HELLO ALL,
I'M TRYING TO TEST THE BSC Rx EXAMPLE FROM DE SDK V16.
WHEN I DO IT USING ANTware II, EVERYTHING IS OK, SINCE IT'S ENOUGH WITH CONFIGURING CORRECTLY CHANNEL PARAMETERS. THE PROBLEM IS WHEN I TRY TO TEST IT USING THE TOOL SimulANT+.
THIS TOOL IS CAPABLE TO SIMULATE ANY ANT+ COMPONENT, FOR EXAMPLE A "BIKE SPEED & CADENCE SENSOR", AND THE EXAMPLE THAT I'M TRYING TO TEST, IS SUPPOSED TO BE CAPABLE OF RECEIVING DATA FROM THIS KIND OF SENSORS.
SO, WHAT I DO TO TEST THE EXAMPLE, IS TO SELECT THE "BIKE SPEED & CADENCE SENSOR" IN THE SimulANT+, AND TURN ON THE CHANNEL, AND I'M ABLE TO SEE THAT THIS IS BROADCASTING MESSAGES LIKE A REAL SENSOR DOES (I CAN CHECK THIS BECAUSE I CAN CONNECT MY GARMIN TO THIS SIMULATED SENSOR, AND SEE THE INFORMATION GIVEN BY IT).
BUT MY nRF52 DK BOARD (ALREADY FLASHED WITH THE EXAMPLE MENTIONED) IS NOT CAPABLE TO CONNECT TO THIS SIMULATED SENSOR. AS I SAID BEFORE, IT DOES CONNECT IF I USE ANTware II, BUT NOT IF I CONNECT THIS SIMULATED SENSOR THROW SimulANT+.
COULD SOMEONE HELP ME PLEASE?? I'D REALLY APPRECIATE.
