My NUS services work fine i can transmit and receive data over UART , but i still get this error in my nRF Toolbox (UART) . Any help will apreciated
Which version of SDK are you using?
What did you modify the example project?
Could you enable the RTT log in the sdk_config.h and provide the log?
#ifndef NRF_LOG_BACKEND_RTT_ENABLED #define NRF_LOG_BACKEND_RTT_ENABLED 1 #endif
Could you also provide the sniff log?
This post might help.
-Amanda H.
Hello Amanda,
im using zephyr rtos and here the to creat GATT service
BT_GATT_SERVICE_DEFINE(nus_svc, BT_GATT_PRIMARY_SERVICE(&nus_base_uuid), BT_GATT_CHARACTERISTIC(&nus_tx_uuid.uuid, // TX from the point of view of the central BT_GATT_CHRC_WRITE, // central is allowed to write to tx BT_GATT_PERM_WRITE, NULL, bt_tx_callback, NULL), BT_GATT_CHARACTERISTIC(&nus_rx_uuid.uuid, // RX from point of view of central BT_GATT_CHRC_READ | BT_GATT_CHRC_NOTIFY, BT_GATT_PERM_READ, bt_rx_callback, NULL, NULL), BT_GATT_CCC(bt_uart_ccc_changed, BT_GATT_PERM_READ | BT_GATT_PERM_WRITE));
Hi Geek,
I cannot see any UUID values you are using, but I am guessing they are initialized properly?!
I think it might be a permission problem. You may take a look https://github.com/NordicPlayground/fw-nrfconnect-nrf/blob/master/subsys/bluetooth/services/nus.c#L47
/* UART Service Declaration */ BT_GATT_SERVICE_DEFINE(nus_svc, BT_GATT_PRIMARY_SERVICE(BT_UUID_NUS_SERVICE), BT_GATT_CHARACTERISTIC(BT_UUID_NUS_TX, BT_GATT_CHRC_NOTIFY, BT_GATT_PERM_READ, NULL, NULL, NULL), BT_GATT_CCC(NULL, BT_GATT_PERM_READ | BT_GATT_PERM_WRITE), BT_GATT_CHARACTERISTIC(BT_UUID_NUS_RX, BT_GATT_CHRC_WRITE | BT_GATT_CHRC_WRITE_WITHOUT_RESP, BT_GATT_PERM_READ | BT_GATT_PERM_WRITE, NULL, on_receive, NULL), );
-Amanda H.
