to control leds of nRF51822 beacon using phone
I was previously working on nRF51822 ble beacon, in which codes flash of hex 20006.
But i wanted to flash a code nRF5_SDK_11.0.0_89a8197\examples\ble_peripheral\experimental_ble_app_blinky\hex\experimental_ble_app_blinky_s130_pca10028.hex, which was perfectly running on my nrf51422 DK. But i wanted to run the same example on my beacon, but i wasn't able to find the same example hex file with 20006.
But i realised that every DK has a PCA chip like the Nrf51422 DK had PCA10028, and the exampe that i wanted to run, was available with that hex,(10028)as mentioned above. So i replaced the Soc of my bluetooth beacon with nRF51422, which was previously nRF51822. i was expecting that now my code of 10028 would be running on the new modified beacon.
But to my suprise it didn't.
It's stilll working on codes of hex 20006.
Can you suggest me, how i can run that same example as mentioned above on the beacon.
  • There's only one example for the PCA20006 and that is the beacon example. The other examples uses the LEDs and buttons on the DKs that are not present on the PCA20006, the examples will therefore not work out of the box.
    The PCA20006 is discontinued btw, it is 6 years old. I'd rather recommend a beacon based on the nRF52810 as an alternative.
  • Is their anyway that i can design an example to control leds on PCA20006, using  an android application.
    So that, the lights could be turned on and off using an android application(just like the nrf blinky example).
    Is it possible to design examples like that are given on nrf infocenter.
    And if so, can you guide me how to do that.
  • /* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "bsp.h"
    #include "ble_gap.h"
    #define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define ADVERTISING_LED_PIN             BSP_LED_0_MASK                              /**< Is on when device is advertising. */
    #define CONNECTED_LED_PIN               BSP_LED_1_MASK                              /**< Is on when device has connected. */
    #define LEDBUTTON_LED_PIN               BSP_LED_2_MASK                              /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON_PIN            BSP_BUTTON_0                                /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "Nordic_Blinky"                             /**< Name of device. Will be included in the advertising data. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED       /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_MAX_TIMERS            6                                           /**< Maximum number of simultaneously created timers. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)            /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define APP_GPIOTE_MAX_USERS            1                                           /**< Maximum number of users of the GPIOTE handler. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50, APP_TIMER_PRESCALER)    /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static ble_lbs_t                        m_lbs;                                      /**< LED Button Service instance. */
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
        LEDS_CONFIGURE(ADVERTISING_LED_PIN | CONNECTED_LED_PIN | LEDBUTTON_LED_PIN);
        LEDS_OFF(ADVERTISING_LED_PIN | CONNECTED_LED_PIN | LEDBUTTON_LED_PIN);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        uint32_t                err_code;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        uint32_t      err_code;
        ble_advdata_t advdata;
        ble_advdata_t scanrsp;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_set(&advdata, &scanrsp);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            LEDS_ON(LEDBUTTON_LED_PIN);
            LEDS_OFF(LEDBUTTON_LED_PIN);
        uint32_t       err_code;
        ble_lbs_init_t init;
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling a Connection Parameters error.
        APP_ERROR_HANDLER(nrf_error);
        uint32_t             err_code;
        ble_gap_adv_params_t adv_params;
        // Start advertising
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.type        = BLE_GAP_ADV_TYPE_ADV_IND;
        adv_params.p_peer_addr = NULL;
        adv_params.fp          = BLE_GAP_ADV_FP_ANY;
        adv_params.interval    = APP_ADV_INTERVAL;
        adv_params.timeout     = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = sd_ble_gap_adv_start(&adv_params);
        LEDS_ON(ADVERTISING_LED_PIN);
    /**@brief Function for handling the Application's BLE stack events.
     * @param[in] p_ble_evt  Bluetooth stack event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                LEDS_ON(CONNECTED_LED_PIN);
                LEDS_OFF(ADVERTISING_LED_PIN);
                err_code = app_button_enable();
                LEDS_OFF(CONNECTED_LED_PIN);
                err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                // No implementation needed.
    /**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
     * @details This function is called from the scheduler in the main loop after a BLE stack
     *          event has been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        on_ble_evt(p_ble_evt);
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_lbs_on_ble_evt(&m_lbs, p_ble_evt);
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
        ble_gap_addr_t addr;
        err_code = sd_ble_gap_address_get(&addr);
        err_code = sd_ble_gap_address_set(BLE_GAP_ADDR_CYCLE_MODE_NONE, &addr);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        uint32_t err_code;
        switch (pin_no)
            case LEDBUTTON_BUTTON_PIN:
                err_code = ble_lbs_on_button_change(&m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        uint32_t err_code;
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]),
                                   BUTTON_DETECTION_DELAY);
    /**@brief Function for the Power Manager.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    /**@brief Function for application main entry.
        // Initialize.
        leds_init();
        timers_init();
        buttons_init();
        ble_stack_init();
        gap_params_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
            power_manage();
    I want to use this example on PCA20006, is it possible in anyway to generate a hex of this main file that is compatible to work with PCA2006.
  • You can build for PCA10028 (nRF51DK), but you need to change the pins for the buttons and leds to what's available on the PCA20006.
