Bluetooth Beacon Setup on Thingy 91
I am working on an IoT project using the Thingy 91 to send sensor data via Bluetooth to a remote device. Currently, I am trying to set up a simple beacon as shown in the Zephyr samples. I would like to set up the NRF9160 as the host and the NRF52 as the controller.
Therefore, I used the LTE/BLE example in the NRF samples and flashed the NRF52 with the patched HCI/UART sample provided in this post.
However, the system keeps crashing during HCI setup (in bt_enable). The error is due to a failing k_sem_take call (return value -11) in Zephyr's hci_core.c.
Is there some issue with the driver setup?
Best regards
Nils Ruf
  • Hi Øyvind,
    Unfortunately, since I have flashed the HCI-UART bridge example onto the NRF52, I have not been able to connect to the serial interface any more so I do not get any application output. Is there another way to obtain this information?
    I did one change to simplify debugging as shown below:
    void ble_init(void)
    	int err;
    	printk("Initializing Bluetooth..\n");
    	err = bt_enable(NULL);
    	if (err) {
    		printk("Bluetooth init failed (err %d)\n", err);
    		return;
    	ble_ready(err);
    Previously, the ble_ready function was passed as a callback to bt_enable. The ble_ready function should be called asynchronously after BLE initialization. This is however, not the case, so I tried it this way which leads to the error.
    If I pass the ble_ready function as a callback to bt_enable no error is thrown in the main thread but the device cannot be seen by a BLE scanner (I am trying to use the Thingy as a beacon).
    -Nils
  • Hello Øyvind,
    Bluetooth is now working properly. The error I posted above was actually due to the change I applied to the code. After turning the Thingy off, switching the debug switch to "NRF52", turning it back on and finally switching the debug switch back to "NRF91" I got my serial output back.
    The failing Bluetooth initialization could be fixed by adding the configuration option CONFIG_BT_PERIPHERAL=y to my prj.conf. After that, advertising and even connection management was working properly without hanging.
    Thank you very much for your help.
    Kind regards
    Nils
  • Very glad to hear, Nils!
    Have a great day!
    Øyvind
