There is a question about sniffer. I want to know if sniffer 3.0 hex can support ble 5.0
The current sniffer FW (the hex files that is flashed on the dongles/DKs) does not support sniffing 2MBPS or CODED_PHY, unfortunately. I believe this is a work in progress, but I don't have any input on when this will come.
Edvin
Hi Edvin,
Thank you for your reply. How to get the data under 2Mbps.
Ming
Hello Ming.
Right now, this is not possible using our sniffers. If you want to sniff the communication, then you need to stay on 1MBPS (during the development). When you are satisfied with the application, you can implement the request for 2MBPS.
May I ask whether there are any specific reason for why you need to sniff on 2MBPS? Do you just want to check that the link switch to 2MBPS? Or do you see any issues with the application after switching to 2MBPS? Do you suspect that this issue is related to the PHY? Or is it possible to reproduce it on 1MBPS?
Edvin
Hi Edvin.
It's a good idea.But it means that sniffer does not support the features of ble 5.0. In the process of Wireshark being used by me, it is found that extend adv cannot be recognized.
Ming
If by extended advertising, you mean advertising with 2MBPS or CODED_PHY (long range), then no, the nRF Sniffer can't be used for this, unfortunately.
