HI:
I Use the Projtcet: "......\nRF5_SDK_15.3.0_59ac345\examples\ble_central\ble_app_uart_c".
In the BLE_Central project, how to set the Tx Power??
thank you very much!
HI:
hello haakonsh
uint32_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT,0, 3);
is this correct way to call sd_ble_gap_tx_power_set i am calling this before sfan_init
thanks and regards
manikandan v
Hi
Please check out this case, where my colleague Einar goes into detail on the sd_ble_gap_tx_power_set() function. For the central, you only need to set it once with the scanner/initiator role (BLE_GAP_TX_POWER_ROLE_SCAN_INIT), and then this is used for the connection as well unless you make a new call to sd_ble_gap_tx_power_set() with the BLE_GAP_TX_POWER_ROLE_CONN and a connection handle.
Simon
