I'm trying to support nRF52833 in Embeetle IDE, but flashing through OpenOCD + GDB doesn't work.
1. Background info
We're developing a new IDE for microcontrollers (see https://embeetle.com) and would like to support a range of Nordic Semiconductor microcontrollers. We received the nRF52833 board on Embedded World 2020 from Mr. Reidar Martin Svendsen for this purpose.
2. Flashing failure
We use the combination OpenOCD and GDB to flash the microcontroller. On the OpenOCD side, I get the following output:
    Open On-Chip Debugger 0.10.0+dev-00973-g80f1a92bd (2019-12-02-17:58)
    Licensed under GNU GPL v2
    For bug reports, read
    openocd.org/.../bugs.html
    swd
    Info : J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 21 2020 17:30:48
    Info : Hardware version: 1.00
    Info : VTarget = 3.300 V
    Info : clock speed 1000 kHz
    Info : SWD DPIDR 0x2ba01477
    Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
    Info : Listening on port 3333 for gdb connections
    target halted due to debug-request, current mode: Thread
    xPSR: 0x01000000 pc: 0x00000414 msp: 0x20002450
    Info : Listening on port 6666 for tcl connections
    Info : Listening on port 4444 for telnet connections
    Info : accepting 'gdb' connection on tcp/3333
    Info : nRF52833-xxAA(build code: A0) 512kB Flash, 128kB RAM
    Warn : Flash protection of this nRF device is not supported
    Error : Cannot erase protected sector at 0x0
    Error : failed erasing sectors 0 to 15
    ** Programming Started **
    Warn : Adding extra erase range, 0x00003810 .. 0x00003fff
    Error : failed erasing sectors 0 to 3
    embedded:startup.tcl:460: Error : ** Programming Failed **
    in procedure 'program'
    in procedure 'program_error' called at file "embedded:startup.tcl", line 525
    at file "embedded:startup.tcl", line 460
    shutdown command invoked
And on the GDB side, I get this:
    (gdb) target remote localhost:3333
    Remote debugging using localhost:3333
    warning: No executable has been specified and target does not support
    determining executable automatically. Try using the "file" command.
    0x00000414 in ?? ()
    (gdb) monitor reset halt
    (gdb) monitor flash erase_address 0x00000000 0x10000
    (gdb) monitor program "C:/Users/Gebruiker/beetle_projects/pca10100/build/myApp.elf"
    (gdb) monitor reset run
    (gdb) monitor shutdown
    (gdb) quit
    A debugging session is active.
    Detaching from program: , Remote target
    Remote communication error. Target disconnected.: Success.
As you can see, OpenOCD cannot erase the protected sector at 0x0. In fact, I don't know if I need to erase that sector before flashing new code. Anyway, even the flashing of the .elf itself fails:
    embedded:startup.tcl:460: Error: ** Programming Failed **
I've also tried another approach to flash the microcontroller. I start OpenOCD with the flags -c "gdb_flash_program enable" -c "gdb_breakpoint_override hard" to make sure that GDB has full control. In GDB I issue the commands:
    (gdb) file "C:/Users/Gebruiker/beetle_projects/pca10100/build/myApp.elf"
    A program is being debugged already.
    Are you sure you want to change the file? (y or n) [answered Y; input not from terminal]
    Reading symbols from C:/Users/Gebruiker/beetle_projects/pca10100/build/myApp.elf...
    (gdb) load
    Loading section .data, size 0x6c lma 0x20000000
    Error erasing flash with vFlashErase packet
For these two GDB commands, I get the following output in OpenOCD:
    Error : flash_erase returned -4
    Error : nrf52.cpu -- clearing lockup after double fault
3. Solution
The problem is solved thanks to the OpenOCD community. They fixed the problem in the latest OpenOCD build. (end of March 2020). For a step-by-step guide on how to build OpenOCD from the source code, see:
https://embeetle.com/#embedded-dev/software/dev-tools/flash/openocd_build
or see:
https://xpack.github.io/openocd
I get the following in GDB:
    0x00000414 in ?? ()
    (gdb) monitor nrf5 mass_erase
    Failed to check chip's write protection
    (gdb) monitor flash erase_check 0
    successfully checked erase state
    Bank is erased
    (gdb) monitor program "C:/Users/Gebruiker/beetle_projects/pca10056/build/myApp.elf"
    xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
    Adding extra erase range, 0x00000bc4 .. 0x00000fff
    ** Programming Finished **
    (gdb) quit
    Inferior 1 [Remote target] will be detached.
    Quit anyway? (y or n) [answered Y; input not from terminal]
Huray! The flashing workes! I've tested on both the PCA10100 (nRF52833) and the PCA10056 (nRF52840) development boards. The blinky projects from the SDK work fine:
nRF5_SDK_16.0.0_98a08e2/examples/peripheral/blinky_freertos/
As you can see, trying to erase the flash memory through giving the nrf5 mass_erase command to OpenOCD results in an error message. This seems to be a bogus error message, because OpenOCD actually succeeds to erase the flash memory (which is confirmed in the output to the flash erase_check 0 command)
The bogus error message is an unsolved problem in OpenOCD, described here:
http://openocd.zylin.com/#/c/5522/
