how to add a new BLE service in existing example?
I have added lbs_service from ble_app_blinky service within ble_app_glucose example. I made changes in main.c and EMPROJECT File accordingly. I have added ble_lbs.c file in nRF_ble_service folder but whenever I building the project the ble_lbs.c service is not compiling and throwing error in project. Please see the screenshot
 I didn't understand why it is not including in the project and why throwing error.  Please help me to find my error. I am using nRF52840 Dongle and nRF SDK_15.3.0 and V6.1.1 soft device.
Here the main.c file.
 * @defgroup ble_sdk_app_gls_main main.c
 * @ingroup ble_sdk_app_gls
 * @brief Glucose Meter service Sample Application
 * This file contains the source code for a sample application using the Glucose Meter service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "ble_bas.h"
#include "ble_lbs.h"
#include "ble_racp.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
//#define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
//#define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
#define DEVICE_NAME                     "BLE_Trigger"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "PitchVision"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define MODEL_NUMBER                    "nRF52"                                     /**< Model Number string. Will be passed to Device Information Service. */
#define MANUFACTURER_ID                 0x55AA55AA55                                /**< DUMMY Manufacturer ID. Will be passed to Device Information Service. You shall use the ID for your Company*/
#define ORG_UNIQUE_ID                   0xEEBBEE                                    /**< DUMMY Organisation Unique ID. Will be passed to Device Information Service. You shall use the Organisation Unique ID relevant for your Company */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                40                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(10000)                      /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL               81                                          /**< Minimum battery level as returned by the simulated measurement function. */
#define MAX_BATTERY_LEVEL               100                                         /**< Maximum battery level as returned by the simulated measurement function. */
#define BATTERY_LEVEL_INCREMENT         1                                           /**< Value by which the battery level is incremented/decremented for each call to the simulated measurement function. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(10, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (10 ms). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)            /**< Maximum acceptable connection interval (100 ms) */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(10000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAM_UPDATE_COUNT     3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define LESC_DEBUG_MODE                 0                                           /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
#define SEC_PARAM_LESC                  1                                           /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
#define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
#define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
#define STATIC_PASSKEY                  "123466"                                    /**< Static passkey */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define EXTERNAL_BUTTON_1               NRF_GPIO_PIN_MAP(0,24)                      // Connected to P0.24
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                         /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
// LED Definitions
#define CONNECTIVITY_LED                BSP_BOARD_LED_0
#define MAIN_LED                        NRF_GPIO_PIN_MAP(1,10)                      // Connected to P1.10
// Timer Values & Definitions
#define SLOW_BLINK_INTERVAL             APP_TIMER_TICKS(500)                        // Timer for Slow flashing LED (turn On/Off LED)
BLE_BAS_DEF(m_bas);        /**< Structure used to identify the battery service. */
BLE_LBS_DEF(m_lbs);        /**< LED Button Service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id);                                                  /**< Battery timer. */
APP_TIMER_DEF(m_connectivity_led_flashing_timer_id);                                // Timer for flashing LED in Disconnected state
static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
static uint16_t     m_conn_handle        = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static ble_uuid_t   m_adv_uuids[] =                                                 /**< Universally unique service identifiers. */
    {LBS_UUID_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static sensorsim_cfg_t   m_battery_sim_cfg;                                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                                       /**< Battery Level sensor simulator state. */
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
//Add statc password //
static void set_static_passkey(void)
    static ble_opt_t    m_static_pin_option;
    uint8_t passkey[] = STATIC_PASSKEY;
    m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
    uint32_t err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            pm_conn_sec_status_t conn_sec_status;
            // Check if the link is authenticated (meaning at least MITM).
            err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
            if (conn_sec_status.mitm_protected)
                NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
                // The peer did not use MITM, disconnect.
                NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                err_code = sd_ble_gap_disconnect(m_conn_handle,
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            advertising_start(false);
/**@brief Function for handling Service errors.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for updating glucose measurement and updating glucose characteristic in Glucose.
          Service.
static void read_glucose_measurement(void)
    ble_gls_rec_t rec;
    uint32_t      err_code;
    static int16_t s_mantissa = 550;
    static int16_t s_exponent = -3;
    static uint8_t s_secs     = 5;
    // simulate the reading of a glucose measurement.
    rec.meas.flags = BLE_GLS_MEAS_FLAG_TIME_OFFSET |
                     BLE_GLS_MEAS_FLAG_CONC_TYPE_LOC |
                     BLE_GLS_MEAS_FLAG_UNITS_MOL_L;
    rec.meas.base_time.year                 = 2012;
    rec.meas.base_time.month                = 1;
    rec.meas.base_time.day                  = 1;
    rec.meas.base_time.hours                = 12;
    rec.meas.base_time.minutes              = 30;
    rec.meas.base_time.seconds              = s_secs;
    rec.meas.glucose_concentration.exponent = s_exponent;
    rec.meas.glucose_concentration.mantissa = s_mantissa;
    rec.meas.time_offset                    = 0;
    rec.meas.type                           = BLE_GLS_MEAS_TYPE_CAP_BLOOD;
    rec.meas.sample_location                = BLE_GLS_MEAS_LOC_FINGER;
    rec.meas.sensor_status_annunciation     = 0;
    // change values for next read.
    s_mantissa += 23;
    if (s_mantissa > 939)
        s_mantissa -= 434;
    s_secs += 3;
    if (s_secs > 59)
        s_secs = 0;
    err_code = ble_gls_glucose_new_meas(&m_gls, &rec);
    if (err_code != NRF_SUCCESS)
        // Do nothing.
static void connectivity_timeout_handler(void * p_context)
    bsp_board_led_invert(CONNECTIVITY_LED);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    err_code = app_timer_init();
    // Create timers.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
    err_code = app_timer_create(&m_connectivity_led_flashing_timer_id, APP_TIMER_MODE_REPEATED, connectivity_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_UNKNOWN);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    bsp_event_t startup_event;
    nrf_gpio_cfg_output(MAIN_LED);
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
        nrf_gpio_pin_write(MAIN_LED, 1);
        NRF_LOG_INFO("Received LED ON!");
        nrf_gpio_pin_write(MAIN_LED, 0);
        NRF_LOG_INFO("Received LED OFF!");
 * @details Initialize the Glucose, Battery and Device Information services.
    ble_lbs_init_t     init = {0};
    ble_dis_init_t     dis_init;
    ble_bas_init_t     bas_init;
    /* Initialize Glucose Service - sample selection of feature bits.
    memset(&gls_init, 0, sizeof(gls_init));
    gls_init.evt_handler          = NULL;
    gls_init.error_handler        = service_error_handler;
    gls_init.feature              = 0;
    gls_init.feature             |= BLE_GLS_FEATURE_LOW_BATT;
    gls_init.feature             |= BLE_GLS_FEATURE_TEMP_HIGH_LOW;
    gls_init.feature             |= BLE_GLS_FEATURE_GENERAL_FAULT;
    gls_init.is_context_supported = false;
    // Here the sec level for the Glucose Service can be changed/increased.
    gls_init.gl_meas_cccd_wr_sec = SEC_JUST_WORKS;
    gls_init.gl_feature_rd_sec   = SEC_JUST_WORKS;
    gls_init.racp_cccd_wr_sec    = SEC_JUST_WORKS;
    gls_init.racp_wr_sec         = SEC_JUST_WORKS;
    err_code = ble_gls_init(&m_gls, &gls_init);
    //Initilize Led Services
    //memset(&init, 0, sizeof(init));
    init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &init);
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    bas_init.bl_rd_sec        = SEC_OPEN;
    bas_init.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init.bl_report_rd_sec = SEC_OPEN;
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
    ble_srv_ascii_to_utf8(&dis_init.serial_num_str, MODEL_NUMBER);
    ble_dis_sys_id_t system_id;
    system_id.manufacturer_id            = MANUFACTURER_ID;
    system_id.organizationally_unique_id = ORG_UNIQUE_ID;
    dis_init.p_sys_id                    = &system_id;
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
    // Start application timers.
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameter events.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail configuration parameter, but instead we use the
 *                event handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    cp_init.max_conn_params_update_count   = MAX_CONN_PARAM_UPDATE_COUNT;
    ret_code_t err_code;;
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising");
            // Set LED state
            err_code = app_timer_start(m_connectivity_led_flashing_timer_id, SLOW_BLINK_INTERVAL, NULL);
            break; // BLE_ADV_EVT_FAST
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
            break; // BLE_ADV_EVT_IDLE
    pm_handler_secure_on_connection(p_ble_evt);
            NRF_LOG_INFO("Disconnected");
            // Check if the last connected peer had not used MITM, if so, delete its bond information.
            if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
                err_code = pm_peer_delete(m_peer_to_be_deleted);
                NRF_LOG_DEBUG("Collector's bond deleted");
        } break;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
            //APP_ERROR_CHECK(err_code);
            err_code = app_timer_stop(m_connectivity_led_flashing_timer_id);
            bsp_board_led_on(CONNECTIVITY_LED);
            // Start Security Request timer.
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
        case BLE_GAP_EVT_PASSKEY_DISPLAY:
            char passkey[PASSKEY_LENGTH + 1];
            memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
            passkey[PASSKEY_LENGTH] = 0;
            NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
        } break;
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
         case BLE_GAP_EVT_AUTH_STATUS:
             NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_WHITELIST_OFF
        case BSP_EVENT_KEY_1:
            //read_glucose_measurement();
            break; // BSP_EVENT_KEY_1
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
static void log_init(void)
    err_code = nrf_ble_lesc_request_handler();
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    set_static_passkey();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Glucose example started.");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
Here the Emproject file
<!DOCTYPE CrossStudio_Project_File>
<solution Name="ble_app_gls_pca10059_s140" target="8" version="2">
  <project Name="ble_app_gls_pca10059_s140">
    <configuration
      Name="Common"
      arm_architecture="v7EM"
      arm_core_type="Cortex-M4"
      arm_endian="Little"
      arm_fp_abi="Hard"
      arm_fpu_type="FPv4-SP-D16"
      arm_linker_heap_size="8192"
      arm_linker_process_stack_size="0"
      arm_linker_stack_size="8192"
      arm_linker_treat_warnings_as_errors="No"
      arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
      arm_target_device_name="nRF52840_xxAA"
      arm_target_interface_type="SWD"
      c_preprocessor_definitions="BOARD_PCA10059;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;MBEDTLS_CONFIG_FILE="nrf_crypto_mbedtls_config.h";NO_VTOR_CONFIG;NRF52840_XXAA;NRF_APP_VERSION=0x00000001;NRF_APP_VERSION_ADDR=0x1D000;NRF_CRYPTO_MAX_INSTANCE_COUNT=1;NRF_SD_BLE_API_VERSION=6;S140;SOFTDEVICE_PRESENT;SWI_DISABLE0;"
      c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/atomic_flags;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/bsp;../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/crypto/backend/cc310;../../../../../../components/libraries/crypto/backend/cc310_bl;../../../../../../components/libraries/crypto/backend/cifra;../../../../../../components/libraries/crypto/backend/mbedtls;../../../../../../components/libraries/crypto/backend/micro_ecc;../../../../../../components/libraries/crypto/backend/nrf_hw;../../../../../../components/libraries/crypto/backend/nrf_sw;../../../../../../components/libraries/crypto/backend/oberon;../../../../../../components/libraries/crypto/backend/optiga;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/memobj;../../../../../../components/libraries/mpu;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/ringbuf;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/sensorsim;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/stack_guard;../../../../../../components/libraries/stack_info;../../../../../../components/libraries/strerror;../../../../../../components/libraries/svc;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/twi_sensor;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/util;../../../../../../components/nfc/ndef/conn_hand_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser;../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser;../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser;../../../../../../components/nfc/ndef/connection_handover/ac_rec;../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata;../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib;../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg;../../../../../../components/nfc/ndef/connection_handover/common;../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec;../../../../../../components/nfc/ndef/connection_handover/hs_rec;../../../../../../components/nfc/ndef/connection_handover/le_oob_rec;../../../../../../components/nfc/ndef/generic/message;../../../../../../components/nfc/ndef/generic/record;../../../../../../components/nfc/ndef/launchapp;../../../../../../components/nfc/ndef/parser/message;../../../../../../components/nfc/ndef/parser/record;../../../../../../components/nfc/ndef/text;../../../../../../components/nfc/ndef/uri;../../../../../../components/nfc/t2t_lib;../../../../../../components/nfc/t2t_parser;../../../../../../components/nfc/t4t_lib;../../../../../../components/nfc/t4t_parser/apdu;../../../../../../components/nfc/t4t_parser/cc_file;../../../../../../components/nfc/t4t_parser/hl_detection_procedure;../../../../../../components/nfc/t4t_parser/tlv;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s140/headers;../../../../../../components/softdevice/s140/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../../../../../external/fprintf;../../../../../../external/mbedtls/include;../../../../../../external/nrf_cc310/include;../../../../../../external/nrf_oberon;../../../../../../external/nrf_oberon/include;../../../../../../external/nrf_tls/mbedtls/nrf_crypto/config;../../../../../../external/segger_rtt;../../../../../../external/utf_converter;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config;"
      debug_additional_load_file="../../../../../../components/softdevice/s140/hex/s140_nrf52_6.1.1_softdevice.hex"
      debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52840.svd"
      debug_start_from_entry_point_symbol="No"
      debug_target_connection="J-Link"
      gcc_debugging_level="Level 3"
      gcc_entry_point="Reset_Handler"
      linker_output_format="hex"
      linker_printf_fmt_level="long"
      linker_printf_width_precision_supported="Yes"
      linker_scanf_fmt_level="long"
      linker_section_placement_file="flash_placement.xml"
      linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0x26000;FLASH_SIZE=0xda000;RAM_START=0x200022e0;RAM_SIZE=0x3dd20"
      linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000"
      macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
      project_directory=""
      project_type="Executable" />
    <folder Name="Segger Startup Files">
      <file file_name="$(StudioDir)/source/thumb_crt0.s" />
    </folder>
    <folder Name="nrf_cc310">
      <file file_name="../../../../../../external/nrf_cc310/lib/cortex-m4/hard-float/libnrf_cc310_0.9.12.a" />
    </folder>
    <folder Name="Board Support">
      <file file_name="../../../../../../components/libraries/bsp/bsp.c" />
      <file file_name="../../../../../../components/libraries/bsp/bsp_btn_ble.c" />
    </folder>
    <folder Name="nRF_Crypto backend nRF HW">
      <file file_name="../../../../../../components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_init.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_rng.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_rng_mbedtls.c" />
    </folder>
    <folder Name="nRF_Libraries">
      <file file_name="../../../../../../components/libraries/button/app_button.c" />
      <file file_name="../../../../../../components/libraries/util/app_error.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
      <file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
      <file file_name="../../../../../../components/libraries/timer/app_timer.c" />
      <file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
      <file file_name="../../../../../../components/libraries/crc16/crc16.c" />
      <file file_name="../../../../../../components/libraries/fds/fds.c" />
      <file file_name="../../../../../../components/libraries/hardfault/hardfault_implementation.c" />
      <file file_name="../../../../../../components/libraries/mem_manager/mem_manager.c" />
      <file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
      <file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
      <file file_name="../../../../../../components/libraries/atomic_flags/nrf_atflags.c" />
      <file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
      <file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
      <file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
      <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage.c" />
      <file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage_sd.c" />
      <file file_name="../../../../../../components/libraries/memobj/nrf_memobj.c" />
      <file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
      <file file_name="../../../../../../components/libraries/queue/nrf_queue.c" />
      <file file_name="../../../../../../components/libraries/ringbuf/nrf_ringbuf.c" />
      <file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
      <file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
      <file file_name="../../../../../../components/libraries/sensorsim/sensorsim.c" />
    </folder>
    <folder Name="nRF_Drivers">
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_rng.c" />
      <file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_uart.c" />
      <file file_name="../../../../../../modules/nrfx/soc/nrfx_atomic.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_rng.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uart.c" />
      <file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c" />
    </folder>
    <folder Name="Board Definition">
      <file file_name="../../../../../../components/boards/boards.c" />
    </folder>
    <folder Name="nRF_Log">
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_uart.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_default_backends.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_frontend.c" />
      <file file_name="../../../../../../components/libraries/log/src/nrf_log_str_formatter.c" />
    </folder>
    <folder Name="nRF_TLS">
      <file file_name="../../../../../../external/mbedtls/library/aes.c" />
      <file file_name="../../../../../../external/mbedtls/library/ctr_drbg.c" />
    </folder>
    <folder Name="nRF_Oberon_Crypto">
      <file file_name="../../../../../../external/nrf_oberon/lib/cortex-m4/hard-float/liboberon_2.0.7.a" />
    </folder>
    <folder Name="nRF_Crypto">
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_aead.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_aes.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_aes_shared.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_ecc.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_ecdh.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_ecdsa.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_eddsa.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_error.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_hash.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_hkdf.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_hmac.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_init.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_rng.c" />
      <file file_name="../../../../../../components/libraries/crypto/nrf_crypto_shared.c" />
    </folder>
    <folder Name="Application">
      <file file_name="../../../main.c" />
      <file file_name="../config/sdk_config.h" />
    </folder>
    <folder Name="nRF_Segger_RTT">
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
    </folder>
    <folder Name="None">
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52840.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
      <file file_name="../../../../../../modules/nrfx/mdk/system_nrf52840.c" />
    </folder>
    <folder Name="nRF_Crypto backend CC310">
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_aes.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_aes_aead.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_chacha_poly_aead.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_ecc.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_ecdh.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_ecdsa.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_eddsa.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_hash.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_hmac.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_init.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_mutex.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_rng.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/cc310/cc310_backend_shared.c" />
    </folder>
    <folder Name="nRF_BLE">
      <file file_name="../../../../../../components/ble/peer_manager/auth_status_tracker.c" />
      <file file_name="../../../../../../components/ble/common/ble_advdata.c" />
      <file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
      <file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
      <file file_name="../../../../../../components/ble/common/ble_conn_state.c" />
      <file file_name="../../../../../../components/ble/ble_racp/ble_racp.c" />
      <file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
      <file file_name="../../../../../../components/ble/peer_manager/gatt_cache_manager.c" />
      <file file_name="../../../../../../components/ble/peer_manager/gatts_cache_manager.c" />
      <file file_name="../../../../../../components/ble/peer_manager/id_manager.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
      <file file_name="../../../../../../components/ble/peer_manager/nrf_ble_lesc.c" />
      <file file_name="../../../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_data_storage.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_database.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_id.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_manager.c" />
      <file file_name="../../../../../../components/ble/peer_manager/peer_manager_handler.c" />
      <file file_name="../../../../../../components/ble/peer_manager/pm_buffer.c" />
      <file file_name="../../../../../../components/ble/peer_manager/security_dispatcher.c" />
      <file file_name="../../../../../../components/ble/peer_manager/security_manager.c" />
    </folder>
    <folder Name="UTF8/UTF16 converter">
      <file file_name="../../../../../../external/utf_converter/utf.c" />
    </folder>
    <folder Name="nRF_BLE_Services">
      <file file_name="ble_bas.c" />
      <file file_name="ble_dis.c" />
      <file file_name="ble_lbs.c" />
    </folder>
    <folder Name="nRF_SoftDevice">
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh.c" />
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh_ble.c" />
      <file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
    </folder>
    <folder Name="nRF_Crypto backend Oberon">
      <file file_name="../../../../../../components/libraries/crypto/backend/oberon/oberon_backend_chacha_poly_aead.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/oberon/oberon_backend_ecc.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/oberon/oberon_backend_ecdh.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/oberon/oberon_backend_ecdsa.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/oberon/oberon_backend_eddsa.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/oberon/oberon_backend_hash.c" />
      <file file_name="../../../../../../components/libraries/crypto/backend/oberon/oberon_backend_hmac.c" />
    </folder>
  </project>
  <configuration
    Name="Release"
    c_preprocessor_definitions="NDEBUG"
    gcc_optimization_level="Optimize For Size" />
  <configuration
    Name="Debug"
    c_preprocessor_definitions="DEBUG; DEBUG_NRF"
    gcc_optimization_level="None" />
</solution>
