Hi
I have a really strange issue with an NRF52840. I'm using it with an MPU-9250 connected via TWI. I've modifed the excellent library:
https://github.com/Martinsbl/nrf5-mpu-examples
And have based my project on the nrf5-mpu-data-ready-interrupts example, with my own BLE custom Service and Characteristics.
All is working okay and data is being sent over BLE, only when I keep my hand close to the nrf52 (I assume its triggering the NFC sensor).
Any ideas, my code is attached, the reset is copied for the git-repository.
main.c
#include <stdbool.h> #include <stdint.h> #include <string.h> #include <stdint.h> #include <stdio.h> #include "nordic_common.h" #include "nrf.h" #include "app_error.h" #include "ble.h" #include "ble_hci.h" #include "ble_srv_common.h" #include "ble_advdata.h" #include "ble_advertising.h" #include "ble_conn_params.h" //OPTION BLE Service #include "srm_service.h" #include "nrf_sdh.h" #include "nrf_delay.h" #include "nrf_sdh_soc.h" #include "nrf_sdh_ble.h" #include "app_timer.h" #include "fds.h" #include "peer_manager.h" #include "bsp_btn_ble.h" #include "sensorsim.h" #include "ble_conn_state.h" #include "nrf_ble_gatt.h" #include "nrf_ble_qwr.h" #include "nrf_pwr_mgmt.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" //MPU-9250 #include "nrf_drv_gpiote.h" #include "app_mpu.h" #define MPU_MPU_INT_PIN 30 volatile bool mpu_data_ready = false; #define DEVICE_NAME "SRMotion" /**< Name of device. Will be included in the advertising data. */ #define MANUFACTURER_NAME "StingRay" /**< Manufacturer. Will be passed to Device Information Service. */ #define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */ #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */ #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */ #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */ #define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */ #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */ #define SLAVE_LATENCY 0 /**< Slave latency. */ #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ #define SEC_PARAM_BOND 1 /**< Perform bonding. */ #define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */ #define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */ #define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */ #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */ #define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */ #define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */ #define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */ #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */ NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */ NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/ BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */ /* Declare all services - BLE_XYZ_DEF(m_xyz); */ BLE_SRVC_OPT_DEF(m_srm_service); //Advertised Services static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */ { {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}, {BLE_SRM_SERVICE_UUID, BLE_UUID_TYPE_BLE}, }; //App Timers #define SERVICES_NOTIFICATION_INTERVAL APP_TIMER_TICKS(5000) /**< Time between updating Services Characteristics. */ #define RAWData_GET_INTERVAL APP_TIMER_TICKS(1000) /**< Time between updating RAW Data Characteristics. */ #define APP_TIMER_MAX_TIMERS 2; APP_TIMER_DEF(m_service_notification_timer_id); //APP_TIMER_DEF(m_rawdata_get_notification_timer_id); static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */ static void advertising_start(bool erase_bonds); //Device State typedef uint8_t m_srm_state_evt_type_t; enum { SR_IDLE = 0x00, SR_RUN = 0x01, SR_FAULT_UKN = 0x09, SR_FAULT_NO_MPU = 0xA1, SR_FAULT_MPU = 0xA2, SR_FAULT_TWI = 0xB1 }; typedef struct { m_srm_state_evt_type_t evt_type; } m_srm_state_type_t; static m_srm_state_type_t m_srm_state; //Device Command typedef uint8_t m_srm_cmd_evt_type_t; enum { SR_STOP = 0x00, SR_START = 0x01, }; typedef struct { m_srm_cmd_evt_type_t evt_type; } m_srm_cmd_type_t; static m_srm_cmd_type_t m_cmd_state; /**@brief Function for handling CMD request. */ static void handle_cmd_chr(ble_srvc_opt_t *p_service) { uint32_t err_code; ble_gatts_value_t t_value; t_value.p_value = &m_cmd_state.evt_type; t_value.len = 1; t_value.offset = 0; err_code = sd_ble_gatts_value_get(p_service->conn_handle, p_service->cmd_char_handle.value_handle, &t_value); APP_ERROR_CHECK(err_code); switch (m_cmd_state.evt_type) { case SR_STOP: NRF_LOG_INFO("CMD Data = STOP"); m_srm_state.evt_type = SR_IDLE; err_code = ble_srvc_set_state(p_service, m_srm_state.evt_type); APP_ERROR_CHECK(err_code); break; case SR_START: NRF_LOG_INFO("CMD Data = RUN"); m_srm_state.evt_type = SR_RUN; err_code = ble_srvc_set_state(p_service, m_srm_state.evt_type); APP_ERROR_CHECK(err_code); break; default: NRF_LOG_INFO("CMD Data = UKN"); break; } } /**@brief Function for handling SRM BLE Service events. */ static void on_ble_srm_service_evt(ble_srvc_opt_t *p_cus_service, ble_srvc_opt_evt_t *p_evt) { //m_setget t_value; uint32_t err_code; switch (p_evt->evt_type) { case BLE_SRVC_EVT_STATE_NOTIFICATION_ENABLED: NRF_LOG_INFO("BLE_SRVC_EVT_STATE_NOTIFICATION_ENABLED"); break; case BLE_SRVC_EVT_STATE_NOTIFICATION_DISABLED: NRF_LOG_INFO("BLE_SRVC_EVT_STATE_NOTIFICATION_DISABLED"); break; case BLE_SRVC_EVT_CONNECTED: NRF_LOG_INFO("BLE_SRVC_OPT_EVT_CONNECTED"); ble_gatts_value_t t_value; t_value.p_value = &m_srm_state.evt_type; t_value.len = 1; t_value.offset = 0; err_code = sd_ble_gatts_value_set(p_cus_service->conn_handle, p_cus_service->state_char_handle.value_handle, &t_value); APP_ERROR_CHECK(err_code); break; case BLE_SRVC_EVT_DISCONNECTED: NRF_LOG_INFO("BLE_SRVC_OPT_EVT_DISCONNECTED"); break; case BLE_SRVC_EVT_STATE_CHAR_WRITE: //Should never happen as State is READ ONLY NRF_LOG_INFO("BLE_SRVC_EVT_STATE_CHAR_WRITE - Should not happen as READ ONLY"); break; case BLE_SRVC_EVT_CMD_CHAR_WRITE: NRF_LOG_INFO("BLE_SRVC_EVT_CMD_CHAR_WRITE"); handle_cmd_chr(p_cus_service); break; default: // No implementation needed. break; } } /**@brief Callback function for asserts in the SoftDevice. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyze * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) { app_error_handler(DEAD_BEEF, line_num, p_file_name); } /**@brief Function for handling Peer Manager events. * * @param[in] p_evt Peer Manager event. */ static void pm_evt_handler(pm_evt_t const *p_evt) { ret_code_t err_code; switch (p_evt->evt_id) { case PM_EVT_BONDED_PEER_CONNECTED: { NRF_LOG_INFO("Connected to a previously bonded device."); } break; case PM_EVT_CONN_SEC_SUCCEEDED: { NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.", ble_conn_state_role(p_evt->conn_handle), p_evt->conn_handle, p_evt->params.conn_sec_succeeded.procedure); } break; case PM_EVT_CONN_SEC_FAILED: { /* Often, when securing fails, it shouldn't be restarted, for security reasons. * Other times, it can be restarted directly. * Sometimes it can be restarted, but only after changing some Security Parameters. * Sometimes, it cannot be restarted until the link is disconnected and reconnected. * Sometimes it is impossible, to secure the link, or the peer device does not support it. * How to handle this error is highly application dependent. */ } break; case PM_EVT_CONN_SEC_CONFIG_REQ: { // Reject pairing request from an already bonded peer. pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false}; pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config); } break; case PM_EVT_STORAGE_FULL: { // Run garbage collection on the flash. err_code = fds_gc(); if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES) { // Retry. } else { APP_ERROR_CHECK(err_code); } } break; case PM_EVT_PEERS_DELETE_SUCCEEDED: { advertising_start(false); } break; case PM_EVT_PEER_DATA_UPDATE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error); } break; case PM_EVT_PEER_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error); } break; case PM_EVT_PEERS_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error); } break; case PM_EVT_ERROR_UNEXPECTED: { // Assert. APP_ERROR_CHECK(p_evt->params.error_unexpected.error); } break; case PM_EVT_CONN_SEC_START: case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED: case PM_EVT_PEER_DELETE_SUCCEEDED: case PM_EVT_LOCAL_DB_CACHE_APPLIED: case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED: // This can happen when the local DB has changed. case PM_EVT_SERVICE_CHANGED_IND_SENT: case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED: default: break; } } /**@brief Function for handling the Battery measurement timer timeout. * * @details This function will be called each time the battery level measurement timer expires. * * @param[in] p_context Pointer used for passing some arbitrary information (context) from the * app_start_timer() call to the timeout handler. */ static void services_state_timeout_handler(void *p_context) { UNUSED_PARAMETER(p_context); ret_code_t err_code; // Increment the value of m_custom_value before nortifing it. err_code = ble_srvc_opt_custom_value_update(&m_srm_service, m_srm_state.evt_type); APP_ERROR_CHECK(err_code); } /**@brief Function for the Timer initialization. * * @details Initializes the timer module. This creates and starts application timers. */ static void timers_init(void) { // Initialize timer module. ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); // Create timers. /* YOUR_JOB: Create any timers to be used by the application. Below is an example of how to create a timer. For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by one. ret_code_t err_code; err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler); APP_ERROR_CHECK(err_code); */ err_code = app_timer_create(&m_service_notification_timer_id, APP_TIMER_MODE_REPEATED, services_state_timeout_handler); APP_ERROR_CHECK(err_code); //err_code = app_timer_create(&m_rawdata_get_notification_timer_id, APP_TIMER_MODE_REPEATED, rawdata_get_timeout_handler); //APP_ERROR_CHECK(err_code); } /**@brief Function for the GAP initialization. * * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the * device including the device name, appearance, and the preferred connection parameters. */ static void gap_params_init(void) { ret_code_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)); APP_ERROR_CHECK(err_code); /* YOUR_JOB: Use an appearance value matching the application's use case. err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_); APP_ERROR_CHECK(err_code); */ memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); ble_gap_privacy_params_t prvt_conf; memset(&prvt_conf, 0, sizeof(prvt_conf)); prvt_conf.privacy_mode = BLE_GAP_PRIVACY_MODE_DEVICE_PRIVACY; prvt_conf.private_addr_type = BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE ; prvt_conf.private_addr_cycle_s = 0; err_code = sd_ble_gap_privacy_set(&prvt_conf); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the GATT module. */ static void gatt_init(void) { ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL); APP_ERROR_CHECK(err_code); } /**@brief Function for handling Queued Write Module errors. * * @details A pointer to this function will be passed to each service which may need to inform the * application about an error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void nrf_qwr_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing services that will be used by the application. */ static void services_init(void) { ret_code_t err_code; nrf_ble_qwr_init_t qwr_init = {0}; // Initialize Queued Write Module. qwr_init.error_handler = nrf_qwr_error_handler; err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init); APP_ERROR_CHECK(err_code); /* YOUR_JOB: Add code to initialize the services used by the application. ble_xxs_init_t xxs_init; ble_yys_init_t yys_init; // Initialize XXX Service. memset(&xxs_init, 0, sizeof(xxs_init)); xxs_init.evt_handler = NULL; xxs_init.is_xxx_notify_supported = true; xxs_init.ble_xx_initial_value.level = 100; err_code = ble_bas_init(&m_xxs, &xxs_init); APP_ERROR_CHECK(err_code); // Initialize YYY Service. memset(&yys_init, 0, sizeof(yys_init)); yys_init.evt_handler = on_yys_evt; yys_init.ble_yy_initial_value.counter = 0; err_code = ble_yy_service_init(&yys_init, &yy_init); APP_ERROR_CHECK(err_code); */ //Option Services ble_srvc_opt_init_t srvc_opt_init; // Initialize CUS Service init structure to zero. memset(&srvc_opt_init, 0, sizeof(srvc_opt_init)); // Set the cus event handler srvc_opt_init.evt_handler = on_ble_srm_service_evt; err_code = ble_srvc_opt_init(&m_srm_service, &srvc_opt_init); APP_ERROR_CHECK(err_code); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&srvc_opt_init.custom_value_char_attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&srvc_opt_init.custom_value_char_attr_md.write_perm); } /**@brief Function for handling the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module which * are passed to the application. * @note All this function does is to disconnect. This could have been done by simply * setting the disconnect_on_fail config parameter, but instead we use the event * handler mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) { ret_code_t err_code; if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } } /**@brief Function for handling a Connection Parameters error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { ret_code_t err_code; ble_conn_params_init_t cp_init; memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID; cp_init.disconnect_on_fail = false; cp_init.evt_handler = on_conn_params_evt; cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } /**@brief Function for starting timers. */ static void application_timers_start(void) { /* YOUR_JOB: Start your timers. below is an example of how to start a timer. ret_code_t err_code; err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL); APP_ERROR_CHECK(err_code); */ } /**@brief Function for putting the chip into sleep mode. * * @note This function will not return. */ static void sleep_mode_enter(void) { ret_code_t err_code; err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); // Prepare wakeup buttons. err_code = bsp_btn_ble_sleep_mode_prepare(); APP_ERROR_CHECK(err_code); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling advertising events. * * @details This function will be called for advertising events which are passed to the application. * * @param[in] ble_adv_evt Advertising event. */ static void on_adv_evt(ble_adv_evt_t ble_adv_evt) { ret_code_t err_code; switch (ble_adv_evt) { case BLE_ADV_EVT_FAST: NRF_LOG_INFO("Fast advertising."); err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); APP_ERROR_CHECK(err_code); break; case BLE_ADV_EVT_IDLE: sleep_mode_enter(); break; default: break; } } /**@brief Function for handling BLE events. * * @param[in] p_ble_evt Bluetooth stack event. * @param[in] p_context Unused. */ static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) { ret_code_t err_code = NRF_SUCCESS; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected."); // LED indication will be changed when advertising starts. break; case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected."); err_code = bsp_indication_set(BSP_INDICATE_CONNECTED); APP_ERROR_CHECK(err_code); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. NRF_LOG_DEBUG("GATT - BLE_GATTC_EVT_TIMEOUT."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. NRF_LOG_DEBUG("GATT - BLE_GATTS_EVT_TIMEOU."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_SYS_ATTR_MISSING: NRF_LOG_DEBUG("GATT -BLE_GATTS_EVT_SYS_ATTR_MISSING."); err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0); APP_ERROR_CHECK(err_code); break; default: // No implementation needed. break; } } /**@brief Function for initializing the BLE stack. * * @details Initializes the SoftDevice and the BLE event interrupt. */ static void ble_stack_init(void) { ret_code_t err_code; err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); } /**@brief Function for the Peer Manager initialization. */ static void peer_manager_init(void) { ble_gap_sec_params_t sec_param; ret_code_t err_code; err_code = pm_init(); APP_ERROR_CHECK(err_code); memset(&sec_param, 0, sizeof(ble_gap_sec_params_t)); // Security parameters to be used for all security procedures. sec_param.bond = SEC_PARAM_BOND; sec_param.mitm = SEC_PARAM_MITM; sec_param.lesc = SEC_PARAM_LESC; sec_param.keypress = SEC_PARAM_KEYPRESS; sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES; sec_param.oob = SEC_PARAM_OOB; sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE; sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE; sec_param.kdist_own.enc = 1; sec_param.kdist_own.id = 1; sec_param.kdist_peer.enc = 1; sec_param.kdist_peer.id = 1; err_code = pm_sec_params_set(&sec_param); APP_ERROR_CHECK(err_code); err_code = pm_register(pm_evt_handler); APP_ERROR_CHECK(err_code); } /**@brief Clear bond information from persistent storage. */ static void delete_bonds(void) { ret_code_t err_code; NRF_LOG_INFO("Erase bonds!"); err_code = pm_peers_delete(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling events from the BSP module. * * @param[in] event Event generated when button is pressed. */ static void bsp_event_handler(bsp_event_t event) { ret_code_t err_code; switch (event) { case BSP_EVENT_SLEEP: sleep_mode_enter(); break; // BSP_EVENT_SLEEP case BSP_EVENT_DISCONNECT: err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } break; // BSP_EVENT_DISCONNECT case BSP_EVENT_WHITELIST_OFF: if (m_conn_handle == BLE_CONN_HANDLE_INVALID) { err_code = ble_advertising_restart_without_whitelist(&m_advertising); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } } break; // BSP_EVENT_KEY_0 default: break; } } /**@brief Function for initializing the Advertising functionality. */ static void advertising_init(void) { ret_code_t err_code; ble_advertising_init_t init; memset(&init, 0, sizeof(init)); init.advdata.name_type = BLE_ADVDATA_SHORT_NAME; init.advdata.short_name_len = 3; init.advdata.include_appearance = true; init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]); init.advdata.uuids_complete.p_uuids = m_adv_uuids; //int8_t tx_power = -4;// Set Power Level //init.advdata.p_tx_power_level = &tx_power; ble_advdata_manuf_data_t manuf_data; //Variable to hold manufacturer specific data uint8_t data[] = MANUFACTURER_NAME; //Our data to advertise manuf_data.company_identifier = 0x0059; //Nordics company ID manuf_data.data.p_data = data; manuf_data.data.size = sizeof(data); init.advdata.p_manuf_specific_data = &manuf_data; ble_advdata_manuf_data_t manuf_data_response; uint8_t data_response[] = MANUFACTURER_NAME; manuf_data_response.company_identifier = 0x0059; manuf_data_response.data.p_data = data_response; manuf_data_response.data.size = sizeof(data_response); init.srdata.name_type = BLE_ADVDATA_NO_NAME; init.srdata.p_manuf_specific_data = &manuf_data_response; init.config.ble_adv_fast_enabled = true; init.config.ble_adv_fast_interval = APP_ADV_INTERVAL; init.config.ble_adv_fast_timeout = APP_ADV_DURATION; init.evt_handler = on_adv_evt; err_code = ble_advertising_init(&m_advertising, &init); APP_ERROR_CHECK(err_code); ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG); } /**@brief Function for initializing buttons and leds. * * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up. */ static void buttons_leds_init(bool *p_erase_bonds) { ret_code_t err_code; bsp_event_t startup_event; err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler); APP_ERROR_CHECK(err_code); err_code = bsp_btn_ble_init(NULL, &startup_event); APP_ERROR_CHECK(err_code); *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA); } /**@brief Function for initializing the nrf log module. */ static void log_init(void) { ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_DEFAULT_BACKENDS_INIT(); } /**@brief Function for initializing power management. */ static void power_management_init(void) { ret_code_t err_code; err_code = nrf_pwr_mgmt_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the idle state (main loop). * * @details If there is no pending log operation, then sleep until next the next event occurs. */ static void idle_state_handle(void) { if (NRF_LOG_PROCESS() == false) { nrf_pwr_mgmt_run(); } } /**@brief Function for starting advertising. */ static void advertising_start(bool erase_bonds) { if (erase_bonds == true) { delete_bonds(); // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event } else { ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); } } void mpu_init(void) { uint32_t err_code; // Initiate MPU driver err_code = app_mpu_init(); APP_ERROR_CHECK(err_code); // Check for errors in return value // Setup and configure the MPU with intial values app_mpu_config_t p_mpu_config = MPU_DEFAULT_CONFIG(); // Load default values p_mpu_config.smplrt_div = 199; // Change sampelrate. Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV). 199 gives a sample rate of 5Hz p_mpu_config.accel_config.afs_sel = AFS_2G; // Set accelerometer full scale range to 2G err_code = app_mpu_config(&p_mpu_config); // Configure the MPU with above values APP_ERROR_CHECK(err_code); // Check for errors in return value // This is a way to configure the interrupt pin behaviour app_mpu_int_pin_cfg_t p_int_pin_cfg = MPU_DEFAULT_INT_PIN_CONFIG(); // Default configurations p_int_pin_cfg.int_rd_clear = 1; // When this bit is equal to 1, interrupt status bits are cleared on any read operation err_code = app_mpu_int_cfg_pin(&p_int_pin_cfg); // Configure pin behaviour APP_ERROR_CHECK(err_code); // Check for errors in return value // Enable the MPU interrupts app_mpu_int_enable_t p_int_enable = MPU_DEFAULT_INT_ENABLE_CONFIG(); p_int_enable.data_rdy_en = 1; // Trigger interrupt everytime new sensor values are available err_code = app_mpu_int_enable(&p_int_enable); // Configure interrupts APP_ERROR_CHECK(err_code); // Check for errors in return value } /** * @brief Simple interrupt handler setting a flag indicating that data is ready * */ void int_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) { mpu_data_ready = true; } /** * @brief Function for initiating the GPIOTE module and enable the * nRF5 to trigger an interrupt on a Low-To-High event on pin MPU_MPU_INT_PIN * */ static void gpiote_init(void) { uint32_t err_code; if (!nrf_drv_gpiote_is_init()) { err_code = nrf_drv_gpiote_init(); APP_ERROR_CHECK(err_code); } nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true); err_code = nrf_drv_gpiote_in_init(MPU_MPU_INT_PIN, &in_config, int_pin_handler); APP_ERROR_CHECK(err_code); nrf_drv_gpiote_in_event_enable(MPU_MPU_INT_PIN, true); } /**@brief Function for the Power manager. */ static void power_manage(void) { ret_code_t err_code = sd_app_evt_wait(); APP_ERROR_CHECK(err_code); } /**@brief Function for application main entry. */ int main(void) { //init State m_srm_state.evt_type = SR_IDLE; bool erase_bonds; // Initialize. log_init(); timers_init(); buttons_leds_init(&erase_bonds); power_management_init(); ble_stack_init(); gap_params_init(); gatt_init(); services_init(); advertising_init(); conn_params_init(); peer_manager_init(); gpiote_init(); mpu_init(); // Start execution. NRF_LOG_INFO("SRMotion started!!"); application_timers_start(); advertising_start(erase_bonds); uint32_t err_code; accel_values_t accel_values; // Enter main loop. for (;;) { if (NRF_LOG_PROCESS() == false) { power_manage(); if ((mpu_data_ready == true) && (m_srm_state.evt_type == SR_RUN)) { // Read accelerometer data. err_code = app_mpu_read_accel(&accel_values); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("Accel: %05d, %05d, %05d, 0x%04X, 0x%04X, 0x%04X", accel_values.x, accel_values.y, accel_values.z, accel_values.x, accel_values.y, accel_values.z); mpu_data_ready = false; /** * START - Test Send Function remove once working **/ if (&m_srm_service == NULL) {return NRF_ERROR_NULL;} uint32_t err_code = NRF_SUCCESS; //Setup the value to send ble_gatts_value_t t_value; uint8_t accvalues[6] = {accel_values.x, accel_values.y, accel_values.z, accel_values.x, accel_values.y, accel_values.z}; //uint8_t value[1] = {0xAA}; t_value.p_value = accvalues; t_value.len = 1; t_value.offset = 0; //setup the notification event ble_gatts_hvx_params_t hvx_params; memset(&hvx_params, 0, sizeof(hvx_params)); hvx_params.handle = m_srm_service.data_char_handle.value_handle; hvx_params.type = BLE_GATT_HVX_NOTIFICATION; hvx_params.offset = t_value.offset; hvx_params.p_len = &t_value.len; //Set value err_code = sd_ble_gatts_value_set(m_srm_service.conn_handle, m_srm_service.data_char_handle.value_handle, &t_value); APP_ERROR_CHECK(err_code); //Set notification if ((m_srm_service.conn_handle != BLE_CONN_HANDLE_INVALID)) { hvx_params.p_data = t_value.p_value; err_code = sd_ble_gatts_hvx(m_srm_service.conn_handle, &hvx_params); } else { err_code = NRF_ERROR_INVALID_STATE; } /** * END - Test Send Function remove once working **/ mpu_data_ready = false; } } } }
srm_service.h
srm_service.c
#include "sdk_common.h" #include "ble_srv_common.h" #include "srm_service.h" #include <string.h> #include "nrf_gpio.h" #include "boards.h" #include "nrf_log.h" #include "app_mpu.h" static const uint8_t state_char_name[] = "State"; static const uint8_t cmd_char_name[] = "Command"; static const uint8_t data_char_name[] = "Data"; /**@brief Function for initializing the Custom Service. * * @param[out] p_cus Custom Service structure. This structure will have to be supplied by * the application. It will be initialized by this function, and will later * be used to identify this particular service instance. * @param[in] p_srvc_opt_init Information needed to initialize the service. * * @return NRF_SUCCESS on successful initialization of service, otherwise an error code. */ //Function for setting the State Characteristic uint32_t ble_srvc_set_state(ble_srvc_opt_t *p_service, uint8_t state_value) { if (p_service == NULL) {return NRF_ERROR_NULL;} uint32_t err_code = NRF_SUCCESS; //Setup the value to send ble_gatts_value_t t_value; t_value.p_value = &state_value; t_value.len = 1; t_value.offset = 0; //setup the notification event ble_gatts_hvx_params_t hvx_params; memset(&hvx_params, 0, sizeof(hvx_params)); hvx_params.handle = p_service->state_char_handle.value_handle; hvx_params.type = BLE_GATT_HVX_NOTIFICATION; hvx_params.offset = t_value.offset; hvx_params.p_len = &t_value.len; //Set value err_code = sd_ble_gatts_value_set(p_service->conn_handle, p_service->state_char_handle.value_handle, &t_value); APP_ERROR_CHECK(err_code); //Set notification if ((p_service->conn_handle != BLE_CONN_HANDLE_INVALID)) { hvx_params.p_data = t_value.p_value; err_code = sd_ble_gatts_hvx(p_service->conn_handle, &hvx_params); } else { err_code = NRF_ERROR_INVALID_STATE; } return err_code; } uint32_t ble_srvc_opt_custom_value_update(ble_srvc_opt_t *p_cus, uint8_t custom_value) { NRF_LOG_INFO("In ble_srvc_opt_custom_value_update. \r\n"); if (p_cus == NULL) { return NRF_ERROR_NULL; } uint32_t err_code = NRF_SUCCESS; ble_gatts_value_t gatts_value; // Initialize value struct. memset(&gatts_value, 0, sizeof(gatts_value)); gatts_value.len = sizeof(uint8_t); gatts_value.offset = 0; gatts_value.p_value = &custom_value; // Update database. err_code = sd_ble_gatts_value_set(p_cus->conn_handle, p_cus->state_char_handle.value_handle, &gatts_value); if (err_code != NRF_SUCCESS) { return err_code; } // Send value if connected and notifying. if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID)) { ble_gatts_hvx_params_t hvx_params; memset(&hvx_params, 0, sizeof(hvx_params)); hvx_params.handle = p_cus->state_char_handle.value_handle; hvx_params.type = BLE_GATT_HVX_NOTIFICATION; hvx_params.offset = gatts_value.offset; hvx_params.p_len = &gatts_value.len; hvx_params.p_data = gatts_value.p_value; err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params); } else { err_code = NRF_ERROR_INVALID_STATE; } return err_code; } //Adding the State Characteristic static uint32_t state_char_add(ble_srvc_opt_t *p_cus, const ble_srvc_opt_init_t *p_srvc_opt_init, uint16_t uuid) { uint32_t err_code; ble_gatts_char_md_t char_md; ble_gatts_attr_md_t cccd_md; ble_gatts_attr_t attr_char_value; ble_uuid_t ble_uuid; ble_gatts_attr_md_t attr_md; memset(&char_md, 0, sizeof(char_md)); char_md.char_props.read = 1; char_md.char_props.write = 0; char_md.char_props.notify = 1; char_md.p_char_user_desc = state_char_name; char_md.char_user_desc_size = sizeof(state_char_name); char_md.char_user_desc_max_size = sizeof(state_char_name); char_md.p_char_pf = NULL; char_md.p_user_desc_md = NULL; char_md.p_cccd_md = NULL; char_md.p_sccd_md = NULL; memset(&attr_md, 0, sizeof(attr_md)); attr_md.read_perm = p_srvc_opt_init->custom_value_char_attr_md.read_perm; attr_md.write_perm = p_srvc_opt_init->custom_value_char_attr_md.write_perm; attr_md.vloc = BLE_GATTS_VLOC_STACK; attr_md.rd_auth = 0; attr_md.wr_auth = 0; attr_md.vlen = 0; ble_uuid.type = p_cus->uuid_type; ble_uuid.uuid = BLE_SRM_STATE_CHAR_UUID; //ble_uuid.uuid = uuid; memset(&attr_char_value, 0, sizeof(attr_char_value)); attr_char_value.p_uuid = &ble_uuid; attr_char_value.p_attr_md = &attr_md; attr_char_value.init_len = sizeof(uint8_t); attr_char_value.init_offs = 0; attr_char_value.max_len = sizeof(uint8_t); uint8_t value[1] = {0x00}; attr_char_value.p_value = value; memset(&cccd_md, 0, sizeof(cccd_md)); // Read operation on Cccd should be possible without authentication. BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm); cccd_md.vloc = BLE_GATTS_VLOC_STACK; char_md.p_cccd_md = &cccd_md; err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md, &attr_char_value, &p_cus->state_char_handle); if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } //Adding the Command Characteristic static uint32_t cmd_char_add(ble_srvc_opt_t *p_cus, const ble_srvc_opt_init_t *p_srvc_opt_init, uint16_t uuid) { uint32_t err_code; ble_gatts_char_md_t char_md; ble_gatts_attr_md_t cccd_md; ble_gatts_attr_t attr_char_value; ble_uuid_t ble_uuid; ble_gatts_attr_md_t attr_md; memset(&char_md, 0, sizeof(char_md)); char_md.char_props.read = 1; char_md.char_props.write = 1; char_md.char_props.notify = 0; char_md.p_char_user_desc = cmd_char_name; char_md.char_user_desc_size = sizeof(cmd_char_name); char_md.char_user_desc_max_size = sizeof(cmd_char_name); char_md.p_char_pf = NULL; char_md.p_user_desc_md = NULL; char_md.p_cccd_md = NULL; char_md.p_sccd_md = NULL; memset(&attr_md, 0, sizeof(attr_md)); attr_md.read_perm = p_srvc_opt_init->custom_value_char_attr_md.read_perm; attr_md.write_perm = p_srvc_opt_init->custom_value_char_attr_md.write_perm; attr_md.vloc = BLE_GATTS_VLOC_STACK; attr_md.rd_auth = 0; attr_md.wr_auth = 0; attr_md.vlen = 0; ble_uuid.type = p_cus->uuid_type; ble_uuid.uuid = BLE_SRM_CMD_CHAR_UUID; memset(&attr_char_value, 0, sizeof(attr_char_value)); attr_char_value.p_uuid = &ble_uuid; attr_char_value.p_attr_md = &attr_md; attr_char_value.init_len = sizeof(uint8_t); attr_char_value.init_offs = 0; attr_char_value.max_len = sizeof(uint8_t); uint8_t value[1] = {0x00}; attr_char_value.p_value = value; memset(&cccd_md, 0, sizeof(cccd_md)); // Read operation on Cccd should be possible without authentication. BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm); cccd_md.vloc = BLE_GATTS_VLOC_STACK; char_md.p_cccd_md = &cccd_md; err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md, &attr_char_value, &p_cus->cmd_char_handle); if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } //Adding the Data Characteristic static uint32_t data_char_add(ble_srvc_opt_t *p_cus, const ble_srvc_opt_init_t *p_srvc_opt_init, uint16_t uuid) { uint32_t err_code; ble_gatts_char_md_t char_md; ble_gatts_attr_md_t cccd_md; ble_gatts_attr_t attr_char_value; ble_uuid_t ble_uuid; ble_gatts_attr_md_t attr_md; memset(&char_md, 0, sizeof(char_md)); char_md.char_props.read = 1; char_md.char_props.write = 0; char_md.char_props.notify = 1; char_md.p_char_user_desc = data_char_name; char_md.char_user_desc_size = sizeof(data_char_name); char_md.char_user_desc_max_size = sizeof(data_char_name); char_md.p_char_pf = NULL; char_md.p_user_desc_md = NULL; char_md.p_cccd_md = NULL; char_md.p_sccd_md = NULL; memset(&attr_md, 0, sizeof(attr_md)); attr_md.read_perm = p_srvc_opt_init->custom_value_char_attr_md.read_perm; attr_md.write_perm = p_srvc_opt_init->custom_value_char_attr_md.write_perm; attr_md.vloc = BLE_GATTS_VLOC_STACK; attr_md.rd_auth = 0; attr_md.wr_auth = 0; attr_md.vlen = 0; ble_uuid.type = p_cus->uuid_type; ble_uuid.uuid = BLE_SRM_CMD_CHAR_UUID; memset(&attr_char_value, 0, sizeof(attr_char_value)); attr_char_value.p_uuid = &ble_uuid; attr_char_value.p_attr_md = &attr_md; attr_char_value.init_len = sizeof(data_values_t); //attr_char_value.init_offs = 0; attr_char_value.max_len = sizeof(data_values_t); uint8_t value[8] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08}; attr_char_value.p_value = value; memset(&cccd_md, 0, sizeof(cccd_md)); // Read operation on Cccd should be possible without authentication. BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm); cccd_md.vloc = BLE_GATTS_VLOC_STACK; char_md.p_cccd_md = &cccd_md; err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md, &attr_char_value, &p_cus->data_char_handle); if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } //Initialise the Service and add the Characteristics uint32_t ble_srvc_opt_init(ble_srvc_opt_t *p_cus, const ble_srvc_opt_init_t *p_srvc_opt_init) { if (p_cus == NULL || p_srvc_opt_init == NULL) { return NRF_ERROR_NULL; } uint32_t err_code; ble_uuid_t ble_uuid; uint16_t cus_char_uuid; // Initialize service structure p_cus->evt_handler = p_srvc_opt_init->evt_handler; p_cus->conn_handle = BLE_CONN_HANDLE_INVALID; // Add Custom Service UUID ble_uuid128_t base_uuid = {BLE_SRM_SERVICE_BASE_UUID}; err_code = sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type); VERIFY_SUCCESS(err_code); ble_uuid.type = p_cus->uuid_type; ble_uuid.uuid = BLE_SRM_SERVICE_UUID; // Add the Custom Service err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle); if (err_code != NRF_SUCCESS) { return err_code; } // Add the State Characteristic err_code = state_char_add(p_cus, p_srvc_opt_init, cus_char_uuid); if (err_code != NRF_SUCCESS) { return err_code; } // Add the Command Characteristic err_code = cmd_char_add(p_cus, p_srvc_opt_init, cus_char_uuid); if (err_code != NRF_SUCCESS) { return err_code; } // Add the Data Characteristic err_code = data_char_add(p_cus, p_srvc_opt_init, cus_char_uuid); if (err_code != NRF_SUCCESS) { return err_code; } return err_code; } /**@brief Function for handling the Connect event. * * @param[in] p_cus Custom Service structure. * @param[in] p_ble_evt Event received from the BLE stack. */ static void on_connect(ble_srvc_opt_t *p_cus, ble_evt_t const *p_ble_evt) { p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle; ble_srvc_opt_evt_t evt; evt.evt_type = BLE_SRVC_EVT_CONNECTED; p_cus->evt_handler(p_cus, &evt); } /**@brief Function for handling the Disconnect event. * * @param[in] p_cus Custom Service structure. * @param[in] p_ble_evt Event received from the BLE stack. */ static void on_disconnect(ble_srvc_opt_t *p_cus, ble_evt_t const *p_ble_evt) { UNUSED_PARAMETER(p_ble_evt); p_cus->conn_handle = BLE_CONN_HANDLE_INVALID; //nrf_gpio_pin_toggle(LED_4); } static void on_write(ble_srvc_opt_t *p_cus, ble_evt_t const *p_ble_evt) { //ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write; ble_gatts_evt_write_t const *p_evt_write = &p_ble_evt->evt.gatts_evt.params.write; // State Characteristic Written to. if (p_evt_write->handle == p_cus->state_char_handle.value_handle) { if (p_cus->evt_handler != NULL) { //Set and Call the application event handler ble_srvc_opt_evt_t evt; evt.evt_type = BLE_SRVC_EVT_STATE_CHAR_WRITE; p_cus->evt_handler(p_cus, &evt); } } // Command Characteristic Written to. if (p_evt_write->handle == p_cus->cmd_char_handle.value_handle) { if (p_cus->evt_handler != NULL) { //Set and Call the application event handler ble_srvc_opt_evt_t evt; evt.evt_type = BLE_SRVC_EVT_CMD_CHAR_WRITE; p_cus->evt_handler(p_cus, &evt); } } // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes. if ((p_evt_write->handle == p_cus->state_char_handle.cccd_handle) && (p_evt_write->len == 2)) { // CCCD written, call application event handler if (p_cus->evt_handler != NULL) { ble_srvc_opt_evt_t evt; if (ble_srv_is_notification_enabled(p_evt_write->data)) { evt.evt_type = BLE_SRVC_EVT_STATE_NOTIFICATION_ENABLED; //NRF_LOG_INFO("ble_srvc_opt- on_write - BLE_SRVC_OPT_EVT_NOTIFICATION_ENABLED"); } else { evt.evt_type = BLE_SRVC_EVT_STATE_NOTIFICATION_DISABLED; //NRF_LOG_INFO("ble_srvc_opt - on_write - BLE_SRVC_OPT_EVT_NOTIFICATION_DISABLED"); } // Call the application event handler. p_cus->evt_handler(p_cus, &evt); } } } void ble_srvc_opt_on_ble_evt(ble_evt_t const *p_ble_evt, void *p_context) { ble_srvc_opt_t *p_cus = (ble_srvc_opt_t *)p_context; if (p_cus == NULL || p_ble_evt == NULL) { return; } switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("ble_srvc_opt - BLE_GAP_EVT_CONNECTED"); on_connect(p_cus, p_ble_evt); break; case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("ble_srvc_opt - BLE_GAP_EVT_DISCONNECTED"); on_disconnect(p_cus, p_ble_evt); break; case BLE_GATTS_EVT_WRITE: on_write(p_cus, p_ble_evt); break; default: // No implementation needed. break; } } uint32_t ble_mpu_update(ble_srvc_opt_t *p_cus, accel_values_t * accel_values) { // Send value if connected and notifying if (p_cus->conn_handle == BLE_CONN_HANDLE_INVALID) { return NRF_ERROR_INVALID_STATE; } uint16_t len = sizeof(accel_values_t); ble_gatts_hvx_params_t hvx_params; memset(&hvx_params, 0, sizeof(hvx_params)); hvx_params.handle = p_cus->data_char_handle.value_handle; hvx_params.type = BLE_GATT_HVX_NOTIFICATION; hvx_params.offset = 0; hvx_params.p_len = &len; hvx_params.p_data = (uint8_t*)accel_values; return sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params); }
