How to avoid erasing the special page of flash which stored some user datas when reprogramming nRF52832 through bootloader ?
   Some user datas have been stored in a special page of flash in nRF52832 . However , I need to reprogramme the chip through bootloader , and make sure the user datas not being erased .
   In the example of bootloader ,  function "nrf_bootloader_init " realizes the reprogramming the chip , the code is shown below .
   How to configure the  function of "nrf_bootloader_init " , so that I can make sure the user datas not being erased ?
ret_code_t nrf_bootloader_init(nrf_dfu_observer_t observer)
    NRF_LOG_DEBUG("In nrf_bootloader_init");
    ret_code_t                            ret_val;
    nrf_bootloader_fw_activation_result_t activation_result;
    uint32_t                              initial_timeout;
    bool                                  dfu_enter = false;
    m_user_observer = observer;
    if (NRF_BL_DEBUG_PORT_DISABLE)
        nrf_bootloader_debug_port_disable();
    if (NRF_BL_DFU_ENTER_METHOD_BUTTON)
        dfu_enter_button_init();
    ret_val = nrf_dfu_settings_init(false);
    if (ret_val != NRF_SUCCESS)
        return NRF_ERROR_INTERNAL;
    #if NRF_BL_DFU_ALLOW_UPDATE_FROM_APP
    // Postvalidate if DFU has signaled that update is ready.
    if (s_dfu_settings.bank_current == NRF_DFU_CURRENT_BANK_1)
        postvalidate();
    // Check if an update needs to be activated and activate it.
    activation_result = nrf_bootloader_fw_activate();
    switch (activation_result)
        case ACTIVATION_NONE:
            initial_timeout = NRF_BOOTLOADER_MS_TO_TICKS(NRF_BL_DFU_INACTIVITY_TIMEOUT_MS);
            dfu_enter       = dfu_enter_check();
        case ACTIVATION_SUCCESS_EXPECT_ADDITIONAL_UPDATE:
            initial_timeout = NRF_BOOTLOADER_MS_TO_TICKS(NRF_BL_DFU_CONTINUATION_TIMEOUT_MS);
            dfu_enter       = true;
        case ACTIVATION_SUCCESS:
            bootloader_reset(true);
            NRF_LOG_ERROR("Unreachable");
            return NRF_ERROR_INTERNAL; // Should not reach this.
        case ACTIVATION_ERROR:
    if (dfu_enter)
        nrf_bootloader_wdt_init();
        scheduler_init();
        dfu_enter_flags_clear();
        // Call user-defined init function if implemented
        ret_val = nrf_dfu_init_user();
        nrf_bootloader_dfu_inactivity_timer_restart(initial_timeout, inactivity_timeout);
        ret_val = nrf_dfu_init(dfu_observer);
        NRF_LOG_DEBUG("Enter main loop");
        loop_forever(); // This function will never return.
        // Erase additional data like peer data or advertisement name
        ret_val = nrf_dfu_settings_additional_erase();
        m_flash_write_done = false;
        nrf_dfu_settings_backup(flash_write_callback);
        ASSERT(m_flash_write_done);
        nrf_bootloader_app_start();
    // Should not be reached.
