hi -- i'm a big fan of the NRF24L01+ chip, i've written a high-performance driver for it using most of the features, relying heavily on Dynamic Payload and Auto-acknowledgement. the driver code is here, GNU license: github.com/.../WPS_NRF24L01, in C++ for Arduino and TI Launchpad TM4C123. the code is currently working fine for both systems.
i am very comfortable using the NRF24L01+ in all of it's advertised modes without problem. i find no flaw in the chip, nor the documentation. the problem i have may very well be outside the capability of the chip, and i apologize if i am wasting your time because of this. but i feel like there is more performance available if i can solve this interesting addressing problem!
i have two questions, related. i will post question 2 separately, because it is more narrowly defined.
QUESTION 1:
i am attempting to use the chip in a peer-to-peer application (frequency-hopping scheme) that occasionally ends up with a link pair in PTX to PTX mode -- both simultaneously transmitting on the same channel/datarate/etc. this use is outside of the suggested application.
i am further "pushing my luck" by having each side of the link -- i will call them LEFT and RIGHT -- use a shared pair of pipe addresses, A and B. (I use here "A" and "B" to stand in for correct 5-byte addresses as suggested in the datasheet, because it is easier to type here). this system is working great except for the PTX to PTX case. For example:
LEFT NRF24L01+ TX_ADDR A RX_ADDR_P0 A RX_ADDR_P1 B
RIGHT NRF24L01+ TX_ADDR B RX_ADDR_P0 B RX_ADDR_P1 A
this works great, when LEFT is PTX and RIGHT is PRX, or the opposite, LEFT is PRX, and RIGHT is PTX. and of course there is no problem when both LEFT and RIGHT are both PRX -- no packet is received! (but my protocol times out).
the problem is when both LEFT and RIGHT are in PTX mode, and transmitting -- a FALSE POSITIVE AUTO-ACKNOWLEDGE is generated!
i am still analyzing the mechanism, but i believe that when (for example) the transmit packet from LEFT arrives in RIGHT's RX_ADDR_P0, it accepts this as the ACK packet signalling to RIGHT that its packet was acknowledged.
the "failure window" is wider than it would appear, in that any RF, on-air collision corrupting the packet then invokes re-transmission, and widens the "failure window" to (ARD * ARC) in time.
Nordic, do you think my analysis of my problem is correct? i will shortly attempt some solutions to this, but your input and insights would be greatly appreciated. my drivers are available for free at the URL above.
the NRF24L01+ is an amazing chip, of course i am not complaining here!
