using pynrfjprog to write data to flash
I have an issue about writing and reading data using flash area of nrf9160. I'm using the library of pynrfjprog and the following script for writing/reading data.
Script:
import argparse
from pynrfjprog import API
# Default settings
JLINK_SPEED_KHZ = 4000
DEFAULT_START_ADDR = "0x6F000"
DEFAULT_LENGTH = "0x4000"
DEFAULT_FILE_NAME = "jflashrw.bin"
def convert(str):
    if str.upper().startswith("0X"):
        return int(str, 16)
    else:
        return int(str)
if __name__ == '__main__':
    # Print banner
    print "JLink Flash read/write"
    # Parse arguments
    parser = argparse.ArgumentParser()
    parser.add_argument("action", choices=("read", "write"), nargs="?", default="read")
    parser.add_argument("--start", type=str, nargs="?", default=DEFAULT_START_ADDR)
    parser.add_argument("--length", type=str, nargs="?", default=DEFAULT_LENGTH)
    parser.add_argument("--file", type=str, nargs="?", default=DEFAULT_FILE_NAME)
    args = parser.parse_args()
    # Open connection to jlink
    nrfjprog = API.API('NRF91')
    nrfjprog.open()
    try:
        nrfjprog.connect_to_emu_without_snr(jlink_speed_khz=JLINK_SPEED_KHZ)
    except:
        print "No jlink detected!"
        exit()
    # Perform action
    if args.action == "read":
        # Read flash
        bin_data = nrfjprog.read(addr=convert(args.start), data_len=convert(args.length))
        # Write to file
        fh = open(args.file, "wb")
        fh.write(bytearray(bin_data))
        fh.close()
    else:
        # Read file
        fh = open(args.file, "rb")
        bin_data = bytearray(fh.read())
        fh.close()
        print len(bin_data), args.length
        # Write flash
        if convert(args.length) == len(bin_data):
            nrfjprog.write(addr=convert(args.start), data=bin_data, control=True)
        else:
            print "Number of bytes miss-match!"
    # Cleanup
    nrfjprog.close()
But, my written data and read data are different from each other. You can check my outputs.
Screenshot of terminal:
And this view is from text editor:
Do you have any idea about my issue? Thanks for your interest.
