Getting acknowledgement only from single node which is 1st connected
Thanks for the reply.
There is a difference that,
If I connect to node A, then I am able to control the elements on node B and vice versa, but I am not able to read state of elements on node B when connected node A.
The trial you suggested is already working on nRF Mesh App of iOS but not working in android.
Please tell me have you checked in android application of nRF Mesh App with Version : 2.1.4?
So that please guide us to identify the problem?
I actually used the same version. Could you please test again using unmodified light switch server example ?
I have checked it. Still it's not working.
Could you please give any other answer?
Thank you.
Hi Anaya,
Could you capture a screen recording to show what you did to test on the screen ? (from provisioning of the 2 boards until you start reading the state, please test with full erased of the chip before the test)
I captured my test here, please have a look:
Thank you for providing video.
I checked with same steps, it is working with original firmware.
But if I used a node with custom firmware, then the same problem occurred on android application, where as on iOS application this problem not occurred.
Please suggest the possible solution.
