812) : #ifndef NRF_TWI_SENSOR_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(5813) : #define NRF_TWI_SENSOR_ENABLED 1 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(7001) : // <q> NRF_TWI_MNGR_ENABLED - nrf_twi_mngr - TWI transaction manager E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(7004) : #ifndef NRF_TWI_MNGR_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(7005) : #define NRF_TWI_MNGR_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8280) : // <e> TWIS_CONFIG_LOG_ENABLED - Enables logging in the module. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8282) : #ifndef TWIS_CONFIG_LOG_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8283) : #define TWIS_CONFIG_LOG_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8285) : // <o> TWIS_CONFIG_LOG_LEVEL - Default Severity level E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8293) : #ifndef TWIS_CONFIG_LOG_LEVEL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8294) : #define TWIS_CONFIG_LOG_LEVEL 3 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8297) : // <o> TWIS_CONFIG_INFO_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8309) : #ifndef TWIS_CONFIG_INFO_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8310) : #define TWIS_CONFIG_INFO_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8313) : // <o> TWIS_CONFIG_DEBUG_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8325) : #ifndef TWIS_CONFIG_DEBUG_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8326) : #define TWIS_CONFIG_DEBUG_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8331) : // <e> TWI_CONFIG_LOG_ENABLED - Enables logging in the module. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8333) : #ifndef TWI_CONFIG_LOG_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8334) : #define TWI_CONFIG_LOG_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8336) : // <o> TWI_CONFIG_LOG_LEVEL - Default Severity level E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8344) : #ifndef TWI_CONFIG_LOG_LEVEL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8345) : #define TWI_CONFIG_LOG_LEVEL 3 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8348) : // <o> TWI_CONFIG_INFO_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8360) : #ifndef TWI_CONFIG_INFO_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8361) : #define TWI_CONFIG_INFO_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8364) : // <o> TWI_CONFIG_DEBUG_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8376) : #ifndef TWI_CONFIG_DEBUG_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(8377) : #define TWI_CONFIG_DEBUG_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9566) : // <e> NRF_TWI_SENSOR_CONFIG_LOG_ENABLED - Enables logging in the module. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9568) : #ifndef NRF_TWI_SENSOR_CONFIG_LOG_ENABLED E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9569) : #define NRF_TWI_SENSOR_CONFIG_LOG_ENABLED 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9571) : // <o> NRF_TWI_SENSOR_CONFIG_LOG_LEVEL - Default Severity level E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9579) : #ifndef NRF_TWI_SENSOR_CONFIG_LOG_LEVEL E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9580) : #define NRF_TWI_SENSOR_CONFIG_LOG_LEVEL 3 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9583) : // <o> NRF_TWI_SENSOR_CONFIG_INFO_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9595) : #ifndef NRF_TWI_SENSOR_CONFIG_INFO_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9596) : #define NRF_TWI_SENSOR_CONFIG_INFO_COLOR 0 E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9599) : // <o> NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR - ANSI escape code prefix. E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9611) : #ifndef NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR E:\nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\ble_app_uart\pca10040\s132\config\sdk_config.h(9612) : #define NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR 0 Lines matched: 209 Files matched: 1 Total files searched: 1
1. I want to add a TWI slave to the ble_app_uart example
2. I also initialized the TWI instance, and included the necessary nrf_drv_twi, nrfx_twi and nrfx_twim in my project
3. when I write or read , the programmer is always stop in while (m_xfer_done == false);
lisi said:3. when I write or read , the programmer is always stop in while (m_xfer_done == false);
Are you still not seeing anything on the SCL or SDA lines when your application is running, using your oscilloscope?
If so, could you provide a trace of the communication?
If you are not, the transfer will never complete, which explains why you are stuck in that while loop.
However, if you are able to see the communication as expected, the issue is probably with your TWI slave device.
Karl
Yes, I still not seeing anything on the SCL or SDA lines when my application is running, using my oscilloscope.
Hi again,
Sorry for my late reply.
I will take a look at the code you provided now.
Could you also detail for me how you have connected the nRF52 DK to your sensor, and on which pins you are attaching your oscilloscope?
Which sensor are you using, is it this BMP280 pressure sensor from Bosch?
Karl
Hi again,
Karl
Having looked over you code and the BMP280 datasheet(which I have assumed you are using), I have noted the following:
Could you make sure that you have connected your sensor and oscilloscope to the right pins on the nRF52 DK? It seems to me that your initialization is fine, which suggest that the pins might be wrong, since you are not seeing anything on your oscilloscope.
Furthermore, after taking a look in the BMP280 datasheet, your method for writing to the sensor, as used in the function BMP280_set_mode, does not seem to align with the format specified in the datasheet. Please see section 5.2.1 of the datasheet, for its required format.
This is not your current problem - but it will be a future one, once the TWI connection is established.
Karl
Thank you very much for your answer. I have found the reason. It is the hardware, not the program.Thanks again for your earnest answer.
No problem at all, I am happy to help!
I am glad to hear that we were able to sort out your issue.
Good luck with your continued development! :)
Karl
