Updating timer capture registers
Hello DevZone,
Is there a way for hardware to update the timer capture register?
I want to create different frequencies using a single timer. Next to the timer, Bluetooth is active.
Example, (values are random and not the values I actually need)
CC0 = 20
CC1 = 40,
CC2 = 125,
CC3 = 189,
CC4 = 323,
CC5 = 6104700 (least common multiple)
I have a short set that on compare 5 the timer will reset.
I have set interrupt enable for every capture register and in the interrupt handler I manually increment every capture register with the value I loaded initially.
The thing is that I do not want to handle this using software, using more timers is not really an option since the frequencies I need to generate will certainly require more timers than there are timers present in the nRF52832.
I've added my code, it might be useful to show what I mean.
T IJ
*                    SEGGER Microcontroller GmbH                     *
*                        The Embedded Experts                        *
*            (c) 2014 - 2020 SEGGER Microcontroller GmbH             *
*           www.segger.com     Support: [email protected]           *
* All rights reserved.                                               *
* Redistribution and use in source and binary forms, with or         *
* without modification, are permitted provided that the following    *
* conditions are met:                                                *
* - Redistributions of source code must retain the above copyright   *
*   notice, this list of conditions and the following disclaimer.    *
* - Neither the name of SEGGER Microcontroller GmbH                  *
*   nor the names of its contributors may be used to endorse or      *
*   promote products derived from this software without specific     *
*   prior written permission.                                        *
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND             *
* CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,        *
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF           *
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE           *
* DISCLAIMED.                                                        *
* IN NO EVENT SHALL SEGGER Microcontroller GmbH BE LIABLE FOR        *
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR           *
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT  *
* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;    *
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF      *
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT          *
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE  *
* USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH   *
* DAMAGE.                                                            *
-------------------------- END-OF-HEADER -----------------------------
File    : main.c
Purpose : Generic application start
#include "nrf.h"
#include <stdio.h>
#include <stdlib.h>
#define CC1 2000U
#define CC2 4000U
#define CC3 12500U
#define CC4 18900U
#define CC5 32300U
#define CC6 610470000UL
#define TIMER3_HANDLER TIMER3_IRQHandler
void TIMER3_HANDLER(void)
    static uint8_t a1 = 0, a2 = 0, a3 = 0, a4 = 0, a5 = 0;
    if (NRF_TIMER3->EVENTS_COMPARE[0] == 1)
        NRF_TIMER3->CC[0] += CC1;
        NRF_TIMER3->EVENTS_COMPARE[0] = 0;
    if (NRF_TIMER3->EVENTS_COMPARE[1] == 1)
        NRF_TIMER3->CC[1] += CC2;
        a2++;
        if (a2 == 2)
            a2 = 0;
        switch (a2)
            case 0:
                NRF_P0->OUTCLR = 1 << 17;
            case 1:
                NRF_P0->OUTSET = 1 << 17;
        NRF_TIMER3->EVENTS_COMPARE[1] = 0;
    if (NRF_TIMER3->EVENTS_COMPARE[2] == 1)
        NRF_TIMER3->CC[2] += CC3;
        a3++;
        if (a3 == 2)
            a3 = 0;
        switch (a3)
            case 0:
                NRF_P0->OUTCLR = 1 << 18;
            case 1:
                NRF_P0->OUTSET = 1 << 18;
        NRF_TIMER3->EVENTS_COMPARE[2] = 0;
    if (NRF_TIMER3->EVENTS_COMPARE[3] == 1)
        NRF_TIMER3->CC[3] += CC4;
        a4++;
        if (a4 == 2)
            a4 = 0;
        switch (a4)
            case 0:
                NRF_P0->OUTCLR = 1 << 19;
            case 1:
                NRF_P0->OUTSET = 1 << 19;
         NRF_TIMER3->EVENTS_COMPARE[3] = 0;
    if (NRF_TIMER3->EVENTS_COMPARE[4] == 1)
        NRF_TIMER3->CC[4] += CC5;
        a5++;
        if (a5 == 2)
            a5 = 0;
        switch (a5)
            case 0:
                NRF_P0->OUTCLR = 1 << 20;
            case 1:
                NRF_P0->OUTSET = 1 << 20;
         NRF_TIMER3->EVENTS_COMPARE[4] = 0;
    if (NRF_TIMER3->EVENTS_COMPARE[5] == 1)
        NRF_TIMER3->CC[0] = CC1;
        NRF_TIMER3->CC[1] = CC2;
        NRF_TIMER3->CC[2] = CC3;
        NRF_TIMER3->CC[3] = CC4;
        NRF_TIMER3->CC[4] = CC5;
        NRF_TIMER3->EVENTS_COMPARE[5] = 0;
 * @brief Function for application main entry.
    NRF_P0->DIRSET = (1 << 17) | (1 << 18) | (1 << 19) | (1 << 20);
    NRF_P0->OUT = (1 << 17) | (1 << 18) | (1 << 19) | (1 << 20);
    NRF_TIMER3->TASKS_CLEAR = 1;
    NRF_TIMER3->MODE = TIMER_MODE_MODE_Timer;
    NRF_TIMER3->BITMODE = TIMER_BITMODE_BITMODE_32Bit;
    NRF_TIMER3->PRESCALER = 9;
    NRF_TIMER3->CC[5] = CC6;
    NRF_TIMER3->INTENSET = (1 << 16) | (1 << 17) | (1 << 18) | (1 << 20) | (1 << 21);
    NRF_TIMER3->SHORTS = TIMER_SHORTS_COMPARE5_CLEAR_Msk;
    NVIC_SetPriority(TIMER3_IRQn, 2);
    NVIC_EnableIRQ(TIMER3_IRQn);
    NRF_TIMER3->TASKS_START = 1;
    while (1)
        __WFI();
        // Do nothing.
/*************************** End of file ****************************/
