Dear,
I am working with THINGY91
ncs_1.2.0/Modem FW_1.1.1
SIMcard: Telia (LTE_M and NB-iot) / Horten.Vestfold.Norway
I am looking for information about AGPS, could you help?
Thanks
BR
Hoang
Dear,
Thanks
BR
Hoang
Hi Hoang, please create a new ticket for this issue as it's different than your initial problem.
But in the meantime, you can try to find out why this line is returning something other than 0, and perhaps try to find out what it is returning, which will tell you more. See the return values here for more information.
Heidi
Dear Heidi
I fixed it,
The problem came from: old Modem FW was using in my THINGY91
I updated the Modem FW_v1.1.1
But I got another problem, I will create a new ticket
** Boor[1B][1;1H[1B][2JNew AGPS data requested, contacting SUPL server, flags 59 Established LTE link ip 6cb1:fc0:: (c00fb16c) port 7276 Starting SUPL session ULP encoding length: 38 Bytes sent: 38 Bytes received: 34 ULP ossDecode success, choice 3 SUPL server responded using version 2.0.4 SUPL response received ULP encoding length: 57 Bytes sent: 57 Bytes received: 708 ULP ossDecode more input 4 Bytes received: 1416 ULP ossDecode more input 4 Bytes received: 2124 ULP ossDecode more input 4 Bytes received: 2832 ULP ossDecode more input 4 Bytes received: 2994 ULP ossDecode success, choice 5 Injected AGPS data, flags: 1, size: 16 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 2, size: 72 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 Injected AGPS data, flags: 3, size: 32 No integrity data available Injected AGPS data, flags: 4, size: 8 Injected AGPS data, flags: 6, size: 144 No location data available Injected AGPS data, flags: 7, size: 16 MCC location info injected, MCC: 242 Lat: 6407964 Lon: 715361 Unc semiminor: 127 Unc semimajor: 117 Confidence: 85 Orientation: 0 SUPL POS received read again read again read again read error: -1 ULP ossDecode fail 5 SUPL error: 1 ULP encoding length: 34 Sending SUPL message failed, bytes_sent: -1 SUPL session internal resources released SUPL session finished Done
My new ticket: https://devzone.nordicsemi.com/f/nordic-q-a/59034/agps_thingy91
Look like Telia SIMcard does NOT work
Thanks so much
