Hi All,
I am developing a data acquisition system in which my device generates an interrupt for every 5ms upon its data is ready. I store one second long data in local buffer and write it into external flash memory every 1 second.
I am bit confused with GPIO events and interrupts in nRF. I guess any level change on a input pin is called an event in nRF. If that is true I would like to configure one GPIO as input and configure an event (High to Low in my case) then assign it to an event handler.
And then, I have read below lines in SDK documentation,
When a SoftDevice is enabled, it can interrupt the application at any time for a certain amount of time. This can lead to the situation where some pin level changes are missed. If the application must track an input pin that can change its level frequently, PPI should be used with a high-accuracy event together with a TIMER in counter mode to count the detected transitions.
Below are my queries:
- My interrupt is generated every 5ms infinitely, and I cannot afford any single interrupt to lose. I would like to know how can I configure my interrupt handling mechanism to avoid data loss?
- If I use PPI with Timer to count the interrupts I have missed from my peripheral, how can I retrieve data from my device at later point?
- What is a softdevice? how it can interrupt the application?
- I need some help understanding event. Previously i was using a processor where any GPIO can be configured for external interrupts which is very straight forward. In nRF it seems there is no interrupt concept for GPIO rather they call it as event.
Any help would be highly appreciated.
Regards
Laskhmi
