Simple one shot ADC example
I'm trying to find simple ADC code for one shot modus as described in the documentation:
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.nrf52832.ps.v1.1%2Fsaadc.html
The question has been asked before (without any concrete answer):
https://devzone.nordicsemi.com/f/nordic-q-a/46716/simple-adc-code/184681#184681
Another here (but I don't understand/cannot follow the thread):
https://devzone.nordicsemi.com/f/nordic-q-a/7188/simple-thermistor-adc-reading
The SDK provides an example with SAADC, which I got to work fine.
The disadvantage is that this example is pretty complex and uses timers (which conflicts with other parts of my code which also need timers).
Also I'm not able to integrate this SAADC example into my project, I have the same problem as here:
https://devzone.nordicsemi.com/f/nordic-q-a/33850/nrf_section_iter-problem-with-sdk-15-and-armgcc/130057#130057
I do not understand "linker script file"?
But I also don't understand why the examples are so complex? Why is it extremely difficult to combine examples?
Simple Arduino example how to perform an analog read:
int analogPin = A3; // potentiometer wiper (middle terminal) connected to analog pin 3
                    // outside leads to ground and +5V
int val = 0;  // variable to store the value read
void setup() {
  Serial.begin(9600);           //  setup serial
void loop() {
  val = analogRead(analogPin);  // read the input pin
  Serial.println(val);          // debug value
I found this thread "Simple ADC read":
https://devzone.nordicsemi.com/f/nordic-q-a/19934/simple-analog-read-on-nrf52/77586#77586
And they point to an example on github:
github.com/.../main.c
The example doesn't give any output, so I updated the code a bit:
#include <stdio.h>
#include <nrf.h>
#include "boards.h"
#include "nrf_delay.h"
#include "nrf_drv_saadc.h"
#define VERSION_ADC      ((0 << 5) | (31 & 0x1F))    // P0.31
#define VERSION_EN       ((0 << 5) | (26 & 0x1F))    // P0.26
void version_enable_init() {
    nrf_gpio_cfg_output(VERSION_EN);
    nrf_gpio_pin_write(VERSION_EN,1);
  volatile int16_t result = 0;
  volatile float precise_result = 0;
  version_enable_init();
  nrf_delay_ms(100);
  printf("starting\n");
  // Start HFCLK from crystal oscillator, this will give the SAADC higher accuracy
  while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
  // Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/6 gain.
  NRF_SAADC->CH[0].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6    << SAADC_CH_CONFIG_GAIN_Pos) |
                            (SAADC_CH_CONFIG_MODE_SE         << SAADC_CH_CONFIG_MODE_Pos) |
                            (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
                            (SAADC_CH_CONFIG_RESN_Bypass     << SAADC_CH_CONFIG_RESN_Pos) |
                            (SAADC_CH_CONFIG_RESP_Bypass     << SAADC_CH_CONFIG_RESP_Pos) |
                            (SAADC_CH_CONFIG_TACQ_3us        << SAADC_CH_CONFIG_TACQ_Pos);
  // Configure the SAADC channel with VDD as positive input, no negative input(single ended).
  //NRF_SAADC->CH[0].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos;
  //NRF_SAADC->CH[0].PSELP = VERSION_ADC;
  NRF_SAADC->CH[0].PSELP = NRF_SAADC_INPUT_AIN7;
  NRF_SAADC->CH[0].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
  // Configure the SAADC resolution.
  NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos;
  // Configure result to be put in RAM at the location of "result" variable.
  NRF_SAADC->RESULT.MAXCNT = 1;
  NRF_SAADC->RESULT.PTR = (uint32_t)&result;
  // No automatic sampling, will trigger with TASKS_SAMPLE.
  NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
  // Enable SAADC (would capture analog pins if they were used in CH[0].PSELP)
  NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
  // Calibrate the SAADC (only needs to be done once in a while)
  NRF_SAADC->TASKS_CALIBRATEOFFSET = 1;
  while (NRF_SAADC->EVENTS_CALIBRATEDONE == 0);
  NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
  while (NRF_SAADC->STATUS == (SAADC_STATUS_STATUS_Busy <<SAADC_STATUS_STATUS_Pos));
  // Start the SAADC and wait for the started event.
  NRF_SAADC->TASKS_START = 1;
  while (NRF_SAADC->EVENTS_STARTED == 0);
  NRF_SAADC->EVENTS_STARTED = 0;
  // Do a SAADC sample, will put the result in the configured RAM buffer.
  NRF_SAADC->TASKS_SAMPLE = 1;
  while (NRF_SAADC->EVENTS_END == 0);
  NRF_SAADC->EVENTS_END = 0;
  // Convert the result to voltage
  // Result = [V(p) - V(n)] * GAIN/REFERENCE * 2^(RESOLUTION)
  // Result = (VDD - 0) * ((1/6) / 0.6) * 2^14
  // VDD = Result / 4551.1
  precise_result = (float)result / 4551.1f;
  printf("result: %0.2f\n",precise_result);
  precise_result; // to get rid of set but not used warning
  // Stop the SAADC, since it's not used anymore.
  NRF_SAADC->TASKS_STOP = 1;
  while (NRF_SAADC->EVENTS_STOPPED == 0);
  NRF_SAADC->EVENTS_STOPPED = 0;
  while (1)
    __WFE();
But the result is always 0 (or 3 when using VDD). Did I set the wrong ADC channel? I'm sure I need NRF_SAADC_INPUT_AIN7?
I'm sure it is possible to do a ADC read without timers, but how?
  • Philip, you seem to miss my point.
    You can remove saadc_sampling_event_init() and saadc_sampling_event_enable() from my main.c file, but you will have to call nrf_drv_saadc_sample() from somewhere.
    If I removed this from the file before sending it to you, I would be sending a project that does nothing.
    Try to remove those functions, and add nrf_drv_saadc_sample() to whatever event you want to trigger the sampling from.
