Service Discovery Issues using the discovery manager.
I am trying to do service discovery using the discovery manager library on any BLE device I connect to my central. I start the service with bt_gatt_dm_start(conn, NULL, &discovery_cb, NULL) and every works fine on the first service discovered. I run into an issue when I try to continue the discovery on the remaining services. The asserts on line 2927 and 2929 in the bt_gatt_discover function of Zephyr's gatt.c library are asserted upon running bt_gatt_dm_continue.  If I remove these asserts everything runs fine and I am able to continue discovery of all the services for my device as intended. Is this a bug in the DM or am I using it incorrectly?
Here is my discover complete callback with the dm continue function
static void discovery_completed(struct bt_gatt_dm *disc, void *ctx)
  printk("Attribute count: %d\n", bt_gatt_dm_attr_cnt(disc));
  bt_gatt_dm_data_release(disc);
  bt_gatt_dm_continue(disc, NULL);
The asserts causing the issues:
int bt_gatt_discover(struct bt_conn *conn, struct bt_gatt_discover_params *params)
__ASSERT((params->start_handle && params->end_handle),
"invalid parameters\n");
__ASSERT((params->start_handle <= params->end_handle),
    have you checked the values of params->start_handle and params->end_handle?
  • I have yes and I figured out where it is happening at. In discovery_process_service you can see that the start handle has one added to it with attr->handle + 1. This becomes an issue when trying to do discovering on an empty service such as the 0x1801 service in the heart rate monitor where the end handle and start handle will be the same. Thus adding 1 to the starts makes it larger than the end. Maybe there needs to be a check if they are equal to each other before adding one to the start?
    static u8_t discovery_process_service(struct bt_gatt_dm *dm,
    				      const struct bt_gatt_attr *attr,
    	int err;
    	if (!attr) {
    		discovery_complete_not_found(dm);
    		return BT_GATT_ITER_STOP;
    	struct bt_gatt_service_val *service_val = attr->user_data;
    	struct bt_gatt_attr *cur_attr = attr_store(dm, attr);
    	if (!cur_attr) {
    		LOG_ERR("Not enough memory for service attribute.");
    		discovery_complete_error(dm, -ENOMEM);
    	LOG_DBG("Service detected, handles range: <%u, %u>",
    		attr->handle + 1,
    		service_val->end_handle);
    	cur_attr->uuid = uuid_store(dm, attr->uuid);
    	service_val = user_data_store(dm, service_val, sizeof(*service_val));
    	service_val->uuid = uuid_store(dm, service_val->uuid);
    	cur_attr->user_data = service_val;
    	if (!cur_attr->uuid || !service_val ||
    	    !service_val->uuid) {
    		LOG_ERR("Not enough memory for service attribute data.");
    	dm->discover_params.uuid         = NULL;
    	dm->discover_params.type         = BT_GATT_DISCOVER_ATTRIBUTE;
    	dm->discover_params.start_handle = attr->handle + 1;    ///ISSUE HERE
    	dm->discover_params.end_handle   = service_val->end_handle;
    	LOG_DBG("Starting descriptors discovery");
    	err = bt_gatt_discover(dm->conn, &(dm->discover_params));
    	if (err) {
    		LOG_ERR("Descriptor discover failed, error: %d.", err);
  • Have you tried implementing this PR? It might solve it.
  • Yes I have. That was also an issue I was having and that PR was created based on information I provided Joakim. I believe this problem may be a separate issue than the one in that PR as that issue was based on the end handle rolling over back to 0 and the discovery service not found callback never being invoked at the end. This seems to have been solved in later versions of the NCS.
