reading the fds issue
hi... i want to store data in flash , i will get the data periodically . Even i am writing data to flash using write command ,when i am trying to print the data which is stored in flash ,while printing the i am getting garbage value  . Here is my code  .. i am getting value like 0,72,123,0
 * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "nordic_common.h"
#ifdef SOFTDEVICE_PRESENT
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#else
#include "nrf_drv_clock.h"
#include "fds.h"
#include "app_timer.h"
#include "app_error.h"
#include "nrf_cli.h"
#include "fds_example.h"
#define NRF_LOG_MODULE_NAME app
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_CONN_CFG_TAG    1
/* Array to map FDS return values to strings. */
char const * fds_err_str[] =
    "FDS_SUCCESS",
    "FDS_ERR_OPERATION_TIMEOUT",
    "FDS_ERR_NOT_INITIALIZED",
    "FDS_ERR_UNALIGNED_ADDR",
    "FDS_ERR_INVALID_ARG",
    "FDS_ERR_NULL_ARG",
    "FDS_ERR_NO_OPEN_RECORDS",
    "FDS_ERR_NO_SPACE_IN_FLASH",
    "FDS_ERR_NO_SPACE_IN_QUEUES",
    "FDS_ERR_RECORD_TOO_LARGE",
    "FDS_ERR_NOT_FOUND",
    "FDS_ERR_NO_PAGES",
    "FDS_ERR_USER_LIMIT_REACHED",
    "FDS_ERR_CRC_CHECK_FAILED",
    "FDS_ERR_BUSY",
    "FDS_ERR_INTERNAL",
/* Array to map FDS events to strings. */
static char const * fds_evt_str[] =
    "FDS_EVT_INIT",
    "FDS_EVT_WRITE",
    "FDS_EVT_UPDATE",
    "FDS_EVT_DEL_RECORD",
    "FDS_EVT_DEL_FILE",
    "FDS_EVT_GC",
/* Dummy configuration data. */
static configuration_t m_dummy_cfg =
    .device_name = "999555",
/* A record containing dummy configuration data. */
static fds_record_t const m_dummy_record =
    .file_id           = CONFIG_FILE,
    .key               = CONFIG_REC_KEY,
    .data.p_data       = &m_dummy_cfg,
    /* The length of a record is always expressed in 4-byte units (words). */
    .data.length_words = (sizeof(m_dummy_cfg) + 3) / sizeof(uint32_t),
/* Keep track of the progress of a delete_all operation. */
static struct
    bool delete_next;   //!< Delete next record.
    bool pending;       //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete the next record.
} m_delete_all;
/* Flag to check fds initialization. */
static bool volatile m_fds_initialized;
static void fds_evt_handler(fds_evt_t const * p_evt)
    NRF_LOG_GREEN("Event: %s received (%s)",
                  fds_evt_str[p_evt->id],
                  fds_err_str[p_evt->result]);
    switch (p_evt->id)
        case FDS_EVT_INIT:
            if (p_evt->result == FDS_SUCCESS)
                m_fds_initialized = true;
        case FDS_EVT_WRITE:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id);
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
        } break;
        case FDS_EVT_DEL_RECORD:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
            m_delete_all.pending = false;
        } break;
/**@brief   Begin deleting all records, one by one. */
void delete_all_begin(void)
    m_delete_all.delete_next = true;
/**@brief   Process a delete all command.
 * Delete records, one by one, until no records are left.
void delete_all_process(void)
    if (   m_delete_all.delete_next
        & !m_delete_all.pending)
        NRF_LOG_INFO("Deleting next record.");
        m_delete_all.delete_next = record_delete_next();
        if (!m_delete_all.delete_next)
            NRF_LOG_CYAN("No records left to delete.");
/**@brief   Function for initializing the SoftDevice and enabling the BLE stack. */
    ret_code_t rc;
    uint32_t   ram_start;
    /* Enable the SoftDevice. */
    rc = nrf_sdh_enable_request();
    APP_ERROR_CHECK(rc);
    rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
    rc = nrf_sdh_ble_enable(&ram_start);
#else
static void clock_init(void)
    /* Initialize the clock. */
    ret_code_t rc = nrf_drv_clock_init();
    /* Wait for the clock to be ready. */
    while (!nrf_clock_lf_is_running()) {;}
/**@brief   Initialize the timer. */
static void timer_init(void)
/**@brief   Initialize logging. */
static void log_init(void)
    ret_code_t rc = NRF_LOG_INIT(NULL);
/**@brief   Sleep until an event is received. */
static void power_manage(void)
    (void) sd_app_evt_wait();
#else
    __WFE();
/**@brief   Wait for fds to initialize. */
static void wait_for_fds_ready(void)
    while (!m_fds_initialized)
        power_manage();
    ret_code_t rc;
    ble_stack_init();
#else
    clock_init();
    timer_init();
    log_init();
   cli_init();
    NRF_LOG_INFO("FDS example started.")
    /* Register first to receive an event when initialization is complete. */
    (void) fds_register(fds_evt_handler);
    NRF_LOG_INFO("Initializing fds...");
    rc = fds_init();
    /* Wait for fds to initialize. */
    wait_for_fds_ready();
    NRF_LOG_INFO("Available commands:");
    NRF_LOG_INFO("- print all\t\tprint records");
    NRF_LOG_INFO("- print config\tprint configuration");
    NRF_LOG_INFO("- update\t\tupdate configuration");
    NRF_LOG_INFO("- stat\t\tshow statistics");
    NRF_LOG_INFO("- write\t\twrite a new record");
    NRF_LOG_INFO("- delete\t\tdelete a record");
    NRF_LOG_INFO("- delete_all\tdelete all records");
    NRF_LOG_INFO("- gc\t\trun garbage collection");
    NRF_LOG_INFO("Reading flash usage statistics...");
    fds_stat_t stat = {0};
    rc = fds_stat(&stat);
    NRF_LOG_INFO("Found %d valid records.", stat.valid_records);
    NRF_LOG_INFO("Found %d dirty records (ready to be garbage collected).", stat.dirty_records);
    fds_record_desc_t desc = {0};
    fds_find_token_t  tok  = {0};
uint8_t *data;
    rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);
    if (rc == FDS_SUCCESS)
        /* A config file is in flash. Let's update it. */
        fds_flash_record_t config = {0};   //!< Location of the record data in flash.
        /* Open the record and read its contents. */
        rc = fds_record_open(&desc, &config); //last known locaton of the data in flash
        if ( rc != FDS_SUCCESS)
                                         printf("Data ");
					return rc;
				printf("Found Record ID = %d\r\n",desc.record_id);
                                data = (uint8_t ) config.p_data;
                                 printf("%d",data);
                                for (uint8_t i=3;i<config.p_header->length_words;i++)
                                    printf("data ");
                                       // printf("%d\n  data:",data[i]);
        /* Copy the configuration from flash into m_dummy_cfg. */
       // memcpy(&m_dummy_cfg, config.p_data, sizeof(configuration_t));
       // NRF_LOG_INFO("Config file found, updating boot count to %d.", m_dummy_cfg.boot_count);
        /* Update boot count. */
       // m_dummy_cfg.boot_count++;
        /* Close the record when done reading. */
        rc = fds_record_close(&desc);
        /* Write the updated record to flash. */
        rc = fds_record_update(&desc, &m_dummy_record);
        /* System config not found; write a new one. */
        NRF_LOG_INFO("Writing config file...");
        rc = fds_record_write(&desc, &m_dummy_record);
    cli_start();
    /* Enter main loop. */
    for (;;)
        if (!NRF_LOG_PROCESS())
            power_manage();
        cli_process();
        delete_all_process();
