I'm very new to c programming and your hardware. Please excuse my novice questions.
I'm making a rotary braille display using nRF52840 dongle (PCA10059) as it's brain. The dongle will take interrupt input from phototransistors to trigger braille dot outputs according to values at index position on an array of braille code in the memory.
My previous prototype is Raspberry Pi-based and runs on Python as in this video
I see nRF52840 Dongle can greatly reduce the size of the braille display prototype.
Now I cannot get any external pin other than the on board ones to receive or output some voltage. What am I doing wrong?
#include <stdbool.h>
#include <stdint.h>
#include "nrf_delay.h"
#include "boards.h"
#include "pca10059.h"
#include "app_timer.h"
#include "app_button.h"
#include "nrf_sdh.h"
// Rotation sensor inputs
// Encoder trigger
#define ENC_IN NRF_GPIO_PIN_MAP(0,10)
#define ENC_DIR NRF_GPIO_PIN_DIR_INPUT
#define ENC_PULL NRF_GPIO_PIN_PULLUP
// Direction detect
#define DIR_IN NRF_GPIO_PIN_MAP(0,13)
#define DIR_DIR NRF_GPIO_PIN_DIR_INPUT
#define DIR_PULL NRF_GPIO_PIN_PULLUP
// Buttons input
//#define BMIDA_IN NRF_GPIO_PIN_MAP(0,24)
//#define BMIDA_DIR NRF_GPIO_PIN_DIR_INPUT
//#define BMIDA_PULL NRF_GPIO_PIN_PULLUP
//#define BMIDB_IN NRF_GPIO_PIN_MAP(1,00)
//#define BMIDB_DIR NRF_GPIO_PIN_DIR_INPUT
//#define BMIDB_PULL NRF_GPIO_PIN_PULLUP
//#define BTHMA_IN NRF_GPIO_PIN_MAP(0,09)
//#define BTHMA_DIR NRF_GPIO_PIN_DIR_INPUT
//#define BTHMA_PULL NRF_GPIO_PIN_PULLUP
//#define BTHMB_IN NRF_GPIO_PIN_MAP(0,10)
//#define BTHMB_DIR NRF_GPIO_PIN_DIR_INPUT
//#define BTHMB_PULL NRF_GPIO_PIN_PULLUP
// Actuator output Right
#define ACT_1 NRF_GPIO_PIN_MAP(0,22)
#define A1_DIR NRF_GPIO_PIN_DIR_OUTPUT
#define ACT_2 NRF_GPIO_PIN_MAP(0,20)
#define A2_DIR NRF_GPIO_PIN_DIR_OUTPUT
#define ACT_3 NRF_GPIO_PIN_MAP(0,17)
#define A3_DIR NRF_GPIO_PIN_DIR_OUTPUT
#define ACT_4 NRF_GPIO_PIN_MAP(0,15)
#define A4_DIR NRF_GPIO_PIN_DIR_OUTPUT
// Actuator output Left
#define ACT_5 NRF_GPIO_PIN_MAP(0,31)
#define A5_DIR NRF_GPIO_PIN_DIR_OUTPUT
#define ACT_6 NRF_GPIO_PIN_MAP(0,29)
#define A6_DIR NRF_GPIO_PIN_DIR_OUTPUT
#define ACT_7 NRF_GPIO_PIN_MAP(0,02)
#define A7_DIR NRF_GPIO_PIN_DIR_OUTPUT
#define ACT_8 NRF_GPIO_PIN_MAP(1,15)
#define A8_DIR NRF_GPIO_PIN_DIR_OUTPUT
// Sample Braille Code, one array for each dot out of 8
// Left column
bool BST_L1[] = { 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1 };
bool BST_L2[] = { 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1 };
bool BST_L3[] = { 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1 };
bool BST_L4[] = { 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1 };
// Right column
bool BST_R1[] = { 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1 };
bool BST_R2[] = { 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1 };
bool BST_R3[] = { 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1, 0, 1 };
bool BST_R4[] = { 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1 };
// Define size of braille
size_t bst_len = ARRAY_SIZE(BST_L1);
size_t i = 0;
// Interrupt handler
static void button_handler(uint8_t pin, uint8_t action) {
// When encoder input is detected rotating to the right
if (pin == ENC_IN) {
if (ENC_IN == 0 && DIR_IN == 0) {
// Output braille left column
nrf_gpio_pin_write(ACT_1,BST_L1[i]);
nrf_gpio_pin_write(ACT_2,BST_L2[i]);
nrf_gpio_pin_write(ACT_3,BST_L3[i]);
nrf_gpio_pin_write(ACT_4,BST_L4[i]);
nrf_gpio_pin_write(ACT_5,0);
nrf_gpio_pin_write(ACT_6,0);
nrf_gpio_pin_write(ACT_7,0);
nrf_gpio_pin_write(ACT_8,0);
// Direction light Green
nrf_gpio_pin_write(LED2_G,0);
nrf_gpio_pin_write(LED2_R,1);
} else if (ENC_IN == 1 && DIR_IN == 1) {
// Output braille right column
nrf_gpio_pin_write(ACT_1,BST_R1[i]);
nrf_gpio_pin_write(ACT_2,BST_R2[i]);
nrf_gpio_pin_write(ACT_3,BST_R3[i]);
nrf_gpio_pin_write(ACT_4,BST_R4[i]);
// Direction light Red
nrf_gpio_pin_write(LED2_G,1);
nrf_gpio_pin_write(LED2_R,0);
// Index increment, reset if end of string
i++;
if (i == bst_len) {
i = 0;
// When white button is pushed
if (pin == BUTTON_1) {
nrf_gpio_pin_toggle(LED1_G);
* @brief Function for application main entry.
int main() {
/* Configure board. */
bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
app_timer_init();
nrf_sdh_enable_request();
static app_button_cfg_t buttons[] = {
{ENC_IN, false, ENC_PULL, button_handler},
{BUTTON_1, false, ENC_PULL, button_handler}
app_button_init(buttons, ARRAY_SIZE(buttons), 50);
app_button_enable();
// Blink an LED just to check if the program is running
while (true) {
nrf_gpio_pin_toggle(LED2_B);
nrf_delay_ms(1000);
Thank you,
Song
